Home » Eclipse Projects » Eclipse Titan » Encoding function for 3GPP RLC/PDCP PDUs
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1783564 is a reply to message #1783510] |
Wed, 14 March 2018 07:54 |
Hi Andre.
sorry, my bad, I should have looked into it in more detail.
In order for Titan to generate the appropriate RAW codecs , you need
1) a final with { encode "RAW"}
2) at least an empty with { variant "" } decorating the types you intend to encode/decode - I'm guessing this is what is missing in your case
(if an empty variant is attached, Titan will generate default encodings, which may not be what you are after)
3) either a purposefully declared external function , or usage of encvalue/decvalue
to refer to your example:
module EUTRA_ASP_DrbDefs {
external function enc_PDCP_PDU(in PDCP_PDU_Type pdu) return octetstring
with { extension "prototype(convert) encode(RAW)" };
external function dec_PDCP_PDU(in octetstring stream) return PDCP_PDU
with { extension "prototype(convert) decode(RAW)" };
type record of PDCP_PDU_Type PDCP_PDUList_Type with { variant "" };
} // End sub-group PDCP
} with { encode "RAW"}
Translation ports are just a clever way to reuse ports for lower layers (like TCP, UDP ) for a higher level transport (e.g. HTTP, SNMP).
I guess you should look into IPL4 which can be used in UDP/TCP/SCTP mode and build a translation from that to your higher level protocol.
Alternatively you can write your own port , which usually start with generating a skeleton (see apiguide) and then adding your specific code.
I hope this helps somewhat
BR ELemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1783612 is a reply to message #1783564] |
Wed, 14 March 2018 15:06 |
Andre Puschmann Messages: 57 Registered: March 2018 |
Member |
Hi Elemar,
no worries at all. After applying your suggestion with "with {variant ""}" on all types and subtypes it generated the code without issues. I've now also added dummy functions for all those functions I declared external and the project compiles and links now.
I am now trying to execute a simple dummy test case that actually just encodes a type into a ASN1 and succeeds then. The entire project, however, contains many more modules that are all loaded and initialized on startup but seem to fail.
$ ttcn3_start ./rlctester ../RLC_Test.cfg
ttcn3_start: Starting the test suite
ttcn3_start: warning: TTCN3_DIR environment variable is not set
spawn mctr_cli ../RLC_Test.cfg
* TTCN-3 Test Executor - Main Controller 2 *
* Version: CRL 113 200/6 R2A *
* Copyright (c) 2000-2017 Ericsson Telecom AB *
* All rights reserved. This program and the accompanying materials *
* are made available under the terms of the Eclipse Public License v1.0 *
* which accompanies this distribution, and is available at *
* http://www.eclipse.org/legal/epl-v10.html *
Using configuration file: ../RLC_Test.cfg
MC@andre-xps13: Unix server socket created successfully.
MC@andre-xps13: Listening on TCP port 40777.
MC2> andre-xps13 is the default
spawn ././rlctester andre-xps13 40777
TTCN-3 Host Controller (parallel mode), version CRL 113 200/6 R2A
MC@andre-xps13: New HC connected from localhost [127.0.0.1]. andre-xps13: Linux 4.13.0-36-generic on x86_64.
cmtc
MC@andre-xps13: Downloading configuration file to all HCs.
HC@andre-xps13: CommonDefs.ttcn:227: Dynamic test case error: Accessing an element of an unbound charstring value.
Error: There were errors during configuring HCs.
Error during initialization. Cannot create MTC.
MC2> ttcn3_start: error: the MTC cannot be created.
exit
MC@andre-xps13: Shutting down session.
MC@andre-xps13: Shutdown complete.
The actual code in that file (which comes from the 3gpp test suite) is like follow:
var integer v_StrLen := lengthof(p_String);
It's actually only used in a number of templates that are, however, not used themselves in any test case. Any idea how to get rid of this? Or is exactly this, i.e. the fact that it is not really used, the issue? The problem is that the 3gpp testsuite does use it in some other testcases but I thought it would be easier to start with a project that only includes a few testcases rather than the whole beast.
Andre
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1783620 is a reply to message #1783612] |
Wed, 14 March 2018 16:23 |
Hi Andre,
without the the code and the complete log all I can tell you is that you should trace back the p_String and find out where it should originate its value from.
This early in the initialization phase should not be too complicated.
If you are lucky it originates in an uninitialized module parameter which you can then simply initialize from the configuration file.
If you are not restricted by copyright, confidentiality etc. and can upload your example , I can take a look.
Best regards
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1783709 is a reply to message #1783695] |
Fri, 16 March 2018 07:14 |
Hi Andre,
here's what happens: Titan is trying to initialize whatever could not be initialized during compilation; this practically means everything that depends on
module parameters that are initialized during runtime, from values set in the configuration file.
For instance it will try to initialize
template (value) PacketFilterComponent cs_PktFilterCompIPv4RemoteAddress :=
{ // 9 octets
/* @status APPROVED */
id := '10'O, // IPv4 remote address
packetFilterComponentValue := {
ipv4RemoteAddress := f_Convert_IPv4Addr2OctString(px_IPv4_RemoteAddress) & tsc_IPv4Mask // R5s100189
whose value depends from px_IPv4_RemoteAddress;
so it will call
function f_Convert_IPv4Addr2OctString(charstring p_IPv4AddrChar) return O4_Type
var Char1List_Type v_SplitCharList := {"."};
var CharStringList_Type v_FieldList := f_StringSplit(p_IPv4AddrChar, v_SplitCharList);
var octetstring v_IPv4AddrOct := ''O;
var integer v_FieldCnt := lengthof(v_FieldList);
var integer v_IntVal;
var integer i;
if (v_FieldCnt != 4) {
FatalError(__FILE__, __LINE__, "invalid IP Address");
for (i:=0; i<v_FieldCnt; i:=i+1) {
v_IntVal := str2int(v_FieldList[i]);
v_IPv4AddrOct := v_IPv4AddrOct & int2oct(v_IntVal, 1);
return v_IPv4AddrOct;
with px_IPv4_RemoteAddress
which will invoke f_StringSplit with px_IPv4_RemoteAddress as input,
which finally calls lengthof( px_IPv4_RemoteAddress)
but problem is that px_IPv4_RemoteAddress is not initialized as it can be seen from the log:
07:42:25.178406 - TTCN-3 Host Controller started on GlobalWarning1. Version: CRL 113 200/6 R3A.
