Home » Archived » Eclipse SmartHome » Multiple AND or OR operators in rules when using rule REST API(How to use multiple AND or OR operators in rule conditions when using Rule REST API)
Multiple AND or OR operators in rules when using rule REST API [message #1778018] Fri, 08 December 2017 03:17 Go to next message
I'm consuming Eclipse smart home REST API to create rules. I already know how to create a rule with only one condition.
 "conditions": [
            "id": "7",
            "label": "Test rule",
            "description": "This triggers the rule if an item state has changed.",
            "configuration": {
            "itemName": "sensor_luminance_TUID_zwave_device_octopuszstick1_node12",
            "state": "48",
            "operator": "="
            "type": "core.ItemStateCondition"
But I have a requirement to create rules with multiple OR or AND operators. Ex:
If( X AND Y AND Z ) {
       DO THIS
If ((X AND Y) OR Z) {
       DO THIS
How to do it?
Re: Multiple AND or OR operators in rules when using rule REST API [message #1778152 is a reply to message #1778018] Mon, 11 December 2017 05:22 Go to previous messageGo to next message
Hi Dushan,
a rule can have a list of triggers and can be started by any of the triggers in this list. As for the conditions, a rule will execute its action(s) only if all given conditions match. For more information start on the JavaDoc for the Rule class.
Hope that helps. Cheers,
Henning
Re: Multiple AND or OR operators in rules when using rule REST API [message #1778225 is a reply to message #1778152] Tue, 12 December 2017 02:02 Go to previous message
Hi Henning,
Thank you for the help!
Dushan
Previous Topic:Eclipse SmartHome
Next Topic:Eclipse Kura
Current Time: Thu Nov 06 14:14:57 EST 2025
Powered by FUDForum. Page generated in 0.03542 seconds
