Re: Breaking up a domain model [message #1784482 is a reply to message #1784383] |
Wed, 28 March 2018 14:05 |
In the Model Explorer view, you can navigate in your semantic model and select an element you would like to set as the root of a sub-model. To do that there is a contextual action "Control". This will split the model and set the select element as the root of the sub-model. Note that if there are diagrams with semantic roots among the element that are moved to the new sub-model, a popup will offer the possibility to also split the graphical model (.aird) to place the diagram in a new sub-graphical model.
Note that if you create or drag and drop several model in your modeling project, they will be added to the current session and you will be able to add reference to element of a different model.
Finally, if you are not in a modeling project, the default emf editor have a contextual menu "Load Resource" to allow to load a different model (in the context of the current one) that allows to reference elements of the loaded model.
Steve
Steve Monnier - Obeo Canada
FUDForum. Page generated in 0.03201 seconds
