Re: mqtt [message #1776823 is a reply to message #1776759] |
Wed, 22 November 2017 04:17 |
gopal korrapati Messages: 48 Registered: October 2017 |
Member |
this is the code i am using and trying to debugging my code before publishing i am able to printing that data. after that I am open mymqtt app in my mobile. I am connected to same server like mqtt://iot.eclipse.org and same topic.I am starting to subscribing to same topic but I not getting anything in dashboard?
package org.eclipse.kura.demo.heater;
import java.util.Date;
import java.util.Map;
import java.util.Random;
import java.util.concurrent.Executors;
import java.util.concurrent.ScheduledExecutorService;
import java.util.concurrent.ScheduledFuture;
import java.util.concurrent.TimeUnit;
import org.eclipse.kura.cloud.CloudClient;
import org.eclipse.kura.cloud.CloudClientListener;
import org.eclipse.kura.cloud.CloudService;
import org.eclipse.kura.configuration.ConfigurableComponent;
import org.eclipse.kura.message.KuraPayload;
import org.osgi.service.component.ComponentContext;
import org.osgi.service.component.ComponentException;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class Heater implements ConfigurableComponent, CloudClientListener {
private static final Logger s_logger = LoggerFactory.getLogger(Heater.class);
// Cloud Application identifier
private static final String APP_ID = "heater";
// Publishing Property Names
private static final String MODE_PROP_NAME = "mode";
private static final String MODE_PROP_PROGRAM = "Program";
private static final String MODE_PROP_MANUAL = "Manual";
private static final String MODE_PROP_VACATION = "Vacation";
private static final String PROGRAM_SETPOINT_NAME = "program.setPoint";
private static final String MANUAL_SETPOINT_NAME = "manual.setPoint";
private static final String TEMP_INITIAL_PROP_NAME = "temperature.initial";
private static final String TEMP_INCREMENT_PROP_NAME = "temperature.increment";
private static final String PUBLISH_RATE_PROP_NAME = "publish.rate";
private static final String PUBLISH_TOPIC_PROP_NAME = "publish.semanticTopic";
private static final String PUBLISH_QOS_PROP_NAME = "publish.qos";
private static final String PUBLISH_RETAIN_PROP_NAME = "publish.retain";
private CloudService m_cloudService;
private CloudClient m_cloudClient;
private final ScheduledExecutorService m_worker;
private ScheduledFuture<?> m_handle;
private float m_temperature;
private Map<String, Object> m_properties;
private final Random m_random;
// Dependencies
public Heater() {
super();
this.m_random = new Random();
this.m_worker = Executors.newSingleThreadScheduledExecutor();
public void setCloudService(CloudService cloudService) {
this.m_cloudService = cloudService;
public void unsetCloudService(CloudService cloudService) {
this.m_cloudService = null;
// Activation APIs
protected void activate(ComponentContext componentContext, Map<String, Object> properties) {
s_logger.info("Activating Heater...");
this.m_properties = properties;
for (String s : properties.keySet()) {
s_logger.info("Activate - " + s + ": " + properties.get(s));
// get the mqtt client for this application
try {
// Acquire a Cloud Application Client for this Application
s_logger.info("Getting CloudClient for {}...", APP_ID);
this.m_cloudClient = this.m_cloudService.newCloudClient(APP_ID);
this.m_cloudClient.addCloudClientListener(this);
// Don't subscribe because these are handled by the default
// subscriptions and we don't want to get messages twice
doUpdate(false);
} catch (Exception e) {
s_logger.error("Error during component activation", e);
throw new ComponentException(e);
s_logger.info("Activating Heater... Done.");
protected void deactivate(ComponentContext componentContext) {
s_logger.debug("Deactivating Heater...");
// shutting down the worker and cleaning up the properties
this.m_worker.shutdown();
// Releasing the CloudApplicationClient
s_logger.info("Releasing CloudApplicationClient for {}...", APP_ID);
this.m_cloudClient.release();
