Home » Eclipse Projects » Gendoc » Not able to retrieve SysML 1.4 Internal Block Diagram
Not able to retrieve SysML 1.4 Internal Block Diagram [message #1784008] Wed, 21 March 2018 09:46 Go to next message
I tried to list diagrams part of a package with the following command:
[for (d:notation::Diagram | element.getPapyrusDiagrams())]<drop/>
[d.name/]
it appears that some diagrams type from my project in this package, like SysML 1.4 Internal Block Diagram is unfortunately not part of this...
Is this something already identified or should I retrieve this in another way ?
Thanks by advance,
Samuel
Re: Not able to retrieve SysML 1.4 Internal Block Diagram [message #1784179 is a reply to message #1784008] Fri, 23 March 2018 05:04 Go to previous message
Hi Samuel,
It may happen the missing diagram is owned by the package but its root element is someting else. The query getPapyrusDiagrams(arg0 : ecore::EObject) : Sequence(Diagram), give you the diagram that has the element as root.
If this is the case, you may try to use a new query we introduced in 0.7.0 (Available in the nightly build): getPapyrusOwnedDiagrams(arg0 : ecore::EObject) : Sequence(Diagram).
Otherwise, for a work around you can look at this topic: https://www.eclipse.org/forums/index.php/t/1091522/
Note: The Gendoc v0.7.0 will be released Monday 26th, Mars.
Previous Topic:gendoc build with maven
Next Topic:is it possible to change the orientation of the page dynamically in word using gendoc
Current Time: Sun Nov 02 21:33:42 EST 2025
Powered by FUDForum. Page generated in 0.04081 seconds
