Re: Some Validation Rules are not executed properly within the generated plugin. [message #1786950 is a reply to message #1786792] |
Wed, 16 May 2018 09:54 |
Christoforos Zolotas Messages: 10 Registered: March 2015 |
Hello Pierre,
based on your question on how I integrated my plugin, I tried it to a fresh Eclipse Oxygen copy and it seems to work fine.
So I suppose that there must be some sort of conflict when the plugin is installed in the "development" Eclipse (where there exist also the corresponding Ecore/Sirius projects in the same workspace) or that something was misconfigured. I write this here so anyone in future will have this possibility also in mind once such issues occur.
Since the plugin works as intended in non development eclipse environments, I consider this issue solved, as far as I am concerned.
Therefore, thank you a lot for your time and any related effort from your part. In case I spot any related issue I will let you know.
Christoforos
[Updated on: Wed, 16 May 2018 09:55] Report message to a moderator
FUDForum. Page generated in 0.03895 seconds
