Re: Different text for unknown values of ports [message #1784231 is a reply to message #1784216] |
Fri, 23 March 2018 21:35 |
I spent some further time on investigating this and also found one issue in FORTE that can cause it [1]. As you can see in the bug report I already fixed it. The problem was that for derived ANY types (e.g., ANY_INT) the monitoring always sent an empty string as value back. This somehow confused the IDE. I don't know how to handle this in the ide as I could also not reproduce the strange output that you saw on your machine. But at least it helped us to track down a strange issue in FORTE. Furthermore FORTE's execution was not harmed by this issue and always the same data was sent from FORTE to the IDE. Why the values where changing I don't know.
In order that this is not coming back I also added a set of unit tests to check that now the behavior on FORTE is as intended.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=532845
FUDForum. Page generated in 0.03546 seconds
