| Eclipse Kura [message #1778412] |
Wed, 13 December 2017 23:16  |
I want to implement to other project which is similar to iot greenhouse project, I followed all steps also I deployed .dp file in kura. Bundle gets active in kura but doesn't included in service section. Output of kura.log is
2017-12-13 10:31:27,611 [qtp18004409-357] INFO o.e.k.w.s.s.FileServlet - Copying uploaded package file to file: /tmp/publish.dp
2017-12-13 10:31:27,622 [qtp18004409-357] INFO o.e.k.w.s.s.FileServlet - Installing package...
2017-12-13 10:31:27,624 [DeploymentAgent] INFO o.e.k.d.a.i.DeploymentAgent - About to install package at URL file:/tmp/publish.dp
2017-12-13 10:31:32,675 [DeploymentAgent] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.iot.greenhouse.publisher.GreenhousePublisher ...
2017-12-13 10:31:32,760 [DeploymentAgent] INFO o.e.k.c.c.ConfigurationServiceImpl - Seeding updated configuration for pid: org.eclipse.iot.greenhouse.publisher.GreenhousePublisher
2017-12-13 10:31:32,927 [DeploymentAgent] INFO o.e.k.d.a.i.DeploymentAgent - Posting INSTALLED event for package at URL file:/tmp/publish.dp: successful
OUTPUT of kura-console.log is
!ENTRY org.eclipse.equinox.ds 4 0 2017-12-13 10:31:34.083
!MESSAGE [SCR] Exception while activating instance org.eclipse.iot.greenhouse.sensors.raspberrypi.Pi4JGreenhouseSensorService@1f45fd5 of component org.eclipse.iot.greenhouse.sensors.raspberrypi.GreenhouseSensorsRaspiService
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.processConfigurationEvent(SCRManager.java:363)
at org.eclipse.equinox.internal.ds.SCRManager.processConfigurationEvent(SCRManager.java:303)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:91)
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70)
Caused by: java.lang.UnsatisfiedLinkError: com.pi4j.wiringpi.Gpio.wiringPiSetup()I
at com.pi4j.wiringpi.Gpio.wiringPiSetup(Native Method)
at com.pi4j.io.gpio.RaspiGpioProvider.<init>(RaspiGpioProvider.java:47)
at com.pi4j.io.gpio.GpioFactory.getDefaultProvider(GpioFactory.java:102)
at com.pi4j.io.gpio.impl.GpioControllerImpl.<init>(GpioControllerImpl.java:67)
at com.pi4j.io.gpio.GpioFactory.getInstance(GpioFactory.java:85)
at org.eclipse.iot.greenhouse.sensors.raspberrypi.Pi4JGreenhouseSensorService.activate(Pi4JGreenhouseSensorService.java:43)
... 15 more
Root exception:
FUDForum. Page generated in 0.02721 seconds
