Re: SVG references not working [message #1778579 is a reply to message #1778533] |
Mon, 18 December 2017 09:09 |
Hi Lina,
As this work when you use your editor but not when you export it, I suggest you to check two things:
* the build.properties of your plugin in which you should mark your referenced svg or its folder as exported
* the reference itself as once deployed the path to the file might be different (is it relative or absolute ?)
Maxime
Maxime Porhel - Obeo
Re: SVG references not working [message #1781024 is a reply to message #1778579] |
Wed, 31 January 2018 16:17 |
Lina 20 Messages: 32 Registered: March 2017 |
Member |
Hi Maxime,
Thanks for your answer.
*The images folder contains the normal images and the icons one. So Ido not think the problem is related to export the folder.
* The reference is a relative path. Should it be absolute? For example the image path shows in the odesing file is "ot.design/images/StakeholderDef.svg" and the ref the svg contains to the icon is: xlink:href="iconiconiconroleIcon.svg". The image exists in the same folder than StakeholderDef.svg and works on testing but not when exported.
The name of the image is exactly the same there are no case differences.
I already test with sorius version 6.0 but still does not work.
Thank you so much for your help!!!!
Lina
[Updated on: Wed, 31 January 2018 16:22] Report message to a moderator
FUDForum. Page generated in 0.06201 seconds
