Re: Line completion with semicolon at the end [message #1779747 is a reply to message #1779712] |
Fri, 12 January 2018 08:10 |
Andreas Sewe Messages: 111 Registered: June 2013 |
Quote:in an earlier version of code recommenders, I'm using the completion of a line with an semicolon with a short cut. Unfortunately, I don't find this shortcut in the current version of this plugin. Under preferences > general > keys exists in the version 2.4.7 the option/command "complete line". Did you rename this entry in the newest release?
No. Code Recommenders does not, by itself, contribute any shortcuts (except for Ctrl+Alt+Space for Snipmatch); these are all contributed by the Java Development Tools, upon which Code Recommenders is built.
That being said, I am unsure what shortcut/behavior you are referring to: In Eclipse Neon (ships with Code Recommenders 2.4.0), the Keys preference page doesn't show a command matching either complete, line, or content assist and uses a semicolon in its shortcut.
Can you please describe what this command you are after actually does? Maybe it is contributed by a third-party plug-in (as I didn't find it in Eclipse Neon)?
FUDForum. Page generated in 0.03445 seconds
