Home » Newcomers » Newcomers » Internal Error occured during " launching SampleTest.java" TestNG class(TestNG class wont run - Internal Error)
Internal Error occured during " launching SampleTest.java" TestNG class [message #1779838] Sun, 14 January 2018 04:21 Go to next message
I am unable to run my TestNG class , It throws Internal Error occured during " launching SampleTest.java" source not specified , Please help troubleshoot issue
Stack Trace:
java.lang.IllegalStateException: source not specified
at org.eclipse.jdt.core.dom.ASTParser.createAST(ASTParser.java:813)
at org.testng.eclipse.util.param.ParameterSolver.getParserNode(ParameterSolver.java:135)
at org.testng.eclipse.util.param.ParameterSolver.parseParameterNames(ParameterSolver.java:125)
at org.testng.eclipse.util.param.ParameterSolver.solveParameters(ParameterSolver.java:112)
at org.testng.eclipse.util.param.ParameterSolver.getParameterNames(ParameterSolver.java:90)
at org.testng.eclipse.util.param.ParameterSolver.solveParameters(ParameterSolver.java:59)
at org.testng.eclipse.ui.util.ConfigurationHelper.getLaunchSuites(ConfigurationHelper.java:422)
at org.testng.eclipse.launch.TestNGLaunchConfigurationDelegate.createVMRunner(TestNGLaunchConfigurationDelegate.java:296)
at org.testng.eclipse.launch.TestNGLaunchConfigurationDelegate.launchTypes(TestNGLaunchConfigurationDelegate.java:161)
at org.testng.eclipse.launch.TestNGLaunchConfigurationDelegate.launch(TestNGLaunchConfigurationDelegate.java:91)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:885)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
Re: Internal Error occured during " launching SampleTest.java" TestNG class [message #1779839 is a reply to message #1779838] Sun, 14 January 2018 06:40 Go to previous message
Looking at the code for ASTParser.createAST:
	public ASTNode createAST(IProgressMonitor monitor) {
		SubMonitor subMonitor = SubMonitor.convert(monitor, 1);
		ASTNode result = null;
		try {
			if (this.rawSource == null && this.typeRoot == null) {
				throw new IllegalStateException("source not specified"); //$NON-NLS-1$
			result = internalCreateAST(subMonitor.split(1));
		} finally {
			// reset to defaults to allow reuse (and avoid leaking)
			initializeDefaults();
		return result;
it's clear that none of the ASTParser.setSource methods have been called to initialize the parser. But everything below that point in the stack is org.testng and unless some other user knows what TestNG is doing I can't help with that. Perhaps https://groups.google.com/forum/#!forum/testng-users would be a better place to ask.
Previous Topic:Eclipse Openhab installation failed
Next Topic:Subclipse problem
Current Time: Tue Oct 28 06:44:42 EDT 2025
Powered by FUDForum. Page generated in 0.09257 seconds