07:42:25.178473 - TTCN Logger v2.2 options: TimeStampFormat:=Time; LogEntityName:=No; LogEventTypes:=No; SourceInfoFormat:=Single; *.FileMask:=LOG_ALL | DEBUG; *.ConsoleMask:=ERROR | USER; LogFileSize:=0; LogFileNumber:=1; DiskFullAction:=Error
07:42:25.178974 - The address of MC was set to GlobalWarning1[127.0.1.1]:0.
07:42:25.179281 - The local IP address of the control connection to MC is 127.0.0.1.
07:42:25.179316 - Connected to MC.
07:42:25.179397 - This host supports UNIX domain sockets for local communication.
07:42:25.180083 - Processing configuration data received from MC.
07:42:25.180809 - Module EUTRA_Parameters has the following parameters: { px_MaxNumberROHC_ContextSessions := cs16 (4), px_NAS_CipheringAlgorithm := '000'B, px_NAS_IntegrityProtAlgorithm := '001'B, px_RRC_CipheringAlgorithm := eea0 (0), px_RRC_IntegrityProtAlgorithm := eia1 (1), px_eSecondaryBandChannelBandwidth := n25 (2), px_eTDDsubframeConfig := sa1 (1), px_eUE_Category_Type := 1, pc_eBand10_Supp := false, pc_eBand11_Supp := false, pc_eBand12_Supp := false, pc_eBand13_Supp := false, pc_eBand14_Supp := false, pc_eBand17_Supp := false, pc_eBand18_Supp := false, pc_eBand19_Supp := false, pc_eBand1_Supp := false, pc_eBand20_Supp := false, pc_eBand21_Supp := false, pc_eBand2_Supp := false, pc_eBand33_Supp := false, pc_eBand34_Supp := false, pc_eBand35_Supp := false, pc_eBand36_Supp := false, pc_eBand37_Supp := false, pc_eBand38_Supp := false, pc_eBand39_Supp := false, pc_eBand3_Supp := false, pc_eBand40_Supp := false, pc_eBand41_Supp := false, pc_eBand42_Supp := false, pc_eBand43_Supp := false, pc_eBand4_Supp := false, pc_eBand5_Supp := false, pc_eBand6_Supp := false, pc_eBand7_Supp := false, pc_eBand8_Supp := false, pc_eBand9_Supp := false }
07:42:25.180924 - Module Parameters has the following parameters: { px_AccessPointName := <unbound>, px_AttachTypeTested := EPS_ATTACH_ONLY (0), px_AuthAMF := <unbound>, px_AuthK := '00000000000000010000001000000011000001000000010100000110000001110000100000001001000010100000101100001100000011010000111000001111'B, px_DelayBeforeIntraCellHO := 300, px_IMEI_Def := <unbound>, px_IMSI_Def := '001010123456063'H, px_IPv4_Address := <unbound>, px_IPv4_Address2 := <unbound>, px_IPv4_RemoteAddress := <unbound>, px_IPv4viaNAS_TestMode := false, px_IPv6_Address := <unbound>, px_IPv6_Address2 := <unbound>, px_IPv6_RemoteAddress := <unbound>, px_PTMSI_Def := 'C2345678'O, px_PTMSI_SigDef := 'AB1234'O, px_SMS_ChkMsgReceived := true, px_SMS_IndexOffset := 0, px_SMS_PrefMem1 := "SM", px_SMS_PrefMem2 := "SM", px_SMS_PrefMem3 := "MT", px_SMS_Service := "0", px_TMSI_Def := '12345678'O, px_eAuthRAND := '10100011110111100000110001101101001101100011111000110000110000110110010010100100000001111000111100011011111110001101010101110111'B, px_eJapanMCC_Band6 := '442'H, px_ePrimaryBandChannelBandwidth := n25 (2), px_ePrimaryFrequencyBand := 1, px_eSecondaryFrequencyBand := 2, pc_1xCSfallback := false, pc_1xRTT := false, pc_Allowed_CSG_list := false, pc_Attach := false, pc_Automatic_Re_Attach := false, pc_CS := false, pc_CS_Fallback := false, pc_CS_SMS_only := false, pc_Combined_Attach := false, pc_DSMIPv6 := false, pc_EMM_Information := false, pc_EPS_Disable := false, pc_ESM_MO_Bearer_Allocation := false, pc_ESM_MO_Bearer_Modification := false, pc_ETWS_message := false, pc_ETWS_message_security := false, pc_FDD := true, pc_FeatrGrp_1 := false, pc_FeatrGrp_10 := false, pc_FeatrGrp_11 := false, pc_FeatrGrp_12 := false, pc_FeatrGrp_13 := false, pc_FeatrGrp_14 := false, pc_FeatrGrp_15 := false, pc_FeatrGrp_16 := false, pc_FeatrGrp_17 := false, pc_FeatrGrp_18 := false, pc_FeatrGrp_19 := false, pc_FeatrGrp_2 := false, pc_FeatrGrp_20 := false, pc_FeatrGrp_21 := false, pc_FeatrGrp_22 := false, pc_FeatrGrp_23 := false, pc_FeatrGrp_24 := false, pc_FeatrGrp_25 := false, pc_FeatrGrp_26 := false, pc_FeatrGrp_27 := false, pc_FeatrGrp_3 := false, pc_FeatrGrp_4 := false, pc_FeatrGrp_5 := false, pc_FeatrGrp_6 := false, pc_FeatrGrp_7 := false, pc_FeatrGrp_8 := false, pc_FeatrGrp_9 := false, pc_FullNameNetwork := false, pc_GERAN := false, pc_GERAN_2_E_UTRAN_meas := false, pc_HO_from_UTRA := false, pc_HRPD := false, pc_IMS := false, pc_IMS_emergency_call := false, pc_IPv4 := true, pc_IPv6 := false, pc_ISR := false, pc_ImmConnect := false, pc_LocalTimeZone := false, pc_Multiple_PDN := false, pc_PS := true, pc_RequestIPv4HAAddress_DuringAttach := false, pc_RequestIPv6HAAddress_DuringAttach := false, pc_SMS_SGs_MO := false, pc_SMS_SGs_MT := false, pc_ShortNameNetwork := false, pc_Speech := false, pc_SupportOpModeA := false, pc_SwitchOnOff := true, pc_TDD_HCR := false, pc_TDD_LCR := false, pc_TDD_VHCR := false, pc_USIM_Rmv := false, pc_UTRA := false, pc_UTRA_CompressedModeRequired := false, pc_UTRA_FeatrGrp_1 := false, pc_UTRA_FeatrGrp_2 := false, pc_UniversalAndLocalTimeZone := false, pc_data_centric := false, pc_eFDD := false, pc_eTDD := false, pc_not_SMS_only := false, pc_ue_Category_1 := false, pc_ue_Category_2 := false, pc_ue_Category_3 := false, pc_ue_Category_4 := false, pc_ue_Category_5 := false, pc_voice_centric := false }
07:42:25.181117 - Module SRSLTE_RLC_Test has the following parameters: { mp_ue_ip := "127.0.0.1", mp_ue_ctrl_port := 4255 }
07:42:25.181170 - Initializing module CommonDefs.