s_logger.debug("Deactivating Heater... Done.");
public void updated(Map<String, Object> properties) {
s_logger.info("Updated Heater...");
// store the properties received
s_logger.info("Update - " + s + ": " + properties.get(s));
// try to kick off a new job
doUpdate(true);
s_logger.info("Updated Heater... Done.");
// Cloud Application Callback Methods
public void onControlMessageArrived(String deviceId, String appTopic, KuraPayload msg, int qos, boolean retain) {
// TODO Auto-generated method stub
s_logger.info("onControlMessageArrived");
public void onMessageArrived(String deviceId, String appTopic, KuraPayload msg, int qos, boolean retain) {
s_logger.info("onMessageArrived" + msg.getMetric("temperatureInternal"));
public void onConnectionLost() {
public void onConnectionEstablished() {
public void onMessageConfirmed(int messageId, String appTopic) {
public void onMessagePublished(int messageId, String appTopic) {
s_logger.info("onMessagepublished" + appTopic);
// Private Methods
* Called after a new set of properties has been configured on the service
private void doUpdate(boolean onUpdate) {
// cancel a current worker handle if one if active
if (this.m_handle != null) {
this.m_handle.cancel(true);
if (!this.m_properties.containsKey(TEMP_INITIAL_PROP_NAME)
|| !this.m_properties.containsKey(PUBLISH_RATE_PROP_NAME)) {
s_logger.info(
"Update Heater - Ignore as properties do not contain TEMP_INITIAL_PROP_NAME and PUBLISH_RATE_PROP_NAME.");
return;
// reset the temperature to the initial value
if (!onUpdate) {
this.m_temperature = (Float) this.m_properties.get(TEMP_INITIAL_PROP_NAME);
// schedule a new worker based on the properties of the service
int pubrate = (Integer) this.m_properties.get(PUBLISH_RATE_PROP_NAME);
this.m_handle = this.m_worker.scheduleAtFixedRate(new Runnable() {
public void run() {
Thread.currentThread().setName(getClass().getSimpleName());
doPublish();
// publish();
}, 0, pubrate, TimeUnit.MINUTES);
* Called at the configured rate to publish the next temperature measurement.
// private void publish() {
// String topic = (String) this.m_properties.get(PUBLISH_TOPIC_PROP_NAME);
// Integer qos = (Integer) this.m_properties.get(PUBLISH_QOS_PROP_NAME);
// Boolean retain = (Boolean) this.m_properties.get(PUBLISH_RETAIN_PROP_NAME);
// String mode = (String) this.m_properties.get(MODE_PROP_NAME);
// // Publish the message
// try {
// s_logger.info("payload content :- " + payload.getMetric("temperatureInternal"));
// this.m_cloudClient.publish(topic, payload, qos, retain);
// s_logger.info("Published to {} message: {}", topic, payload);
// } catch (Exception e) {
// s_logger.error("Cannot publish topic: " + topic, e);
private void doPublish() {
// fetch the publishing configuration from the publishing properties
// Increment the simulated temperature value
float setPoint = 0;
float tempIncr = (Float) this.m_properties.get(TEMP_INCREMENT_PROP_NAME);
if (MODE_PROP_PROGRAM.equals(mode)) {
setPoint = (Float) this.m_properties.get(PROGRAM_SETPOINT_NAME);
} else if (MODE_PROP_MANUAL.equals(mode)) {
setPoint = (Float) this.m_properties.get(MANUAL_SETPOINT_NAME);
} else if (MODE_PROP_VACATION.equals(mode)) {
setPoint = 6.0F;
if (this.m_temperature + tempIncr < setPoint) {
this.m_temperature += tempIncr;
} else {
this.m_temperature -= 4 * tempIncr;
// Allocate a new payload
KuraPayload payload = new KuraPayload();
// Timestamp the message
payload.setTimestamp(new Date());
// Add the temperature as a metric to the payload
payload.addMetric("temperatureInternal", this.m_temperature);
payload.addMetric("temperatureExternal", 5.0F);
payload.addMetric("temperatureExhaust", 30.0F);
int code = this.m_random.nextInt();
if (this.m_random.nextInt() % 5 == 0) {
payload.addMetric("errorCode", code);
} else {
payload.addMetric("errorCode", 0);
try {
// subscribe the message
// try {
// this.m_cloudClient.subscribe(topic, qos);
// s_logger.info("subscribe the {} message: {}", topic, qos);
FUDForum. Page generated in 0.03037 seconds
