Home » Eclipse Projects » OM2M » org.eclipse.equinox.console bundle is missing
org.eclipse.equinox.console bundle is missing [message #1784301] Mon, 26 March 2018 08:11 Go to next message
I am working on the OM2M project I have cloned and build OM2M git repository. When I run start.bat file in org.eclipse.om2m.site.in-cse folder. it gives this error in the console file.
!ENTRY org.eclipse.osgi 4 0 2018-03-26 16:55:36.622
!MESSAGE Could not find bundle: org.eclipse.equinox.console
I have googled it but could not find the solution. If someone knows the solution kindly help me with this.
Thanks!
Ahmad Arif
Re: org.eclipse.equinox.console bundle is missing [message #1784310 is a reply to message #1784301] Mon, 26 March 2018 10:54 Go to previous messageGo to next message
Hi Ahmad,
Could you please try with java 1.8 ?
Mahdi
Re: org.eclipse.equinox.console bundle is missing [message #1784318 is a reply to message #1784310] Mon, 26 March 2018 12:58 Go to previous messageGo to next message
Hi Mahdi,
Thanks for the reply. I am using java 1.8 but the problem is solved I recloned and build om2m its working fine now.
I have another question can you guide me how to send data from gateway to server? I tried lamp example but it's not working properly. Kindly help me with this.
Ahmad Arif
Re: org.eclipse.equinox.console bundle is missing [message #1784489 is a reply to message #1784318] Wed, 28 March 2018 11:48 Go to previous messageGo to next message
Hi Mahdi,
I have done RestAPI tutorial for send data to the server and successfully adds the container for data I used postman for this purpose. I want to send telemetry data coming from different sensors. Is there any example code (Java) or guide available?
Thanks!
Ahmad Arif
Re: org.eclipse.equinox.console bundle is missing [message #1805484 is a reply to message #1784301] Tue, 16 April 2019 03:01 Go to previous message
Hi Ahmad Arif,
I am trying to build OM2M in ubuntu 16.04 . Could you please give some document how to do this.
I referred the link https://wiki.eclipse.org/OM2M/Clone
I need to build for the reason that MQTT binding is not built in official release https://wiki.eclipse.org/OM2M/Download
version v1.3.0 release.
Hence I need procedure and prerequisite to build OM2M project in eclipse
[1] Linux Ubuntu OS Version required ??
[2] Java version with build number ??
[3] OS type 32 or 64 bit ??
[4] Eclipse IDE version(Luna , oxygen , etc ...) and type(32 bit /64 bit) ??
[5] maven version for ubuntu ??
[6] Project import and IDE configuration document ?
[7] Any plugin required , if so name and http:// location, if need to be installed via new software installation via eclipse ?
[8] Any plugin from eclipse marketplace if any ??
Please refer my post on the details on error when i tried to build
https://www.eclipse.org/forums/index.php/m/1805354/?srch=%5BERROR%5D+eclipse-plugin#msg_1805354
Ilanchezhian Thingalkodi
Previous Topic:MQTT: Error in creating container/content instance on MN-CSE/IN-CSE
Next Topic:[REQUEST] Official Release with MQTT binding feature pre-built
Current Time: Thu Jul 31 09:42:29 EDT 2025
Powered by FUDForum. Page generated in 0.05126 seconds
