Oxygen.2 cannot find org.junit.Test [message #1779292] |
Thu, 04 January 2018 18:59  |
After importing the project https://github.com/ConSol/java9-modules-maven-junit-example compilation fails when trying to import "org.junit.Test' et al. This project builds, tests, runs fine via Maven.
Looking at the classpath in the Package Explorer, I can clearly see that "org.junit.Test" et al are on the classpath via junit-4.12.jar, but in the editor, it complains "the import org cannot be resolved"
Has anyone else had problems like this with Oxygen.2?
Should I report this as a defect, or does anyone have any ideas on what else to check in the configuration?
I note that in the past I have often seen Eclipse complain about imports this way, but for the life of me, I cannot remember what the resolution was. As far as I am concerned, if a project builds fine via Maven, then Eclipse should also be able to import and build it without issues.
Re: Oxygen.2 cannot find org.junit.Test [message #1779424 is a reply to message #1779292] |
Sun, 07 January 2018 04:39  |
I'm not very familiar with all the Java 9 features, but perhaps you have to do something in your model-info.java to requires/uses something from the other model. Perhaps it's better to post on the JDT forum where the Java tools experts are more likely to see your question.
FUDForum. Page generated in 0.03529 seconds
