Home » Modeling » Papyrus » Reading .emx model file(Error during file parsing)
Reading .emx model file [message #1782313] |
Wed, 21 February 2018 16:10 |
Dmitrii Nikeshkin Messages: 28 Registered: February 2018 |
I am trying to read .emx model file that contains RSA-RTE model with PingPong example, by doing:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("emx", new XMIResourceFactoryImpl());
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/uml2/3.0.0/UML", UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put("http://www.ibm.com/xtools/1.5.3/Umlnotation", UmlnotationPackage.eINSTANCE);
resourceSet.getPackageRegistry().put("http:///schemas/Default/_fNm3AAqoEd6-N_NOT9vsCA/2", DefaultPackage.eINSTANCE);
resourceSet.getPackageRegistry().put("http:///schemas/UMLRealTime/_3TUzoHq6Ed2hSeAAWZznoA/119", UMLRealTimePackage.eINSTANCE);
Resource resource = resourceSet.getResource(modelFileURI, true);
And I get the following error:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'assembly' is not legal. (file:/C:/Users/qdni/Desktop/PingPong.emx, 530, 105)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at RSAModelParser.main(RSAModelParser.java:93)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'assembly' is not legal. (file:/C:/Users/qdni/Desktop/PingPong.emx, 530, 105)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2697)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2751)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:79)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2229)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFeatureType(XMLHandler.java:2195)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2071)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:151)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1876)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1030)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:82)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:190)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1359)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2784)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 2 more
Caused by: java.lang.IllegalArgumentException: The feature 'kind' is not a valid changeable feature
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenSet(BasicEObjectImpl.java:1141)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(BasicEObjectImpl.java:1119)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(BasicEObjectImpl.java:1112)
at org.eclipse.uml2.uml.internal.impl.ConnectorImpl.eSet(ConnectorImpl.java:519)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1156)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2692)
... 31 more
Any ideas how to fix this problem? Emx model is correct. Here in the attachment you can find the model. Thanks!
Attachment: PingPong.emx
(Size: 59.20KB, Downloaded 211 times)
[Updated on: Wed, 21 February 2018 16:11] Report message to a moderator
Re: Reading .emx model file [message #1782350 is a reply to message #1782346] |
Thu, 22 February 2018 09:51 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Hi Dmitrii,
The plug-in probably wouldn't be immediately compatible with IntelliJ, as it contains some eclipse extensions. However, it might be a good starting point to see how we achieved this in Papyrus
You can find the sources here: https://git.eclipse.org/c/gerrit/papyrus/org.eclipse.papyrus-interoperability.git/tree/rsa/plugins/org.eclipse.papyrus.interoperability.rsa
You can also install it in Eclipse via the following update site: http://download.eclipse.org/modeling/mdt/papyrus/interoperability/rsa
As mentioned earlier, this plug-in covers several aspects required for importing RSA-RTE models in Papyrus. The first step was to be able to read the *.emx models, which is achieved via custom Ecore metamodels and adding specific content-types, so that Eclipse/UML2 can recognize these models as UML2.3 models (And migrate them to UML2.5). This is probably the part that you'd want to reuse.
So you'd need:
- The ecore metamodels used to understand what's inside an *.emx file: all *.ecore models in the /model/ folder
- The nsURI declarations to map these Ecore models to the RSA nsURIs: this is done in plugin.xml via Eclipse Extension Points, so you'll need something equivalent in plain-Java
- The content type declarations, so UML can detect that *.emx files are actually UML2.3 models (Older versions of UML need to be opened with special handlers, because they are not 100% compatible with UML 2.5). Once again, this is done in the plugin.xml, so you'll need to redeclare this in Java
IIRC, these should be the only required items to read *.emx files (Everything else in that plug-in is related to migrating the diagrams to the Papyrus format)
HTH,
Camille
Camille Letavernier
Re: Reading .emx model file [message #1782377 is a reply to message #1782373] |
Thu, 22 February 2018 13:11 |
For the exception itself, I believe (I'm pretty sure) that it is because the *.emx file is not loaded in a 'UML302UMLResourceImpl' Resource (The resource that is responsible for converting UML2 3.x models - used by RSA - to UML2 5.x - used by Papyrus).
