Eclipse Input Output Redirection with < and > [message #1781568] |
Thu, 08 February 2018 13:44  |
So in the terminal, I can run my program with
./letter --stack -b ship -e shot -c --output W < input.txt > output.txt
How do I achieve the same functionality in Eclipse? I've figured out how to do --stack -b ship -e shot -c --output W by going to the arguments tab under Run configuration.
I've looked online and seen a lot of posts about using the Common tab to input and output redirection but I can't get it working. When I check only the input file, it doesn't work and the Debug perspective shows it's stuck somewhere trying to read from a stream. When I check allocate console and input file, then it gets stuck on user input (aka I can manually type stuff) in the console.
So how do I get < input.txt and by extension > output.txt working?
FUDForum. Page generated in 0.05895 seconds
