| I2c bus [message #1776856] |
Wed, 22 November 2017 04:59  |
Hello
I successfully access Gpio through jdk.dio library.
Now im trying to access i2c device through index id method , but im facing below error
2017-11-22 09:19:43,220 [Component Resolve Thread (Bundle 7)] INFO o.e.k.i.I2c - java.io.IOException
what i have did is
this is my jdk.dio.policy file (/opt/eclipse/kura/kura/jdk.dio.policy) in target
grant {
permission jdk.dio.DeviceMgmtPermission "*:*", "open";
permission jdk.dio.gpio.GPIOPinPermission "*:*", "open,setdirection";
permission jdk.dio.gpio.GPIOPortPermission "*:*";
permission jdk.dio.i2cbus.I2CPermission "*:*";
permission jdk.dio.spibus.SPIPermission "*:*";
permission jdk.dio.uart.UARTPermission "*:*";
permission jdk.dio.watchdog.WatchdogTimerPermission "*:*";
permission java.security.AllPermission;
i added below line in jdk.dio.properties (/opt/eclipse/kura/kura/jdk.dio.properties) in target
41 = deviceType: i2cbus.I2CDevice, address:0x52, addressSize:7, clockFrequency:400000
where 0x52 is my i2c device address.
Is this the path of jdk.dio.policy and jdk.dio.properties i am modifying is correct or some other files i need to modify?
Is something else i need to do?
khaleel
[Updated on: Wed, 22 November 2017 05:03] by Moderator
| Re: I2c bus [message #1780831 is a reply to message #1776856] |
Mon, 29 January 2018 00:12  |
hello, I am trying to use jdk.dio in kura. I have searched a lot in web. But i still do not understand how to use it. For example, How to output a high level to
GPIO port? what is Raspberry PI 3 B port number or port name in jdk.dio? Can you give me any advices ? thank you very much .
FUDForum. Page generated in 0.05418 seconds
