Home » Archived » BIRT » Export report to pdf at runtime.(How do you export a report at runtime to pdf using javascript.)
Export report to pdf at runtime. [message #1780944] Tue, 30 January 2018 04:38
How do you export a birt report using javascript at runtime?
The code that I have tried is in the After Render event:
importPackage(Packages.org.eclipse.birt.report.engine.api);
rptdoc = reportContext.getReportRunnable().getReportName();
// Open the rptDocument
  reportDocument = getReportEngine().openReportDocument(rptdoc);
  // Create the render task, configured for the wanted export format
 IRenderTask renderTask = getReportEngine().createRenderTask(reportDocument);
  IRenderOption options = new RenderOption();
  options.setOutputFormat("pdf");
  options.setOutputFileName("C:/test/myfile.pdf");
  renderTask.setRenderOption(options);
 // Launch the render task and close it
    renderTask.render();
    renderTask.close();
    // Close the rptDocument
    reportDocument.close();
It runs and there are no errors but no pdf gets generated...
My requirement is to run the birt report using an URL and the report should generate itself in a folder as a pdf.
The report should only execute once. I don't want to execute the URL and then in the report it does another runAndRender in after factory, the report should export itself. Hope this makes sense.
I am using Birt 4.5.
Previous Topic:Birt 4.5.0 JARs problem
Next Topic:Cascade Parameters in DataSets
Current Time: Wed Nov 05 07:46:44 EST 2025
Powered by FUDForum. Page generated in 0.03040 seconds
