Additional configuration for "Eclipse Application under Test" [message #1781763] |
Tue, 13 February 2018 07:23 |
We want to use RCPTT with a product that already uses multiple framework hooks (AspectJ and XSLTransforms). The transforms are heavily used to modify/hide the Eclipse Default UI.
When we compare the launches of the Product itself with the "Eclipse Application under Test" we see some significant differences, which cause serious issues in the launched product. The transform hook is gone.
Details of the 2 different launches are in the attached configurations stored from the running instances inside text files. Diff is as most important difference the following properties:
osgi.bundles
osgi.framework.extensions
osgi.frameworkClassPath
My questions are:
Can I influence the launch behaviour of RCPTT "Eclipse Application under Test"?
What would be the best way to enable configuration of the properties, mentioned above.
Is there a way to specifiy, which hooks in which versions to use?
Can I update the 3rd party dependencies used for the RCPTT launches (e.g. the emf bundles - cause we use newer versions?)
Any help or hint is highly appreciated.
FUDForum. Page generated in 0.02645 seconds
