Home » Archived » BIRT » Getting 'Data Set script method "Fetch" returned null;' while fetching 2nd Row(Getting Data Set script method "Fetch" returned null; while fetching 2nd Row)
Getting 'Data Set script method "Fetch" returned null;' while fetching 2nd Row [message #1782269] Wed, 21 February 2018 01:55
I am new to Birt reporting tool and trying to learn the scripted data set. My requirement is simple - to fetch data from spring service method and show it to the table. Currently I am getting ''Data Set script method "Fetch" returned null; expected a Boolean value.' while fetching 2nd row of table. In other word, the first row is being fetched successfully and I can see it in the report as well. My data list contains 5 or more list of java objects. Unable to figure out what am I missing(rptdesign is attached). Tried putting the content of initialize method in data-set's open method but still the output was same(stack trace is attached). I need some other operations like adding aggregation to the table so I fetched the data in initialize method instead of data-set's open method.
Previous Topic:Sum only on specific bars in a chart
Next Topic:Report Parameter List Box - Dynamic and Multiple - Select All
Current Time: Wed Nov 05 14:38:12 EST 2025
Powered by FUDForum. Page generated in 0.03519 seconds