07:42:25.181215 - Initialization of module CommonDefs finished.
07:42:25.181257 - Initializing module CommonIP.
07:42:25.181299 - Initialization of module CommonIP finished.
07:42:25.181341 - Initializing module CommonIratDefs.
07:42:25.181382 CommonIratDefs.ttcn:0 Initializing module NAS_AuxiliaryDefsAndFunctions.
07:42:25.181438 NAS_AuxiliaryDefsAndFunctions.ttcn:0 Initializing module NAS_CommonTemplates.
07:42:25.181485 NAS_CommonTemplates.ttcn:0 Initializing module NAS_CommonTypeDefs.
07:42:25.181532 NAS_CommonTemplates.ttcn:0 Initialization of module NAS_CommonTypeDefs finished.
07:42:25.181700 NAS_AuxiliaryDefsAndFunctions.ttcn:0 Initialization of module NAS_CommonTemplates finished.
07:42:25.181762 NAS_AuxiliaryDefsAndFunctions.ttcn:0 Initializing module Parameters.
07:42:25.181809 Parameters.ttcn:0 Initializing module EUTRA_CommonDefs.
07:42:25.181855 Parameters.ttcn:0 Initialization of module EUTRA_CommonDefs finished.
07:42:25.181900 NAS_AuxiliaryDefsAndFunctions.ttcn:0 Initialization of module Parameters finished.
07:42:25.181959 CommonDefs.ttcn:226 Dynamic test case error: Performing lengthof operation on an unbound charstring value.
07:42:25.182069 CommonDefs.ttcn:226 Performing error recovery.
07:42:25.182423 - Initialization of modules failed.
07:42:25.183197 - Exit was requested from MC. Terminating HC.
07:42:25.183478 - Disconnected from MC.
07:42:25.183542 - TTCN-3 Host Controller finished.
wherever you see <unbound>, there's an uninitialized module parameter, so first you have to give them some value in your configuration file ;
without that , the initialization will not be able to finish.
Two notes here:
-of course you know, but for completeness only:
your main module
module SRSLTE_RLC_Test
type component Empty_CT {
modulepar {
/* remote parameters of IUT */
charstring mp_ue_ip := "127.0.0.1";
integer mp_ue_ctrl_port := 4255;
// Dummy test case
testcase tc_dummy() runs on Empty_CT {
setverdict(pass);
control {
execute( tc_dummy() );
has no dependencies so it can be compiled and run on its' own
-the entire project is large-ish so it probably takes you (too ) a while to compile ;
to speed up compilation I recommend you regenerate your Makefile with the - U option, e.g.
and possibly use the gold linker,
see this post for details:
Compilation of big files
https://www.eclipse.org/forums/index.php/t/1085369/
Hope this will be of help
Best regards
Elemer
[Updated on: Fri, 16 March 2018 07:56] Report message to a moderator
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1783718 is a reply to message #1783709] |
Fri, 16 March 2018 09:28 |
Hi Andre,
a skeleton example for your config file could be:
[LOGGING]
#LogFile := "logs/%l/%e.%h-%t%r.%s"
FileMask := LOG_ALL | TTCN_ERROR | TTCN_USER | TTCN_PORTEVENT | TTCN_DEBUG
#| TTCN_MATCHING | TTCN_WARNING | TTCN_TESTCASE | TTCN_STATISTICS
ConsoleMask := TTCN_ERROR | TTCN_USER
#| TTCN_PORTEVENT
LogSourceInfo := Yes
[MODULE_PARAMETERS]
Parameters.px_IPv4_Address := "127.0.0.1"
[TESTPORT_PARAMETERS]
[MAIN_CONTROLLER]
TCPPort := 8035
KillTimer := 1.0
[EXECUTE]
SRSLTE_RLC_Test.control
BR
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1783768 is a reply to message #1783766] |
Fri, 16 March 2018 17:10 |
Hi Andre,
what's most likely happening here is that you are trying to send a message on a port that, although it is marked internal ,
it is mapped to the system so it is supposed to have a communication stack connected.
You should add a test port here (this is the upper tester so it connects to the SUT and it is supposed to trigger some messages from it)
and remove the internal markings.
BTW, I don't see much point in running this code before the missing parts have been added.
BR
Elemer
[Updated on: Fri, 16 March 2018 17:11] Report message to a moderator
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1784043 is a reply to message #1783773] |
Wed, 21 March 2018 21:34 |
Member |
Hi all,
in order to interface the EUTRA_PTC with my DUT I've created a dual-faced port that converts, for example, the SYSTEM_CTRL_REQ and SYSTEM_CTRL_CNF messages, and transmits/receives them over UDP using the IPL4 port. Part of the (incomplete) port definition is below. I am now wondering about the best way to implement the connect call, or to be precise, the best place to put the connect function? Since the EUTRA_IPL4_PT port is part of the EUTRA_PTC component, it should be called in one of the init function of the component, right? However, In most of the examples I've studied so far, connecting the port is done in the testcase directly, which in my case usually "runs on MTC system SYSTEM" and hence I cannot call the init from there. I guess it's an easy one but I don't seem to find a good and portable way to achieve this.
Andre
The UDP connect function that should be called on EUTRA_PTC.
function f_openConnection(in ConnectionParams pl_connectionParams, integer pl_connId)
runs on EUTRA_PTC return integer
var Socket_API_Definitions.Result vl_result;
vl_result := IPL4asp_User_CtrlFunct.f_IPL4_connect(SYS,
pl_connectionParams.remHost,
pl_connectionParams.remPort,
pl_connectionParams.locHost,
pl_connectionParams.locPort,
pl_connId, //pl_connectionParams.connId,
{udp := {}}
log(vl_result)
return(vl_result.connId)
And here the definition of the dual-faced port.
