NoClassDefFoundError/ClassNotFoundException >>> ObjectMapper [message #1780235] |
Thu, 18 January 2018 22:44 |
Florent Lesage Messages: 2 Registered: January 2018 |
Recent and amateur java developper, on Eclipse IDE, I have join the voluntary staff of a server game. I have a problem with the plugin of the server. It's normally link with our website, but the link seems break. The reason seems to be an "ObjectMapper" not found by the plugin :
[21:20:16] [Thread-8/WARN]: Exception in thread "Thread-8"
[21:20:16] [Thread-8/WARN]: java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper
[21:20:16] [Thread-8/WARN]: at main.java.com.naheulcraft.specific.Ressources.FeatureFunctions$AsynchronousAPISender$APISenderRunnable.run(FeatureFunctions.java:669)
[21:20:16] [Thread-8/WARN]: at java.lang.Thread.run(Unknown Source)
[21:20:16] [Thread-8/WARN]: Caused by: java.lang.ClassNotFoundException: org.codehaus.jackson.map.ObjectMapper
[21:20:16] [Thread-8/WARN]: at java.net.URLClassLoader.findClass(Unknown Source)
[21:20:16] [Thread-8/WARN]: at org.bukkit.plugin.java.PluginClassLoader.findClass(PluginClassLoader.java:101)
[21:20:16] [Thread-8/WARN]: at org.bukkit.plugin.java.PluginClassLoader.findClass(PluginClassLoader.java:86)
[21:20:16] [Thread-8/WARN]: at java.lang.ClassLoader.loadClass(Unknown Source)
[21:20:16] [Thread-8/WARN]: ... 2 more
The following dependancy is in the pom.xml, and Maven seems detects it :
<dependency>
<groupId>org.codehaus.jackson</groupId>
<artifactId>jackson-mapper-asl</artifactId>
<version>1.9.11</version>
<type>jar</type>
<scope>compile</scope>
</dependency>
There isn't error in the import :
import org.codehaus.jackson.map.ObjectMapper;
private class APISenderRunnable implements Runnable
Map<String, String> params;
APISenderRunnable(Map<String, String> params)
this.params = params;
public void run()
ObjectMapper mapper = new ObjectMapper();
String url = FeatureFunctions.BuildFullUrl(NCPlugin.API_URL, params);
try
array = mapper.readTree(new URL(url));
catch(Exception e)
System.out.println("ERROR, URL BUILDING FAILED OR API IS DOWN.");
But it don't work. I have try many propositions on the internet, as change the version, change the .classpath, use com.faster.xml.jackson.databind instead, add the .jar with buildpath > add external jars, clean and build the project... Without success.
This is the complete pom.xml :
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.naheulcraft</groupId>
<artifactId>specific</artifactId>
<url>http://www.naheulcraft.com/</url>
<build>
<sourceDirectory>src</sourceDirectory>
<resources>
<resource>
<filtering>true</filtering>
<directory>src</directory>
<includes>
<include>plugin.yml</include>
</includes>
</resource>
</resources>
<plugins>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<version>2.0.2</version>
<configuration>
<source>1.8</source>
<target>1.8</target>
<encoding>${project.build.sourceEncoding}</encoding>
</configuration>
</plugin>
<plugin>
<artifactId>maven-assembly-plugin</artifactId>
<version>2.4</version>
<executions>
<execution>
<phase>package</phase>
<goals>
<goal>single</goal>
</goals>
</execution>
</executions>
<configuration>
<descriptorRefs>
<descriptorRef>jar-with-dependencies</descriptorRef>
</descriptorRefs>
</configuration>
</plugin>
<plugin>
<artifactId>maven-resources-plugin</artifactId>
<version>2.4.3</version>
<configuration>
</configuration>
</plugin>
</plugins>
</build>
<repositories>
<repository>
<id>spigot-repo</id>
<url>https://hub.spigotmc.org/nexus/content/groups/public/</url>
</repository>
<!--<repository>
<id>bukkit-repo</id>
<url>http://repo.bukkit.org/content/groups/public</url>
</repository>-->
<repository>
<id>codehaus-snapshots</id>
<url>http://snapshots.repository.codehaus.org</url>
</repository>
</repositories>
<dependencies>
<dependency>
<groupId>commons-io</groupId>
<artifactId>commons-io</artifactId>
<version>2.1</version>
</dependency>
<dependency>
<type>jar</type>
</dependency>
<!--<dependency>
<groupId>com.fasterxml.jackson.core</groupId>
<artifactId>jackson-annotations</artifactId>
<version>2.9.3</version>
<type>jar</type>
</dependency>
<dependency>
<artifactId>jackson-core</artifactId>
<type>jar</type>
</dependency>
<dependency>
<artifactId>jackson-databind</artifactId>
<type>jar</type>
<exclusions>
<exclusion>
</exclusion>
<exclusion>
</exclusion>
</exclusions>
</dependency>-->
<!--<dependency>
<groupId>org.bukkit</groupId>
<artifactId>bukkit</artifactId>
<version>LATEST</version>
</dependency>-->
<dependency>
<groupId>com.google.code.google-collections</groupId>
<artifactId>google-collect</artifactId>
<version>snapshot-20080530</version>
<type>jar</type>
</dependency>
</dependencies>
<properties>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
</properties>
<name>NaheulcraftFR-Specific</name>
<version>1.10</version>
</project>
And the actual .classpath :
<classpath>
<classpathentry kind="src" path="src"/>
<classpathentry exported="true" kind="lib" path="C:/Users/Florent_2/Desktop/Serveur test Spigot/bukkit.jar"/>
<classpathentry exported="true" kind="con" path="org.eclipse.m2e.MAVEN2_CLASSPATH_CONTAINER">
<attributes>
<attribute name="maven.pomderived" value="true"/>
</attributes>
</classpathentry>
<classpathentry exported="true" kind="lib" path="C:/Users/Florent_2/Desktop/spigot-1.12.2-R0.1-SNAPSHOT-b1577.jar"/>
<classpathentry exported="true" kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
<classpathentry exported="true" kind="lib" path="C:/Users/Florent_2/Desktop/jackson-mapper-asl-1.9.11.jar"/>
<classpathentry exported="true" kind="lib" path="C:/Users/Florent_2/Desktop/jackson-core-asl-1.9.11.jar"/>
<classpathentry kind="output" path="target/classes"/>
</classpath>
Thank you in advance for your help.
Florent
P.S. : Sorry for my bad english, I'm french, I'm not english-speaker. I write in english forums because I hope receive more help.
[Updated on: Fri, 19 January 2018 23:20] Report message to a moderator
Re: NoClassDefFoundError/ClassNotFoundException >>> ObjectMapper [message #1780320 is a reply to message #1780319] |
Fri, 19 January 2018 23:30 |
Effectively, there are not enough information in the message. The reason is I have not been able to post the totality of my message because of links (anti-bot protection ?).
I edit my message immediately.
EDIT : I don't know if the problem is caused by Eclipse or not, but during my research I found this in a forum on the web with a similar problem, I quote : "It turns out that the environment I am using (Eclipse!) does not properly update the manifest file when you export your code to a JAR file. Without the proper manifest entries, the application cannot "find" the dependent jar files."
I don't know how to proceed.
EDIT2 : PROBLEM SOLVED. I installed m2Eclipse, I selected Run as > Maven Install. A jar-with-dependancies was generated in the target directory, including the missing ObjectMapper. I installed this on the server and this work, the link plugin>website is ok.
[Updated on: Sun, 21 January 2018 02:58] Report message to a moderator
FUDForum. Page generated in 0.03206 seconds
