Multitenant deployment error [message #1780461] |
Mon, 22 January 2018 17:31 |
Arco van der Velden Messages: 6 Registered: October 2017 |
Junior Member |
Hi there,
I'm trying to setup a multitenant enviroment.
All my entities are annotated with @Multitenant(MultitenantType.TABLE_PER_TENANT)
and
@TenantTableDiscriminator(type = TenantTableDiscriminatorType.SCHEMA, contextProperty = EntityManagerProperties.MULTITENANT_PROPERTY_DEFAULT)
When I try to deploy my application on glassfish the following error occurs.
"Exception [EclipseLink-53] (Eclipse Persistence Services - 2.6.4.qualifier): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The relation table name is not set for this mapping.
Mapping: org.eclipse.persistence.mappings.ManyToManyMapping[gebruikerList]
Descriptor: RelationalDescriptor(nl.argumait.vasco.entiteiten.authenticatie.Groep --> [DatabaseTable(vasco_gebruikers.groep)])"
Which points out something is wrong with a ManyToMany relation but when I remove the multitenant properties everything works fine.
So seems like there's a problem with multitenancy and MayToMany relations.
Can someone help me out what's wrong ?
Thanks in advance.
[Updated on: Tue, 23 January 2018 16:03] Report message to a moderator
FUDForum. Page generated in 0.02542 seconds