type port EUTRA_IPL4_PT message
out
SYSTEM_CTRL_REQ
in
SYSTEM_CTRL_CNF,
ASP_Event
}with
{ extension
"user IPL4asp_PT
out(
SYSTEM_CTRL_REQ -> ASP_Send: function(f_enc_SYSTEM_CTRL_REQ_DualFace)
in(
ASP_RecvFrom -> SYSTEM_CTRL_CNF : function(f_dec_SYSTEM_CTRL_CNF_DualFace);
ASP_Event -> ASP_Event : simple
//extension "address" - not possible with current Titan
function f_enc_SYSTEM_CTRL_REQ_DualFace
( in SYSTEM_CTRL_REQ pl_in,
out ASP_Send pl_out) return integer
pl_out.connId := -1;
pl_out.msg := 'AA'O;
pl_out.proto := omit;
return 0;
}with {extension "prototype(backtrack)" }
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1784085 is a reply to message #1784043] |
Thu, 22 March 2018 10:47 |
Hi Andre,
yes, in case your test case involves parallel components, the sensible thing to do is to create and start them from the MTC , then at the beginning of the function started on the component call f_openConnection ;
for UDP, mind, it's not really a connection, maybe "association" is the right word?
f_openConnection will return a connection Id that has to be reused when referring to the communication channel
This means that using "-1" for connection id e.g. here
return 0;
will not work( as you should use here the value returned by f_openConnection) , with the following exception:
If you expect to have only one UDP ( or TCP) channel along the duration of your test case, you can use the following simplification:
the connection can be controlled not only from f_openConnection, but directly from the map operation , meaning that when mapped, the port will open automatically a connection with parameters taken from the config file;
if , on top of that , lazy_conn_id_handling is set to yes (and only one comms channel in the system, which can be unequivocally referred to) ,
then the user does not have to care about the real value of the connection id , the dummy value -1 can be used instead.
This means that you can skip the f_openConnectionFunction but have to use in the config file something like:
*.portName.defaultListeningPort := "0"
*.portName.map_behavior := "connect"
*.portName.RemotePort := "666" // SUT - Port
*.portName.RemoteHost := "127.0.0.1" // SUT - IP
*.portName.lazy_conn_id_handling := "yes"
*.portName.debug := "yes" //or "no"
*.mccPort.map_protocol := "udp"
For obvious reasons this setup can handle one connection only ; with f_connect() , f_close() etc. , any number of connections can be opened or closed flexibly at any moment.
So this is an early design decision one will have to take.
Besides , the reasoning is not valid for listening ports , when the other side will open the connection and set the connection Id.
One more thing: dual-faced-ports will work just as fine, but you might have more flexibiilty and features eventually with the standard-compliant translation ports.
Hope this helps
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1785587 is a reply to message #1785533] |
Tue, 17 April 2018 08:19 |
Hi Andre,
I ftp-d the test cases:
esekilxxen1841 [8:31] [Andre/ttcn3_rlc/ue_testcases] -> wget ftp://ftp.3gpp.org/Specs/archive/36_series/36.523-3/36523-3-860.zip
--2018-04-17 08:32:06-- ftp://ftp.3gpp.org/Specs/archive/36_series/36.523-3/36523-3-860.zip
=> `36523-3-860.zip'
Resolving ftp.3gpp.org... 195.238.226.35
Connecting to ftp.3gpp.org|195.238.226.35|:21... connected.
Logging in as anonymous ... Logged in!
==> SYST ... done. ==> PWD ... done.
==> TYPE I ... done. ==> CWD /Specs/archive/36_series/36.523-3 ... done.
==> SIZE 36523-3-860.zip ... 2753747
==> PASV ... done. ==> RETR 36523-3-860.zip ... done.
Length: 2753747 (2.6M)
100%[==================================================================================================>] 2,753,747 1.60M/s in 1.6s
2018-04-17 08:32:08 (1.60 MB/s) - `36523-3-860.zip' saved [2753747]
applied the patch:
esekilxxen1841 [8:46] [Andre/ttcn3_rlc/ue_testcases] -> patch -p1 -i 3gpp_testcases.diff
patching file CommonEUTRA_Defs/EPS_NAS_MsgContainers.ttcn
patching file CommonEUTRA_Defs/EUTRA_ASP_DrbDefs.ttcn
patching file CommonEUTRA_Defs/EUTRA_ASP_NasCtrl.ttcn
patching file CommonEUTRA_Defs/EUTRA_ASP_SrbDefs.ttcn
patching file CommonEUTRA_Defs/EUTRA_ASP_TypeDefs.ttcn
patching file CommonUTRAN/UTRAN_CommonDefs.ttcn
patching file IP_PTC/DHCPv4_TypeDefs.ttcn
patching file IP_PTC/ICMPv6_TypeDefs.ttcn
patching file IP_PTC/IP_ASP_TypeDefs.ttcn
patching file IP_PTC/IP_PTC_CtrlMsgs.ttcn
patching file MTC/MTC_Component.ttcn
patching file MTC/MTC_Main.ttcn
patching file NasEmulation/NasEmu_AspTypes.ttcn
patching file common/CommonIratDefs.ttcn
patching file common/UpperTesterDefs.ttcn
created bin and started compilation with ../install.sh
First of all, the compiler tries to warn you if it estimates the translation port will not work as expected:
MTC_Main.ttcn:62.3-168.3: In function definition `f_MTC_ConnectPTCs':
MTC_Main.ttcn:76.5-27: In map statement:
MTC_Main.ttcn:76.5-27: note: This mapping is not done in translation mode, because the second endpoint is unknown
SRSLTE_RLC_Test.ttcn:59.3-80.3: In testcase definition `TC_7_2_2_1':
SRSLTE_RLC_Test.ttcn:71.5-27: In map statement:
SRSLTE_RLC_Test.ttcn:71.5-27: note: This mapping is not done in translation mode
( I am compiling with latest Titan from source, please make sure you do the same)
see https://www.eclipse.org/forums/index.php/t/1091899/
By default a translation port is mapped to the empty skeleton/direct port if the system clause, config file etc, are not consistent; in such a situation the compiler issues a note as it cannot be certain if this is intentional or not.
So please check this first.
I'm not sure what you mean by SYSTEM being nested in MTC, but it does not sound right.
The system component represents the system under test and it mirrors the ports of all the components, see figure;
Here you need to map MTC:portA to system:sysportA, PTC1:portB to system:sysportB etc.
The component ports are abstract ports , while the system ports are the matching physical ports .
For simple ports both component ports and system ports are of the same type (e.g. UDPasp_PT) and system component declaration can be forgotten (though I prefer to do it for clarity) as the compiler will assume it.
For translation ports the component ports are of one type,
in your case IPL4_MTC_System_Ut_PT
// Translation port to map between ETSI messages and IUT
type port IPL4_MTC_System_Ut_PT message map to IPL4asp_PT //translation port
out
UT_SYSTEM_REQ to ASP_Send with f_enc_UT_SYSTEM_REQ_translation()
in
UT_COMMON_CNF from ASP_RecvFrom with f_dec_UT_COMMON_CNF_translation(),
ASP_Event
and system ports are of the type to which the upper port is mapped
(in your case IPL4asp_PT)
and declaring a system component is compulsory else translation will not work (the port will bind to an empty internal skeleton)
Also every function, test case etc. which refers to mapping the translation ports will have to have the right 'runs on' and 'system' clause, or , again, translation will not work.
