Home » Modeling » TMF (Xtext) » Code assist for DataType rules
Code assist for DataType rules [message #1779847] Sun, 14 January 2018 11:07 Go to next message
I would like to get some help regarding this problem:
I have a data type rule like this (unit of measure) with a Value converter etc..
A valid value would be ex: 200 mm
UomLength returns UomLength:
INT STRING
I need to get the code assist popup after I type the integer value. The code assist has to show the units available.
I can only get the popup for the whole thing only, not the integer.
Still is reasonable, I can suggest "0 mm" and jump the cursor but I am asking if it's possible
Thanks and Regards,
PD
Re: Code assist for DataType rules [message #1779849 is a reply to message #1779847] Sun, 14 January 2018 12:48 Go to previous messageGo to next message
i am not sure if a datatype rule is very good here cause error recovery / context calculation might be bad.
you may try to play around with
INT ID
class MyDslProposalProvider extends AbstractMyDslProposalProvider {
	override complete_UomLength(EObject model, RuleCall ruleCall, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
		super.complete_UomLength(model, ruleCall, context, acceptor)
		if (context.prefix.isEmpty) {
			acceptor.accept(createCompletionProposal("1", context))
		} else if (context.prefix.endsWith(" ")) {
			acceptor.accept(createCompletionProposal(context.prefix+"mm", context))
		} else {
			acceptor.accept(createCompletionProposal(context.prefix+" mm", context))
	@Inject MyDslGrammarAccess ga
	override complete_ID(EObject model, RuleCall ruleCall, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
		if (ruleCall === ga.uomLengthAccess.IDTerminalRuleCall_1) {
			acceptor.accept(createCompletionProposal("mm", context))
		super.complete_ID(model, ruleCall, context, acceptor)
Re: Code assist for DataType rules [message #1779866 is a reply to message #1779849] Mon, 15 January 2018 00:34 Go to previous message
Great is works !
Thanks you very much (again)
Previous Topic:cross-project references not resolved in standalone mode
Next Topic:Build fails after upgrading to xtext 2.13.0
Current Time: Tue Aug 05 02:02:19 EDT 2025
Powered by FUDForum. Page generated in 0.52279 seconds
