problem saving a diagram after assigning a stereotype [message #1783280] |
Sat, 10 March 2018 16:45 |
Rolf Schumacher Messages: 60 Registered: January 2014 |
Member |
Very often after assignment of a stereotype to a component I am not able to save the component diagram.
It happens in a first example project that I am preparing.
I can repeat the problem with any new Papyrus project:
I created a very simple profile.
Restart Eclipse - just to be sure the profile is known.
I create a new Papyrus project, add a component diagram put a component on there. Still able to save the diagram.
Now when I try to assign a stereotype to that component, but miss it, because I click only one time instead of double-click, and try to save, I get the message: "Save Failed
Path must include project and resource name: /<the projects name>/"
I googled, saw that this happened before, but did not find any numbered issue, solution, or workaround.
My workaround was, to save the diagram as a picture, restart Eclipse and repeat the changes. Attached you may find the profile and a simple application together with a screenshot of the failure message.
I am using Oxygen 2, updated today, on Debian Jessie (LMDE 2) and Java-9.
Any other idea to cope with this problem?
[Updated on: Sun, 11 March 2018 21:08] Report message to a moderator
Re: problem saving a diagram after assigning a stereotype [message #1848675 is a reply to message #1790232] |
Mon, 13 December 2021 17:19 |
John McCabe Messages: 228 Registered: July 2009 |
Does anyone know if a bug report was ever filed for this? I've just had it with the 2021-09 download of Papyrus on Windows 10 after:
1. Adding an interface into a class diagram
2. Selecting the interface, right click and select "Profiles" -> "Update profiles..."
3. Move "Class" from left to right
4. Remove "Interface" from right
5. Click on OK.
6. Delete the interface as the stuff above didn't do what I'd hoped.
Ctrl-S after that gives the path error.
The stack trace is:
java.lang.IllegalArgumentException: Path must include project and resource name: /EMAControllerStuffUML/
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:66)
at org.eclipse.core.internal.resources.Workspace.newResource(Workspace.java:2143)
at org.eclipse.core.internal.resources.Container.getFile(Container.java:196)
at org.eclipse.papyrus.infra.ui.internal.emf.readonly.handlers.FSReadOnlyHandler.getIFile(FSReadOnlyHandler.java:101)
at org.eclipse.papyrus.infra.ui.internal.emf.readonly.handlers.FSReadOnlyHandler.computeAnyReadOnly(FSReadOnlyHandler.java:83)
at org.eclipse.papyrus.infra.ui.internal.emf.readonly.handlers.FSReadOnlyHandler.anyReadOnly(FSReadOnlyHandler.java:65)
at org.eclipse.papyrus.infra.emf.readonly.ReadOnlyManager.anyReadOnly(ReadOnlyManager.java:275)
at org.eclipse.papyrus.infra.emf.readonly.ReadOnlyManager.anyReadOnly(ReadOnlyManager.java:256)
at org.eclipse.papyrus.infra.core.resource.ModelSet.save(ModelSet.java:738)
at org.eclipse.papyrus.infra.ui.lifecycleevents.SaveAndDirtyService.doSave(SaveAndDirtyService.java:289)
at org.eclipse.papyrus.infra.ui.editor.CoreMultiDiagramEditor.doSave(CoreMultiDiagramEditor.java:1040)
at org.eclipse.ui.internal.SaveableHelper.lambda$0(SaveableHelper.java:156)
at org.eclipse.ui.internal.SaveableHelper.lambda$3(SaveableHelper.java:271)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:434)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:352)
at org.eclipse.ui.internal.WorkbenchWindow.lambda$7(WorkbenchWindow.java:2345)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:74)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2343)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:278)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:260)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelper.java:160)
at org.eclipse.ui.internal.WorkbenchPage.saveSaveable(WorkbenchPage.java:3820)
at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPage.java:3833)
at org.eclipse.ui.internal.handlers.SaveHandler.execute(SaveHandler.java:82)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:283)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:97)
at jdk.internal.reflect.GeneratedMethodAccessor114.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:317)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:251)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:488)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:308)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:580)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:647)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:439)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:96)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1270)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1059)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1084)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1069)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1111)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1107)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1536)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4875)
at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:345)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4753)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4958)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(Native Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3624)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1041)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
[Updated on: Mon, 13 December 2021 17:19] Report message to a moderator
Re: problem saving a diagram after assigning a stereotype [message #1849132 is a reply to message #1848675] |
Wed, 05 January 2022 08:28 |
I can reproduce getting an exception during saving, even if I get a different error in the log and my testmodel is apparently saved (with Papyrus 6.0 / Eclipse 2021-12). It only happens, If I say "yes" when a dialog pops up that requires write request to additional resources. As the command only makes sense for profiles, it shouldn't appear in the context menu of a normal class diagram.
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Resource '/tests/bugs/BugSave' already exists.
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl$PlatformResourceOutputStream.flush(PlatformResourceURIHandlerImpl.java:143)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl$PlatformResourceOutputStream.close(PlatformResourceURIHandlerImpl.java:91)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl$WorkbenchHelper$
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource '/tests/bugs/BugSave' already exists.
at org.eclipse.core.internal.resources.Resource.checkDoesNotExist(Resource.java:309)
at org.eclipse.core.internal.resources.Resource.checkDoesNotExist(Resource.java:296)
at org.eclipse.core.internal.resources.File.create(File.java:107)
at org.eclipse.core.internal.resources.File.create(File.java:179)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl$PlatformResourceOutputStream.flush(PlatformResourceURIHandlerImpl.java:130)
... 78 more
FUDForum. Page generated in 0.04147 seconds