I know the translation ports are a bit fussy, but they offer the huge advantage of reusing a lower layer port for higher level protocols.
I hope this made it a bit clearer.
Best regards
Elemer
Attachment: system.png
(Size: 16.27KB, Downloaded 1433 times)
[Updated on: Tue, 17 April 2018 13:27] Report message to a moderator
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1785854 is a reply to message #1785852] |
Fri, 20 April 2018 16:33 |
Hi Andre,
the translation ports have their own separate variable space, disjunct from the variable space of the components, so a small trick is needed to smuggle the connId value into that ; please check this post:
https://www.eclipse.org/forums/index.php/t/1092290/
I'll refer to that below.
First , you add integer to the out message list of the translation port and a port variable in which you can store the connection ID:
type port HTTP2Port message map to IPL4asp_PT {
out HTTP2_Frames to ASP_Send with f_enc_HTTP2_Frames_to_ASPSend(),
octetstring to ASP_Send with f_enc_octetstring_to_ASPSend(),
integer to ASP_Send with f_set_connId() <------------------------------------
in HTTP2_Frame from ASP_RecvFrom with f_dec_ASPRecvFrom_to_HTTP2_Frame(),
ASP_Event from ASP_Event with f_discardASPEvent()
var HTTP2_Frame v_HTTP2_Frame;
var integer v_cid; <------------------------------------
var HTTP2_decoder_error_descr v_err;
} with {extension "internal" }
the translation function associated with the integer type will store the connection Id passed as an incoming parameter , and will produce no output:
function f_set_connId(in integer p_in, out ASP_Send p_out) port HTTP2Port
v_cid:=p_in; //save connection Id
port.setstate(4); //discard output
}with {extension "prototype(fast)"}
Now all that needs to be done is to send the connection Id as a message to the port
after calling f_IPL4_connect:
vl_result :=IPL4asp_User_CtrlFunct.f_IPL4_connect( http2_port, tsp_hostname, 50050,"",0, -1, {tcp := {} }, {} );
log("connect result",vl_result)
if (not(ispresent(vl_result.connId))) { log("Could not connect"); stop; }
v_cid:=vl_result.connId ;
http2_port.send(v_cid);// send connId to the port
After this, protocol messages can be translated.
Also, we have added statefulness as a non-standard extension to the translation port ( subject of a future post)
which means that the whole state machine can be resolved by translation;
In this case one may want to invoke f_IPL4_connect from within the translation port and track the connection Id (or Ids) with port variables.
I hope this helps
Best regards
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1785985 is a reply to message #1785933] |
Mon, 23 April 2018 20:06 |
Member |
Hi again,
I am currently in the process of converting all the system ports defined in MTC_Component.ttcn that are not UTRAN, GERAN, CDMA2K into translation ports to connect to the DUT over TCP. I started with the Ut port (MTC_System_Ut) which works fine up to the point where I transmit the first JSON converted message (POWER_OFF) to the DUT and receive the JSON encoded result from the UE. For some reason, however, after receiving the confirmation from the DUT the E_Ut port is closed unexpectedly and the whole test is stopped (see long log below).
On the console I am also getting a Dynamic test case error: Message cannot be sent to system on internal port SYS. which may or may not be the cause for the error. Unfortunately, I couldn't really find where this transmission on port SYS is made but my question is if it is a) the shutdown is really related to that error and b) if I definitely need to have all translation ports in place or if I can somehow develop with a more incremental approach and use internal ports until I really need the functionality on the DUT side without breaking something?
Andre
21:52:17.264716 - TTCN-3 Main Test Component started on andre-xps13. Version: CRL 113 200/6 R4A.
21:52:17.264775 - TTCN Logger v2.2 options: TimeStampFormat:=Time; LogEntityName:=No; LogEventTypes:=No; SourceInfoFormat:=Stack; *.FileMask:=LOG_ALL; *.ConsoleMask:=ERROR | TESTCASE | STATISTICS_VERDICT | STATISTICS_UNQUALIFIED; LogFileSize:=0; LogFileNumber:=1; DiskFullAction:=Error
21:52:17.264839 - Connected to MC.
21:52:17.265098 - Executing control part of module SRSLTE_RLC_Test.
21:52:17.265188 SRSLTE_RLC_Test.ttcn:121 Execution of control part in module SRSLTE_RLC_Test started.
21:52:17.265224 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:97 Test case TC_7_2_2_1 started.
21:52:17.265254 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:97 Initializing variables, timers and ports of component type MTC_Component.MTC inside testcase TC_7_2_2_1.
21:52:17.265286 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:97 Port Ut was started.
21:52:17.265304 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:97 Port E_Ut was started.
21:52:17.265313 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:97 Port U_Ut was started.
21:52:17.265321 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:97 Port G_Ut was started.
21:52:17.265329 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:97 Port CDMA2000_Ut was started.
21:52:17.265337 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:97 Component type MTC_Component.MTC was initialized.
21:52:17.265346 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:100 Creating new alive PTC with component type EUTRA_Component.EUTRA_PTC.
21:52:17.265843 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:100 PTC was created. Component reference: 3, alive: yes, type: EUTRA_Component.EUTRA_PTC.
21:52:17.265860 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:107->MTC_Main.ttcn:40 Connecting to DUT
21:52:17.265876 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:77 Port Ut was started.
21:52:17.265885 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:77 Mapping port mtc:Ut to system:Ut.
21:52:17.265919 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:77 Port Ut was mapped to system:Ut.
21:52:17.265943 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:77 Port Ut was mapped to system:Ut.
21:52:17.265983 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:77 Map operation of mtc:Ut to system:Ut finished.
21:52:17.266007 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:85 Creating new alive PTC with component type NasEmu_Component.NASEMU_PTC.
21:52:17.266394 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:85 PTC was created. Component reference: 4, alive: yes, type: NasEmu_Component.NASEMU_PTC.
21:52:17.266408 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:90 Connecting ports 3:UT and mtc:E_Ut.
21:52:17.266507 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:90 Port E_Ut is waiting for connection from 3:UT on UNIX pathname /tmp/ttcn3-portconn-c2bf511.
21:52:17.266566 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:90 Port E_Ut has accepted the connection from 3:UT.
21:52:17.266583 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:90 Connect operation on 3:UT and mtc:E_Ut finished.
21:52:17.266594 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:93 Connecting ports 3:NASCTRL and 4:CTRL.
21:52:17.266704 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:93 Connect operation on 3:NASCTRL and 4:CTRL finished.
