Home » Eclipse Projects » Virgo » Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found(ServiceLoader for jar in repository/ext not working for virgo-tomcat-server-3.7.1.RELEASE)
Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found [message #1778326] Wed, 13 December 2017 02:50 Go to next message
I hope this is the right place to ask this.
Using: virgo-tomcat-server-3.7.1.RELEASE
In my OSGi-bundle-project I am using
javax.websocket.server.ServerEndpointConfig$Configurator
for creating websocket-endpoints.
When starting the bundle via its Activator, I am calling
javax.websocket.server.ServerContainer#addEndpoint
which at runtime is processed by the object/method
org.apache.tomcat.websocket.server.WsServerContainer#addEndpoint
This results in the following stacktrace:
[2017-12-13 08:33:59.189] TCP Connection(16)-127.0.0.1 <DE0006E> Start failed for bundle 'my.bundle' version '1.1.2'. org.eclipse.virgo.nano.deployer.api.core.DeploymentException: BundleException
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleDriver.startBundle(StandardBundleDriver.java:199)
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleDriver.start(StandardBundleDriver.java:178)
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleInstallArtifact.doStart(StandardBundleInstallArtifact.java:310)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.driveDoStart(AbstractInstallArtifact.java:231)
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleInstallArtifact.start(StandardBundleInstallArtifact.java:299)
	at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.start(PipelinedApplicationDeployer.java:375)
	at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:258)
	at org.eclipse.virgo.kernel.deployer.management.StandardDeployer.deploy(StandardDeployer.java:52)
	at sun.reflect.GeneratedMethodAccessor78.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:71)
	at sun.reflect.GeneratedMethodAccessor72.invoke(Unknown Source)
	at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:275)
	at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenReturn(ConvertingMethod.java:193)
	at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenReturn(ConvertingMethod.java:175)
	at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:117)
	at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:54)
	at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:237)
	at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.java:138)
	at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.java:252)
	at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:819)
	at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:801)
	at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1471)
	at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:76)
	at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1312)
	at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1404)
	at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:832)
	at sun.reflect.GeneratedMethodAccessor77.invoke(Unknown Source)
	at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:323)
	at sun.rmi.transport.Transport$1.run(Transport.java:200)
	at sun.rmi.transport.Transport$1.run(Transport.java:197)
	at sun.rmi.transport.Transport.serviceCall(Transport.java:196)
	at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:568)
	at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:826)
	at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$256(TCPTransport.java:683)
	at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:682)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Caused by: org.osgi.framework.BundleException: Exception in my.bundle.Activator.start() of bundle my.bundle.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
	at org.eclipse.virgo.nano.core.internal.StandardBundleStarter.start(StandardBundleStarter.java:57)
	at org.eclipse.virgo.nano.core.internal.StandardBundleStarter.start(StandardBundleStarter.java:45)
	at sun.reflect.GeneratedMethodAccessor66.invoke(Unknown Source)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:333)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:133)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:121)
	at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
	at com.sun.proxy.$Proxy45.start(Unknown Source)
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleDriver.startBundle(StandardBundleDriver.java:197)
	... 45 common frames omitted
Caused by: java.util.ServiceConfigurationError: javax.websocket.server.ServerEndpointConfig$Configurator: Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found
	at java.util.ServiceLoader.fail(ServiceLoader.java:239)
	at java.util.ServiceLoader.access$300(ServiceLoader.java:185)
	at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:372)
	at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404)
	at java.util.ServiceLoader$1.next(ServiceLoader.java:480)
	at javax.websocket.server.ServerEndpointConfig$Configurator.loadDefault(ServerEndpointConfig.java:168)
	at javax.websocket.server.ServerEndpointConfig$Configurator.fetchContainerDefaultConfigurator(ServerEndpointConfig.java:152)
	at javax.websocket.server.ServerEndpointConfig$Builder.<init>(ServerEndpointConfig.java:69)
	at javax.websocket.server.ServerEndpointConfig$Builder.create(ServerEndpointConfig.java:57)
	at org.apache.tomcat.websocket.server.WsServerContainer.addEndpoint(WsServerContainer.java:227)
	at my.bundle.WebSocketServlet.publishEndpoint(WebSocketServlet.java:294)
	at my.bundle.Activator$EndpointPublisherServiceTrackerCustomizer.addingService(Activator.java:26)
	at my.bundle.Activator$EndpointPublisherServiceTrackerCustomizer.addingService(Activator.java:21)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:932)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
	at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:317)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
	at my.bundle.Activator.start(Activator.java:54)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	... 68 common frames omitted
When looking at the StackTrace, I found out that the Provider for the ServiceLoader is located in the .jar file
org.apache.tomcat.websocket_8.5.11.jar
in the path
%VIRGO%/repository/ext
Looking at the .jar itself its setup looks alright: META-INF/services has the required SLI file and the class itself exists aswell.
