Re: Building dependent resources [message #1777210 is a reply to message #1777209] |
Mon, 27 November 2017 07:17 |
this usually happens automatically through org.eclipse.xtext.builder.clustering.ClusteringBuilderState.queueAffectedResources(Set<URI>, IResourceDescriptions, CurrentDescriptions, Collection<Delta>, Collection<Delta>, BuildData, IProgressMonitor)
which calls org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager.isAffected(Collection<Delta>, IResourceDescription, IResourceDescriptions)
=> if it does not work for you the question is: what is special about your dsl and the references and the changes that require a rebuild
Twitter : @chrdietrich
Re: Building dependent resources [message #1777244 is a reply to message #1777242] |
Mon, 27 November 2017 12:49 |
they are modeled by references
b references a
and changes to a which are detected by the EObjectDescription changes.
created by IDefaultResourceDescriptionStrategy.
this would be 100000000 times easier to eplain if you would be more explicit on
what you change.
and how file b relates to file a
FUDForum. Page generated in 0.05211 seconds