21:52:17.266717 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:94 Connecting ports 3:SRB and 4:TC_SRB.
21:52:17.266822 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:94 Connect operation on 3:SRB and 4:TC_SRB finished.
21:52:17.266833 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:97 Mapping port 3:SYS to system:E_SYS.
21:52:17.266882 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:97 Map operation of 3:SYS to system:E_SYS finished.
21:52:17.266896 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:108 Starting function f_NASEMU_MainLoop(false) on component 4.
21:52:17.266934 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:108 Function was started.
21:52:17.266950 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:45 Creating new alive PTC with component type IP_PTC_Component.IP_PTC.
21:52:17.267336 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:45 PTC was created. Component reference: 5, alive: yes, type: IP_PTC_Component.IP_PTC.
21:52:17.267356 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:48 Connecting ports 3:IP and 5:EUTRA_CTRL.
21:52:17.267485 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:48 Connect operation on 3:IP and 5:EUTRA_CTRL finished.
21:52:17.267501 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:57 Mapping port 5:IP_CTRL to system:IP_CTRL.
21:52:17.267554 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:57 Map operation of 5:IP_CTRL to system:IP_CTRL finished.
21:52:17.267565 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:58 Mapping port 5:IP_SOCK to system:IP_SOCK.
21:52:17.267612 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:58 Map operation of 5:IP_SOCK to system:IP_SOCK finished.
21:52:17.267627 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:60 Starting function f_IP_PTC_MainLoop() on component 5.
21:52:17.267657 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:109->MTC_Main.ttcn:172->MTC_Main.ttcn:60 Function was started.
21:52:17.267744 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:111->SRSLTE_RLC_Test.ttcn:54 { errorCode := omit, connId := 1, os_error_code := omit, os_error_text := omit }
21:52:17.267771 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:111->SRSLTE_RLC_Test.ttcn:61 Sent on Ut to system integer : 1
21:52:17.267783 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:111->SRSLTE_RLC_Test.ttcn:61 The state of the Ut port was changed by a setstate operation to unset. Information: by test environment.
21:52:17.267795 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:111->SRSLTE_RLC_Test.ttcn:61->IPL4_MTC_SYSTEM_Ut_Definitions.ttcn:47 The state of the Ut port was changed by a setstate operation to discarded.
21:52:17.267808 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:115 Starting function f_TC_7_2_2_1_EUTRA() on component 3.
21:52:17.267841 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:115 Function was started.
21:52:17.267851 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:116 Start timer t_GuardTimer: 5 s
21:52:17.267893 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:361 Sent on Ut to system @UpperTesterDefs.UT_SYSTEM_REQ : { Cmd := { MMI := { Cmd := "POWER_OFF", ParameterList := omit } }, CnfRequired := true }
21:52:17.267905 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:361 The state of the Ut port was changed by a setstate operation to unset. Information: by test environment.
21:52:17.267917 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:361->IPL4_MTC_SYSTEM_Ut_Definitions.ttcn:23 f_enc_UT_SYSTEM_REQ_translation
21:52:17.267936 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:361->IPL4_MTC_SYSTEM_Ut_Definitions.ttcn:28 The state of the Ut port was changed by a setstate operation to translated.
21:52:17.267954 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:361 Outgoing message was mapped to @IPL4asp_Types.ASP_Send : { connId := 1, proto := omit, msg := '7B22436D64223A7B224D4D49223A7B22436D64223A22504F5745525F4F4646227D7D2C22436E665265717569726564223A747275657D'O ("{\"Cmd\":{\"MMI\":{\"Cmd\":\"POWER_OFF\"}},\"CnfRequired\":true}") }
21:52:17.268068 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:362 Message enqueued on Ut from system @IPL4asp_Types.ASP_RecvFrom : { connId := 1, remName := "127.0.0.1", remPort := 2222, locName := "127.0.0.1", locPort := 2223, proto := { tcp := { } }, userData := 0, msg := '7B22526573756C74223A747275657D'O ("{\"Result\":true}") } id 1
21:52:17.268118 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:362 The state of the Ut port was changed by a setstate operation to unset. Information: by test environment.
21:52:17.268152 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:362->IPL4_MTC_SYSTEM_Ut_Definitions.ttcn:34 f_dec_UT_COMMON_CNF_translation
21:52:17.268184 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:362->IPL4_MTC_SYSTEM_Ut_Definitions.ttcn:41 The state of the Ut port was changed by a setstate operation to translated.
21:52:17.268216 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:362 Incoming message was mapped to @UpperTesterDefs.UT_COMMON_CNF : { Result := true, ResultString := omit } id 1
21:52:17.268249 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:362 Receive operation on port Ut succeeded, message from system(): @UpperTesterDefs.UT_COMMON_CNF : { Result := true, ResultString := omit } id 1
21:52:17.268280 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:230->MTC_UpperTester.ttcn:362 Message with id 1 was extracted from the queue of Ut.
21:52:17.268311 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:232 power off over
21:52:17.272609 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:236 Connection of port E_Ut to 3:UT was closed unexpectedly by the peer.
21:52:17.272631 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:236 Port E_Ut was disconnected from 3:UT.
21:52:17.272661 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:237->MTC_Main.ttcn:193 any component.killed
21:52:17.272672 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:237->MTC_Main.ttcn:194 Killing all components.
21:52:17.273090 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:237->MTC_Main.ttcn:194 All components were killed.
21:52:17.273109 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118->MTC_Main.ttcn:237->MTC_Main.ttcn:195 Stopping test component execution.
21:52:17.273246 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Test case TC_7_2_2_1 was stopped.
21:52:17.273262 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Terminating component type MTC_Component.MTC.
21:52:17.273275 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Removing unterminated mapping between port Ut and system:Ut.
21:52:17.273289 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Port Ut was unmapped from system:Ut.
21:52:17.273388 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Port Ut was stopped.
21:52:17.273403 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Port E_Ut was stopped.
21:52:17.273413 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Port U_Ut was stopped.
21:52:17.273422 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Port G_Ut was stopped.
21:52:17.273432 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Port CDMA2000_Ut was stopped.
21:52:17.273441 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Removing unterminated mapping between port Ut and system:Ut.
21:52:17.273471 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Port Ut was unmapped from system:Ut.
21:52:17.273489 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Port Ut was stopped.
21:52:17.273500 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Component type MTC_Component.MTC was shut down inside testcase TC_7_2_2_1.
21:52:17.273511 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Waiting for PTCs to finish.
21:52:17.273553 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Setting final verdict of the test case.
