TLS SSL Socket error on client , disconnecting [message #1783732] |
Fri, 16 March 2018 07:48 |
I am running mosquitto version 1.4.15 (build date 28/02/2018 16:01:56.25)
I followed steps in tutorial in given link below to try out MQTT over ssl/tls on Windows.
Tutorial followed.
steves-internet-guide for mosquitto-tls
{it is now allowing me to add link here but can be googled )
and
Enable Secure Communication with TLS and the Mosquitto Broker
Erich Styger
these tutorials are similar to Eclipse Mosquitto help but slightly more elaborate.
What is Issue:
I am getting error
" New connection from 10.186.0.66 on port 8883″
"Socket error on client , disconnecting." on server and
on client side I get "A TLS error occured".
I am using CN=My computer name where I am running mosquitto server. I tried client from VMWare and on same local machine where mosquitto sever is running both gives same error.
What I have tried so far
I use mossquitto -v for broker on admin Cmd window
and Client is Mosquitto_pub on different admin Cmd window on same machine.
I have installed and used
Win32OpenSSL-1_1_0g installed.
from this installation I have copied following dlls to mosquitto folder
libcrypto-1_1.dll
libssl-1_1.dll
pthreadVC2.dll
My mosquitto conf file is default with following change
Require Certificate is false (as default)
and Allow_ anonymous is true (default) but set it explicitly as well
Difference from defualt/original mosquitto.conf is following
#port 1883 -> port 8883
cafile c:\mosquitto\certs\ca.crt
keyfile c:\mosquitto\certs\server.key
certfile c:\mosquitto\certs\server.crt
tried server key with/without passphrase
Tried different tls version v1 v1.1 v1.2.
I have run following command and don't get any error except
openssl s_client -showcerts -connect MyTest-PC:8883
Protocol : TLSv1.2
Verify return code: 18 (self signed certificate)
I used whireshark to see where is it going wrong and found that
Server hello is successfully done
Client sends Client key Exchange, Change Cipher spec, Encrypted handshake Message
that Server replys with RST and abruptly drops communication
Please find attached whireshark package capture file
I have checked following things
- firewall is not blocking TCP traffic
- tried different port number
- running mosquitto_pub on separate admin cmd (console window) ,
- running mosquitto_pub on vmware
- can establish mqtt communication without TLS/SSL
- make sure that password file is not mentioned and password required is off
- make sure allow allow_anonymous true (i.e default but tried explicitly set)
- tried --insecure on mosquitto_pub
FUDForum. Page generated in 0.46674 seconds