And maybe the worst of all: Everything works fine when trying to publish the exact same bundle to a "virgo-tocmat-server-3.7.0.RELEASE" on another PC.
I don't know, maybe some configuration for my local 3.7.1 Installation needs to be fixed.
Can you help me to figure out how to resolve this error?
Thanks and Greetings,
Lukas Höllein
Re: Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found [message #1778414 is a reply to message #1778326] Thu, 14 December 2017 00:23 Go to previous messageGo to next message
Hi Lukas
Indeed, this is the place to ask such questions.
Is it possible that you attach your bundle here, so I can have a look at the problem you are facing.
Dani
Re: Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found [message #1778508 is a reply to message #1778414] Fri, 15 December 2017 07:26 Go to previous messageGo to next message
Hi Dani,
ok I attached some files.
I hope this helps you to better unterstand my problem.
I have two bundles:
1. Server - requires websocket. Consists of "server-pom.xml", "server-Activator.java"
2. websocket. Consists of "websocket-pom.xml", "EndpointPublisher.java", "WebSocketServlet.java"
The error occurs, when trying to start the "Server" bundle via its activator.
In its activator, the "websocket" bundle is referenced.
In "WebSocketServlet" I created a comment starting with "$ERROR_HERE$".
Thats the line of code where the last code of me gets executed before the "Provider not found" error.
Thanks for your help,
Lukas
Re: Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found [message #1778509 is a reply to message #1778508] Fri, 15 December 2017 07:37 Go to previous messageGo to next message
Can you also upload the generated Manifests? Would make things easier for me ;)
Dani
Re: Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found [message #1778513 is a reply to message #1778509] Fri, 15 December 2017 08:33 Go to previous messageGo to next message
Here you go.
Re: Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found [message #1778696 is a reply to message #1778513] Wed, 20 December 2017 03:58 Go to previous messageGo to next message
Hi Lukas
I could not yet spot anything which would cause the effect, that it runs on Virgo 3.7.0 but nor on 3.7.1.
Maybe another Virgo expert will look at this.
Dani
Re: Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found [message #1778756 is a reply to message #1778508] Wed, 20 December 2017 18:12 Go to previous messageGo to next message
Lukas Höllein wrote on Fri, 15 December 2017 12:26
Hi Dani,
I have two bundles:
Lukas
Why do you try to provide your own server? Is there any requirement about that?
Virgo Server for Apache Tomcat supports websockets.
Violeta
Re: Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found [message #1778757 is a reply to message #1778756] Wed, 20 December 2017 18:52 Go to previous message
Just tested this very simple example (attached) and I am able to see
[2017-12-21 01:43:13.313] INFO  iLogServiceListener@2f7f143d org.osgi.service.log.LogService                                   Bundle websocket_0.0.0, Service 254, ServiceEvent REGISTERED
[2017-12-21 01:43:13.313] INFO  start-signalling-3           org.eclipse.virgo.medic.eventlog.default                         WE0001I Started web bundle 'websocket' version '0.0.0' with context path '/websocket'.
[2017-12-21 01:43:13.314] INFO  start-signalling-3           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'websocket' version '0.0.0'.
[2017-12-21 01:43:13.314] INFO  start-signalling-3           o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager     Thread context class loader 'KernelBundleClassLoader: [bundle=websocket_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=websocket_0.0.0]'
[2017-12-21 01:47:38.612] INFO  tp-nio-127.0.0.1-8080-exec-3 System.out                                                        test.endpoint.Endpoint.onOpen
[2017-12-21 01:47:38.616] INFO  tp-nio-127.0.0.1-8080-exec-3 System.out                                                        test.endpoint.Endpoint.onMessage
[2017-12-21 01:47:38.618] INFO  tp-nio-127.0.0.1-8080-exec-8 System.out                                                        test.endpoint.Endpoint.onClose
[2017-12-21 01:47:39.957] INFO  tp-nio-127.0.0.1-8080-exec-2 System.out                                                        test.endpoint.Endpoint.onOpen
[2017-12-21 01:47:39.958] INFO  tp-nio-127.0.0.1-8080-exec-5 System.out                                                        test.endpoint.Endpoint.onMessage
[2017-12-21 01:47:39.964] INFO  tp-nio-127.0.0.1-8080-exec-7 System.out                                                        test.endpoint.Endpoint.onClose
just put the war archive in the pickup folder and that's it
Previous Topic:How to include a managed service factory configuration artifact in a plan?
Next Topic:Error while upgrading to Java 1.8 : Expecting a stackmap frame
Current Time: Sun Oct 26 04:26:02 EDT 2025
Powered by FUDForum. Page generated in 0.26589 seconds
