Home » Newcomers » Newcomers » An error has occurred. See the log file(Error to open a workbench)
An error has occurred. See the log file [message #1778651] |
Tue, 19 December 2017 10:21 |
Ana Nascimento Messages: 1 Registered: December 2017 |
Hi!
I'm new here and I'm having a problem to open my workbench.
"An error has occurred. See the log file".
So I open the log file and had this message:
!SESSION 2017-10-18 14:32:08.183 -----------------------------------------------
eclipse.buildId=I20110613-1736
java.version=1.7.0_51
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=pt_BR
Command-line arguments: -os win32 -ws win32 -arch x86_64
This is a continuation of log file C:\redacao\manual-usuario\.metadata\.bak_0.log
Created Time: 2017-10-18 14:32:15.365
!ENTRY org.eclipse.jface 2 0 2017-10-18 14:32:15.369
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2017-10-18 14:32:15.369
!MESSAGE A conflict occurred for CTRL+SHIFT+A:
Binding(CTRL+SHIFT+A,
ParameterizedCommand(Command(org.eclipse.pde.ui.openPluginArtifact,Open Plug-in Artifact,
Open a plug-in artifact in the manifest editor,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.pde.internal.ui.search.dialogs.PluginArtifactSearchHandler,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(com.senior.plugin.actions.openResourceAction,Abrir Recursos Jakare,
Category(Command.Category.SeniorPluginCore,Jakare Commandos,null,true),
com.senior.plugin.actions.OpenResourceAction,
,,true),null),
!SESSION 2017-10-19 12:18:06.708 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2017-10-19 12:18:55.899
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 2 0 2017-10-19 12:19:37.649
!SUBENTRY 1 org.eclipse.jface 2 0 2017-10-19 12:19:37.649
,,true),null),
,,true),null),
I don't know what to do, I try to restore the projects in the workbench but it wasn't worked for me.
I tried to delete the .metadata folder e reimport the Existing projects into workspace, but still not working.
I tried to remove the keybinding association, but it doesn't work.
There's anyone that have a clue for what to do?
Re: An error has occurred. See the log file [message #1778861 is a reply to message #1778651] |
Fri, 22 December 2017 14:34 |
Ed Merks Messages: 33142 Registered: July 2009 |
I don't know what com.senior.plugin.actions is but you've installed something that registers a conflicting key binding. There's nothing you can do to fix that unless you're the developer of com.senior and modify the registrations in the plugin.xml to not conflict (or avoid installing PDE so that there is nothing with which to conflict).
Ed Merks
Current Time: Fri Apr 26 12:57:34 GMT 2024
Powered by FUDForum. Page generated in 0.09367 seconds