21:52:17.273572 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Local verdict of MTC: none
21:52:17.273585 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Local verdict of PTC with component reference 3: error (none -> error)
21:52:17.273595 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Local verdict of PTC with component reference 4: none (error -> error)
21:52:17.273605 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Local verdict of PTC with component reference 5: none (error -> error)
21:52:17.273617 SRSLTE_RLC_Test.ttcn:125->SRSLTE_RLC_Test.ttcn:118 Test case TC_7_2_2_1 finished. Verdict: error
21:52:17.273637 SRSLTE_RLC_Test.ttcn:125 Execution of control part in module SRSLTE_RLC_Test finished.
21:52:17.274682 - Verdict statistics: 0 none (0.00 %), 0 pass (0.00 %), 0 inconc (0.00 %), 0 fail (0.00 %), 1 error (100.00 %).
21:52:17.274785 - Test execution summary: 1 test case was executed. Overall verdict: error
21:52:17.274823 - Exit was requested from MC. Terminating MTC.
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1786041 is a reply to message #1785985] |
Tue, 24 April 2018 16:10 |
Member |
please ignore my somewhat messy previous post. But I've now converted all system ports into translation ports but am facing an issue in configuring them again. I am unsure how and especially where to call the openConnection for the IPL4 port. The port that is working so far (IPL4_MTC_System_Ut) has the "runs on MTC system SYSTEM" flag and I can call the connect function from within the testcase definition. All other ports, however, like the SYS, SYSIND, etc are either on the EUTRA_PTC, on the NASEMU_PTC or on the IP_PTC. So I can't directly execute function on those PTCs from the testcase. What's best practice here to achieve the configuration? Earlier it was mentioned that in order for the translation ports to work it is essential to have the "system SYSTEM" clause in place as well which isn't the case for any of the PTCs, so would I need to define that for those?
Andre
Update:
Just updated the public repo to better replicate the issue.
[Updated on: Tue, 24 April 2018 16:19] Report message to a moderator
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1786063 is a reply to message #1786041] |
Wed, 25 April 2018 06:00 |
Hi Andre,
If you have only one connection/association per port at one time, which I think might be your case , then you might not need to use the f_IPL4_connect ;
Let me repeat an earlier entry:
In this case, connect is called implicitly when the port is mapped.
So maybe this is the way to go in your case. Try it with one port first to see how it works.
Otherwise you will have to add f_IPL4_connect to the appropriate sections of the functions running on PTC's which might force you to re-edit the code
-which is coming from elsewhere -anytime it changes.
Please let me now if this helps.
Best regards
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1786154 is a reply to message #1786063] |
Thu, 26 April 2018 08:39 |
Member |
Hi Elemer,
yes, you are right, I think one association per port at a time is enough in my case which allows me to use the lazy connection handling. I actually tried that before but now looking at the logs again, I don't think that's the main issue I am having currently. Because in theory, even without the port being connected, I should see the log entry I put in the translation port sending function, i.e. f_enc_SYSTEM_CTRL_REQ_translation(), which I don't. I see the message being sent on the port but the translation port is never called to transmit it. And I think the reason is that another component isn't started up correctly and hence the entire execution is stopped. I've attached the entire logs of the execution but here is the snippet that I think causes the issue. Unfortunately, it doesn't tell much about what is actually going wrong. I also put various log calls before and after the functions that are mentioned in the log below but they don't seem to appear in the log after all. Any idea what might be wrong here in the NasEmu or IP_PTC?
10:28:29.801531 - Port IP_CTRL was mapped to system:IP_CTRL.
10:28:29.801592 - Port IP_SOCK was mapped to system:IP_SOCK.
10:28:29.801657 - Starting function f_IP_PTC_MainLoop().
10:28:29.801664 IP_PTC_Main.ttcn:288 f_IP_PTC_Ma10:28:34.803912 NasEmu.ttcn:685 Stop was requested from MC.
10:28:34.804070 NasEmu.ttcn:685 Stopping test component execution.
10:28:34.804857 - Function f_NASEMU_MainLoop was stopped. PTC remains alive and is waiting for next start.
Andre
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1786175 is a reply to message #1786171] |
Thu, 26 April 2018 13:26 |
Hi Andre,
it's visible form the log that connect on map does not happen:
14:27:48.536840 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: debug, value: yes)
14:27:48.536851 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: map_protocol, value: tcp)
14:27:48.536857 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: defaultListeningPort, value: 0)
14:27:48.536861 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: map_behavior, value: connect)
14:27:48.536866 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: RemotePort, value: 2222)
14:27:48.536871 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: RemoteHost, value: 127.0.0.1)
14:27:48.536876 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: lazy_conn_id_handling, value: yes)
14:27:48.536881 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: debug, value: yes)
14:27:48.536885 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: debug, value: yes)
14:27:48.536889 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::set_parameter: enter (name: map_protocol, value: tcp)
14:27:48.536895 MTC_Main.ttcn:96 Ut: IPL4asp__PT_PROVIDER::user_map(Ut): enter
14:27:48.536899 MTC_Main.ttcn:96 Port Ut was mapped to system:Ut.
You should see something like:
2018/Apr/17 13:43:00.347519 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::set_parameter: enter (name: debug, value: yes)
2018/Apr/17 13:43:00.347538 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::set_parameter: enter (name: map_protocol, value: tcp)
2018/Apr/17 13:43:00.347552 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::set_parameter: enter (name: map_protocol, value: tcp)
2018/Apr/17 13:43:00.347569 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::user_map(mcaPort): enter
2018/Apr/17 13:43:00.347627 PORTEVENT OneM2M_Functions.ttcn:37(function:f_cf01Up) entering f__IPL4__PROVIDER__connect: :0 -> 203.253.128.161:7579 / TCP
2018/Apr/17 13:43:00.347656 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: enter
2018/Apr/17 13:43:00.347705 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: create new socket: :0 -> 203.253.128.161:7579
2018/Apr/17 13:43:00.347724 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: SetLocalSockAddr: locName: loc_port 0 def_loc_host 0.0.0.0, add_family AF_INET
2018/Apr/17 13:43:00.347738 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: use default host: 0.0.0.0:0
2018/Apr/17 13:43:00.347765 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::setOptions: enter, number of options: 0
2018/Apr/17 13:43:00.347779 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::setOptions: sock: 7
2018/Apr/17 13:43:00.347799 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::setOptions: Socket option REUSEADDR on socket 7 is set to: 1
2018/Apr/17 13:43:00.347813 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::setOptions: leave
2018/Apr/17 13:43:00.347835 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: sock: 7
2018/Apr/17 13:43:00.347909 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: error: Operation now in progress
2018/Apr/17 13:43:00.347931 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER: ConnAdd enter: type: 2, ssl_tls_type: 0, sock: 7, parentIx: -1
2018/Apr/17 13:43:00.347953 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::ConnAdd: new sockListSize: 16
2018/Apr/17 13:43:00.347979 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::ConnAdd: connId: 1
2018/Apr/17 13:43:00.348006 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::ConnAdd: connId: set ssl options for connId : 1
2018/Apr/17 13:43:00.348025 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::set_ssl_supp_option: set SSL options
2018/Apr/17 13:43:00.348079 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::ConnAdd: getpeername failed: Transport endpoint is not connected
2018/Apr/17 13:43:00.348104 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: IPL4asp__PT_PROVIDER::ConnAdd: leave: sockListCnt: 1
2018/Apr/17 13:43:00.348119 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: EAGAIN: waiting in poll: fd 7 connId: 1
2018/Apr/17 13:43:00.660474 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: EAGAIN: poll returned: 1
2018/Apr/17 13:43:00.660548 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: EAGAIN: revents: 0x0004
2018/Apr/17 13:43:00.660564 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: EAGAIN: writable
2018/Apr/17 13:43:00.660594 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: Probing connection: getsockopt returned: 0, connection result code: 0
2018/Apr/17 13:43:00.660610 DEBUG OneM2M_Functions.ttcn:37(function:f_cf01Up) mcaPort: f__IPL4__PROVIDER__connect: leave
2018/Apr/17 13:43:00.660631 PORTEVENT OneM2M_Functions.ttcn:37(function:f_cf01Up) Port mcaPort was mapped to system:mcaPort.
