Home » Eclipse Projects » Eclipse Titan » Default Parameters in Template Bug ?(When using function in template for default parameters, the function is not recall.)
Default Parameters in Template Bug ? [message #1777997] Thu, 07 December 2017 09:07 Go to next message
Hi everyone !
I'm integrating ITS tests used by ETSI with TTWB in TITAN. But to my dismay, for DENM, default parameter for timestamp in the templates use a function to get current time.
But when I execute the tests, this function is called at the begining, before all initialize, and they are not recall, so after two tests, I have 40 s of difference between my time and tester time (I precise that they are on the same machine).
So, my question is : is it a Titan bug, or will it stay like that and change all call to these template to use the function to initialize the parameter.
It's simpler with example : I'm have to change
m_denm(
                    m_denmMgmtConTermination(
                        m_tsActionId,
                        c_transmissionInterval * 4 / 1000,
                    v_situation,
                    m_denmLocation_zeroDelta
to
m_denm(
                    m_denmMgmtCon(
                        m_tsActionId,
                        c_transmissionInterval,
                        f_getCurrentTime(),
                        f_getCurrentTime()
                    v_situation,
because the template is
template (value) ManagementContainer m_denmMgmtCon(
            template (value) ActionID p_actionID,
            template (value) StationType p_stationType := f_getTsStationType(),
            template (value) ValidityDuration p_validityDuration := defaultValidity,
            template (omit) TransmissionInterval p_transmissionInterval := omit,
            template (value) TimestampIts p_detectionTime := f_getCurrentTime(),
            template (value) TimestampIts p_referenceTime := f_getCurrentTime()
            actionID := p_actionID,
            detectionTime := p_detectionTime,
            referenceTime := p_referenceTime,
            termination := omit,
            eventPosition := m_tsPosition,
            relevanceDistance := lessThan50m,
            relevanceTrafficDirection := allTrafficDirections,
            validityDuration := p_validityDuration,
            transmissionInterval := p_transmissionInterval,
            stationType := p_stationType
I hope I was clear, and you can answer to my question.
Best regards
E. Bourdy
Re: Default Parameters in Template Bug ? [message #1778030 is a reply to message #1777997] Fri, 08 December 2017 06:10 Go to previous messageGo to next message
Hi Emilien,
OK , this is what I understood so far:
If for the template m_denmMgmtCon one relies on the default value of the parameter say p_referenceTime (which is the return value of f_getCurrentTime() ) and invokes this parameter with "-",
like here :
                        m_tsActionId,
                        -,    //default:= f_getCurrentTime()
			-,    //default:=f_getCurrentTime()
			isCancellation
then the value of the parameter stays the same
(Mind that I have used "-" which does not appear in your example; please confirm that this is an oversight from your part)
If instead of the "-" we use the function as parameter, as in:
                        m_tsActionId,
                        f_getCurrentTime(),
			f_getCurrentTime(),
			isCancellation
then the parameter value changes accordingly at every new invokation.
Please confirm that I understood correctly;
I have verified it and this is indeed the current behaviour.
I can't tell yet you whether this is a fault or not ; we have to look into the standard carefully;
I will come back to you soonest
Best regards
Elemer
[Updated on: Fri, 08 December 2017 11:02] by Moderator
Re: Default Parameters in Template Bug ? [message #1778036 is a reply to message #1778030] Fri, 08 December 2017 07:44 Go to previous messageGo to next message
Hi Emilien,
you might also be interested in the following:
we have an ITS suite (not the most recent one though ) which is functional and adapted to Titan, see here:
https://github.com/elnrnag/ITSG5_TS_Titanized_TA
-the test ports used are a hybrid of our adaptations and the ETSI Java test adapters ( so the ATS is connected to these adapters)
-the PER codecs are based on asn1c
Most of the code been tested and working against a Cohda box
We are working on the latest version of the code , but for that we don't have an open source PER codec solution.
If interested in details pls contact https://github.com/elnrnag
BR
Elemer
[Updated on: Fri, 08 December 2017 11:03] by Moderator
Re: Default Parameters in Template Bug ? [message #1778253 is a reply to message #1778036] Tue, 12 December 2017 06:11 Go to previous messageGo to next message
Hi Emilien,
Here's our conclusion:
- this is a side effect of a speed optimization:
Titan calls the function referred as default parameter at the beginning of execution
and then reuses the return value to save time;
This works well for deterministic functions , but causes problems with non-deterministic ones , as those that depend on time.
What we can offer as a solution is to implement the standard behaviour in runtime 2 (function test runtime) ,
but keeping the current behaviour in the default runtime (runtime 1 , load test runtime) .
Practically this means that users of runtime 1 will have to continue to use direct function references as parameters as you did.
Users of runtime 2 will have the choice of using the standard notation for default "-".
I don't have an ETA for this modification, most likely it will be added during January.
BR
Elemer
Re: Default Parameters in Template Bug ? [message #1778254 is a reply to message #1778036] Tue, 12 December 2017 06:13 Go to previous messageGo to next message
Hi Elemer,
Thanks for your answer.
You get it, it's because with m_denmConMgmt template, termination is set to omit, so from detectionTime to termination they are initialized with default value.
I've ask Yann Garcia from FSCOM to know if there is a detail on TTCN standard and he answer that if we want default value initiliazed only at the beginning it should be taged @deterministic to not re-evaluate the value each time we need default value.
For your ITS test suite, I'll see if we can use it with our ITS stack (I don't know why we couldn't), because we made codec for CAM/DENM/GN but when we saw that ETSI was working on ACPorts for GeoNetworking, we decided to wait until they end this part.
Emilien
Re: Default Parameters in Template Bug ? [message #1778258 is a reply to message #1778254] Tue, 12 December 2017 06:38 Go to previous messageGo to next message
Hi Emilien,
yes, we know about the @deterministic, but it poses two problems;
-first , the majority of functions are deterministic , so it would be easier to mark those which aren't (with @nondeterministic maybe?)
-secondly it would cause legacy problems, as in our existing test suites with speed requirements the functions are not marked with @deterministic so the above modification
would cause issues
However, we will be evaluating the different options
BR
Elemer
Re: Default Parameters in Template Bug ? [message #1780101 is a reply to message #1778258] Wed, 17 January 2018 07:03 Go to previous message
Hi Emilien,
we have implemented the correction in Runtime 2 , as discussed above,
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=529019
We will not release a binary at this time, if you need this modification please compile from source.
You can migrate your project to Runtime 2 with a loss of speed of execution you will probably not notice.
To change your project you will have to do the following modifications in your Makefile (after running a make clean first of course):
1. add -DTITAN_RUNTIME_2 to CPPFLAGS:
# Flags for the C++ preprocessor (and makedepend as well):
CPPFLAGS = -D$(PLATFORM) -I$(TTCN3_DIR)/include -DTITAN_RUNTIME_2
2. add -R to compiler flags:
# Flags for the TTCN-3 and ASN.1 compiler:
COMPILER_FLAGS = -L ..other flags.. -R
3.change TTCN3_LIB to ttcn3-rt2 or ttcn3-rt2-parallel (from ttcn3 or ttcn3-parallel)
# Execution mode: (either ttcn3 or ttcn3-parallel)
TTCN3_LIB = ttcn3-rt2-parallel
Best regards
Elemer
Previous Topic:TTCN-3 template question
Next Topic:Debug: Using the value of an optional field containing omit
Current Time: Tue Sep 23 16:45:31 EDT 2025
Powered by FUDForum. Page generated in 0.03770 seconds
