Re: Can Eclipse deduce compiler flags in a Makefile/autotools project? [message #1784825 is a reply to message #1784773] |
Wed, 04 April 2018 13:38 |
Ilya Basin Messages: 25 Registered: October 2011 |
Thank you David. I have the libtool gcc builld output parser enabled and it indeed adds the include and define entries to my source files. However, in the C/C++ Editor there's still the marker "Unresolved inclusion: <glib.h>", even though the file properties show the system include directory "/usr/include/glib-2.0" under the build output parser entries.
It seems that in multi-configuration project the editor doesn't take these settings from the active configuration, but instead from the initial configuration, which is called "Build (GNU)".
[Updated on: Wed, 04 April 2018 13:44] Report message to a moderator
FUDForum. Page generated in 0.04209 seconds