as taken from a similar log;
now, as discussed before, all functions, testcases etc. where mapping is done must have appropriate runs on and system clauses,
so I'm suspecting that the missing system clause of
function f_MTC_ConnectPTCs(EUTRA_PTC p_Eutra,
UTRAN_PTC p_Utran,
GERAN_PTC p_Geran,
CDMA2000_PTC p_Cdma2000) runs on MTC
could be the reason of the problem
Could you please test this hypothesis?
BR
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1786186 is a reply to message #1786182] |
Thu, 26 April 2018 15:05 |
Hi Andre,
it appears that for some reason you are using an old version of IPL4 test port
R18N
// Prodnr: CNL 113 531
// Updated: 2013-08-27
the current version being R30A;
This old version does not support connect on map.
could you try to update please?
Also the Socket-API and AbstractSocket while you are at it.
BR
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1786227 is a reply to message #1786204] |
Fri, 27 April 2018 07:51 |
Hi Andre,
if I'm not mistaken ,
mapping of 3:SYS to system:E_SYS is done in
function f_MTC_ConnectDUT(EUTRA_PTC p_Eutra) runs on MTC
log("Connecting to DUT");
vc_Components.Eutra := p_Eutra;
map(vc_Components.Eutra:SYS, system:E_SYS);
map(vc_Components.Eutra:SYSIND, system:E_SYSIND);
map(vc_Components.Eutra:DRB, system:E_DRB);
//map(v_NASEMU_PTC:SYS_SRB, system:E_SRB);
as seen in the log
22:26:43.280991 MTC_Main.ttcn:40 Connecting to DUT
22:26:43.281000 MTC_Main.ttcn:44 Mapping port 3:SYS to system:E_SYS.
22:26:43.281066 MTC_Main.ttcn:44 Map operation of 3:SYS to system:E_SYS finished.
22:26:43.281082 MTC_Main.ttcn:45 Mapping port 3:SYSIND to system:E_SYSIND.
22:26:43.281137 MTC_Main.ttcn:45 Map operation of 3:SYSIND to system:E_SYSIND finished.
22:26:43.281152 MTC_Main.ttcn:46 Mapping port 3:DRB to system:E_DRB.
22:26:43.281206 MTC_Main.ttcn:46 Map operation of 3:DRB to system:E_DRB finished.
22:26:43.281225 SRSLTE_RLC_Test.ttcn:67 Starting function f_TC_7_2_2_1_EUTRA() on component 3.
and I see no system clause for f_MTC_ConnectDUT ;
where am I wrong here?
BR
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1786229 is a reply to message #1786228] |
Fri, 27 April 2018 08:56 |
Hi Andre,
probably yes, but please have in mind that this translation function in Titan , besides being a quite complex one, is relatively new and untested in real-life usage ; we are working on refining it though.
Hence we appreciate all feedback we get from users.
Best regards
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1786740 is a reply to message #1786719] |
Thu, 10 May 2018 12:09 |
Hi Andre,
not sure I understand all the subtext, but why not create a new record type say
type record Composite
universal charstring json,
octetstring per
which can carry both representations and then send that across the port. If the port is between components ,
this is straightforward, the structure can be sent as is, if it's external , a simple binary encoding can be applied .
Does this make sense?
BR
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1786762 is a reply to message #1786745] |
Thu, 10 May 2018 18:51 |
Hi Andre,
to ease the job of the RAW codec, you can add length info as below:
integer jsonLength,
integer perLength,
octetstring per
so it's like a (Type)LengthValue protocol; the length info can be filled in by the RAW codec automatically at encoding
and at decoding it helps to find the boundaries between fields.
BR
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1787235 is a reply to message #1787178] |
Tue, 22 May 2018 15:27 |
Hi Andre,
regarding the RAW codec:
the problem arises from the optional fields:
it's impossible to tell when an optional field has been omitted; to deal with that, you need to add another field (for each optional field ) that indicates
presence or absence.
However, this should work :
MsgElement json,
MsgElement tb1,
MsgElement tb2,
MsgElement tb3
} with {
variant "";
I don't think invoking external PER changed ; can you give me an example?
if you invoke it explicitly , declaring the external function , than you can decide to declare it (and define it ) with octetstrings or bitstrings.
if you invoke it implicitly, via encvalue/decvalue, then only bitstring can be used, but that did not change.
BR
Elemer
Re: Encoding function for 3GPP RLC/PDCP PDUs [message #1787615 is a reply to message #1787567] |
Wed, 30 May 2018 06:14 |
Hi Andre,
sorry , I was mistaken; indeed, external functions for PER have to be declared with bitstring input/output:
external function fx_enc_CAM (in CAM pdu) return bitstring
with {extension "prototype(convert) encode(PER)"}
however you can declare a wrapper to use octetstring instead:
function my_own_fx_enc_CAM(in CAM pdu ) return octetstring
return bit2oct(fx_enc_CAM(pdu))
and use that.
I hope this helps
BR
Elemer
[Updated on: Wed, 30 May 2018 06:14] Report message to a moderator
Current Time: Fri Apr 26 22:14:13 GMT 2024
Powered by FUDForum. Page generated in 0.08727 seconds
