| Weird profile references when using the "New Papyrus Model" wizard [message #1777738] |
Sun, 03 December 2017 17:02  |
When applying "local" profiles (with "browse workspace") you get two different reference types for the applied profile if you apply it after creating the model or if you apply it from the "New Papyrus Model" wizard (in the last page).
In the first case you get relative references like "path/foo.profile.uml" in the second case you get a schema-less absolute paths: "/<project dir>/path/foo.profile.uml".
While both references work from inside Eclipse if you deal with the second type from a stand-alone program you are in troubles.
Is that by design or is that a bug?
FUDForum. Page generated in 0.03455 seconds