This resource should be instantiated by the 'UML302UMLResourceFactoryImpl' ResourceFactory, which should be associated to *.emx models
I'm not sure how to associate ContentTypes programmatically, but trying to debug the resource-instantiation steps should help (If you get a UMLResourceImpl or XMIResourceImpl instead of UML302UMLResourceImpl, then the model won't be properly loaded and will throw such exceptions)
An easy (Although a little bit "over-simplified") way to make sure you're using the correct factory would be to use:
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("emx", new UML302UMLResourceFactoryImpl());
instead of:
(This is over-simplified, because it wouldn't work with older versions of RSA Models, using e.g. UML2.2)
HTH,
Camille
Camille Letavernier
Re: Reading .emx model file [message #1782383 is a reply to message #1782381] |
Thu, 22 February 2018 14:42 |
After changing factory to UML302UMLResourceFactoryImpl, I get the following error:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.net.MalformedURLException: unknown protocol: platform
at org.eclipse.uml2.uml.internal.resource.UML302UMLResourceFactoryImpl.createResource(UML302UMLResourceFactoryImpl.java:95)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:434)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCreateResource(ResourceSetImpl.java:243)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:400)
at RSAModelParser.main(RSAModelParser.java:97)
Caused by: java.net.MalformedURLException: unknown protocol: platform
at java.net.URL.<init>(URL.java:600)
at java.net.URL.<init>(URL.java:490)
at java.net.URL.<init>(URL.java:439)
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:199)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
... 6 more
Process finished with exit code 1
As far as I understand a problem appears here :
ecore2xmlRegistry.put("http://www.eclipse.org/uml2/3.0.0/UML", EcoreUtil.getObjectByType(resourceSet.getResource(URI.createURI("platform:/plugin/org.eclipse.uml2.uml/model/UML30_2_UML.ecore2xml"), true).getContents(), Literals.XML_MAP));
in UML302UMLResourceFactoryImpl.java
[Updated on: Thu, 22 February 2018 15:22] Report message to a moderator
Re: Reading .emx model file [message #1782391 is a reply to message #1782383] |
Thu, 22 February 2018 16:06 |
Well after roughly changing
Ecore2XMLRegistry ecore2xmlRegistry = new Ecore2XMLRegistryImpl(
Ecore2XMLRegistry.INSTANCE);
ecore2xmlRegistry
.put(
UML302UMLResource.UML_METAMODEL_NS_URI,
EcoreUtil
.getObjectByType(
resourceSet
.getResource(
URI
.createURI("platform:/plugin/org.eclipse.uml2.uml/model/UML30_2_UML.ecore2xml"), //$NON-NLS-1$
Ecore2XMLPackage.Literals.XML_MAP));
to
ecore2xmlRegistry
.put(
EcoreUtil
.getObjectByType(
resourceSet
.getResource(
URI
.createURI(ClassLoader.getSystemResource("./model/UML30_2_UML.ecore2xml").toString()), //$NON-NLS-1$
where the "model" folder is the same folder copied to the project's "resource" folder I am getting the same error
at RSAModelParser.main(RSAModelParser.java:100)
at org.eclipse.uml2.uml.internal.resource.UML302UMLHandler.createObject(UML302UMLHandler.java:67)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1850)
... 2 more
... 32 more
I will continue investigating how I can read the model in standalone application. Any help is appreciated.
[Updated on: Thu, 22 February 2018 16:07] Report message to a moderator
Re: Reading .emx model file [message #1782426 is a reply to message #1782394] |
Fri, 23 February 2018 07:58 |
Hi Ed,
By default, UML Initialization won't recognize *.emx files, no matter what (Because UML content types, which are used to determine which resource class should be instantiated, are only associated with *.uml, *.xmi and a few other standard file extensions).
So UMLResourcesUtil.init() may help but definitely won't be sufficient
@Dmitrii: did you check which Resource instance you get at runtime? If you get a UML302UMLResourceImpl, then this is probably a UML bug (The correct resource doesn't behave as expected). If you get any other resource instance, then the UML ContentTypes/Factories are not properly configured, and you should keep investigating that
Camille
Camille Letavernier
Re: Reading .emx model file [message #1783399 is a reply to message #1783395] |
Mon, 12 March 2018 15:31 |
After changing the xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" to xmlns:uml="http://www.eclipse.org/uml2/2.5.0/UML" and having the following code:
URI modelFileURI = URI.createFileURI("C:/Users/" + System.getProperty("user.name") + "/Desktop/PingPong.uml");
// URI modelFileURI = URI.createFileURI("C:/Users/" + System.getProperty("user.name") + "/Desktop/PingPong_Cut.uml");
UMLResourcesUtil.init(resourceSet);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("uml", new UMLResourceFactoryImpl());
I don't get the "Value 'assembly' is not legal." error but resource.getContents() is still full of AnyTypeImpl objects.
The same goes to the "cut" version of the attached model before.
You can find "cut" version in the attachment.
[Updated on: Mon, 12 March 2018 15:33] Report message to a moderator
Re: Reading .emx model file [message #1783463 is a reply to message #1783455] |
Tue, 13 March 2018 11:14 |
Ed Willink Messages: 7655 Registered: July 2009 |
Once you change the erroneous xmlns:uml="http://www.eclipse.org/uml2/2.5.0/UML" to xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML", your reader loads the Eclipse UML to give:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'assembly' is not legal. (file:///E:/Development/Rusa/Workspace/PingPongREader/models/PingPong.uml, 530, 105)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'assembly' is not legal. (file:///E:/Development/Rusa/Workspace/PingPongREader/models/PingPong.uml, 530, 105)
Checking the UML 2.3 and 2.5 specs, the Connector::kind feature is derived, so it should not be serialized in the UML file. After deleting the erroneous element, the model loads in your program. The first resource content is a PackageImpl tree. The remainder are AnyTypeImpl which is the fallback for stereotype applications for which there is no official UML element. In the UML Model Editor, the missing libraries cause three errors.
If editing your source model is impractical, you can fix the 'bug' which oocurs at
Thread [main] (Suspended (exception IllegalArgumentException))
ConnectorImpl(BasicEObjectImpl).eOpenSet(EStructuralFeature, Object) line: 1141
ConnectorImpl(BasicEObjectImpl).eDynamicSet(int, EStructuralFeature, Object) line: 1119
ConnectorImpl(BasicEObjectImpl).eDynamicSet(int, Object) line: 1112
ConnectorImpl.eSet(int, Object) line: 519
ConnectorImpl(BasicEObjectImpl).eSet(EStructuralFeature, Object) line: 1071
XMIHelperImpl(XMLHelperImpl).setValue(EObject, EStructuralFeature, Object, int) line: 1156
UMLHandler(XMLHandler).setFeatureValue(EObject, EStructuralFeature, Object, int) line: 2710
UMLHandler(XMLHandler).setAttribValue(EObject, String, String) line: 2769
by providing a derived UMLResourceFactoryImpl that provides a derived UMLHandler that overrides setFeatureValue for the specific case of Connectior::kind or the generic case of setting a derived feature.
Ed Willink
Current Time: Fri Apr 26 19:47:09 GMT 2024
Powered by FUDForum. Page generated in 0.05437 seconds
