Home » Modeling » TMF (Xtext) » Using indent for more than one level of indentation
Using indent for more than one level of indentation [message #1782182] Tue, 20 February 2018 09:33 Go to next message
Giray Ozel is currently offline Giray OzelFriend
I have the following grammar:
Department:
  'Department:' name = ID
  'Company:' companyName = STRING
  'Persons:' persons += Person+
Person:
  firstName = STRING
  surname = STRING
  address = STRING
And I would like to have formatting like this:
Department: Department1
    Company: "Company1"
    Persons:
        "Person1FirstName" : "Person1LastName" : "Person1Address"
        "Person2FirstName" : "Person2LastName" : "Person2Address"
But when I implement the formatter code for the Person type I cannot seem to be able to use indent twice since the white space formatting gets merged instead of getting concatinated.
class TestsFormatter extends AbstractFormatter2
    def dispatch void format(Department department, extension IFormattableDocument document)
        department.interior[indent]
        department.regionFor.keyword("Department:").prepend[setNewLines(2)]
        department.regionFor.keyword("Department:").append[oneSpace]
        department.regionFor.keyword("Company:").prepend[newLine]
        department.regionFor.keyword("Company:").append[oneSpace]
        department.regionFor.keyword("Persons:").prepend[newLine]
        for (Person person : department.persons)
            person.format
    def dispatch void format(Person person, extension IFormattableDocument document)
        person.prepend[indent]
I found out that there is an example with "increaseIndentation"/"decreaseIndentation" in the documentation of AbstractFormatter2. But when I try to use them, they cannot be resolved.
Re: Using indent for more than one level of indentation [message #1782231 is a reply to message #1782182] Tue, 20 February 2018 19:12 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
you can do this with custom replacer as described here:
https://stackoverflow.com/questions/45305293/how-to-define-different-indentation-levels-in-the-same-document-with-xtext-forma
Twitter : @chrdietrich
Previous Topic:Problem with ID Terminal Rule
Next Topic:Custom QualifiedNameProvider Problems
Current Time: Sat Apr 27 04:12:13 GMT 2024
Powered by FUDForum. Page generated in 0.03198 seconds
