Re: Internal error occurred during: "Launching Launch Runtime Eclipse" [message #1776586 is a reply to message #1776568] |
Sat, 18 November 2017 02:18 |
serio adamo Messages: 24 Registered: September 2017 |
Christian Dietrich wrote on Fri, 17 November 2017 19:22Please attach the complete error log from the error view
!ENTRY org.eclipse.core.jobs 4 2 2017-11-18 10:15:29.905
!MESSAGE An internal error occurred during: "Launching Launch Runtime Eclipse".
!STACK 0
java.lang.NoSuchMethodError: org.eclipse.jdt.launching.JavaRuntime.isModularJava(Lorg/eclipse/jdt/launching/IVMInstall;)Z
at org.eclipse.pde.launching.AbstractPDELaunchConfiguration.launch(AbstractPDELaunchConfiguration.java:77)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:885)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
Christian Dietrich wrote on Fri, 17 November 2017 19:23And ps: which java version do you use?
Java version:
java version "1.8.0_101"
Java(TM) SE Runtime Environment (build 1.8.0_101-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.101-b13, mixed mode)
Install package: jdk-8u101-windows-x64.exe
[Updated on: Sat, 18 November 2017 02:20] Report message to a moderator
Re: Internal error occurred during: "Launching Launch Runtime Eclipse" [message #1776594 is a reply to message #1776591] |
Sat, 18 November 2017 09:18 |
Christian Dietrich wrote on Sat, 18 November 2017 07:58For me it looks like you have somewhere
(Eg due automatic plugin update)
A mixture of oxygen 1a and pre oxygen 1a plugins
(Pde from 1a jdt from before)
Can you have a look at the version number of the pde and jdt plugins
org.eclipse.pde.core:
3.11.100.v20170517-0724
org.eclipse.pde.launching:
3.7.50.v20171007-1315
org.eclipse.pde.ui:
3.10.50.v20171007-1315
org.eclipse.pde.build:
3.9.300.v20170515-0912
org.eclipse.jdt:
2.13.0.v20170612-0950
the plugins org.eclipse.pde.ui and org.eclipse.pde.launching seems be automatic updated. (That is very strange, because I have turn off the automatic updates in Preferences/Install/Update/Automatic Updates)
[Updated on: Sat, 18 November 2017 09:23] Report message to a moderator
Re: Internal error occurred during: "Launching Launch Runtime Eclipse" [message #1776610 is a reply to message #1776606] |
Sat, 18 November 2017 12:31 |
Ed Willink wrote on Sat, 18 November 2017 11:55Hi
I presume that you invoked Help->Check for Updates and so Oxygen.1a was provided as the best update.
org.eclipse.jdt:
is wrong. It should be 2.13.1... Are you sure you did not get any errors while updating? Try updating again.
Ed Willink
In fact, I did not click Help->Check for Updates at all. As I mention at topic, I just reinstall eclipse...
Anyway, this issue was fixed, after update jdt to newest version: 3.12.1.v20171009-0410. (Only this version can be select, no 2.13.1...)
PS: But I will use neon, it more stable. oxygen seems silent update in background, even if turn off automatic update.....
Thanks again!
[Updated on: Sat, 18 November 2017 12:33] Report message to a moderator
FUDForum. Page generated in 0.03891 seconds
