Home » Archived » Eclipse SmartHome » JDBC persistence service in ESH(JDBC persistence service in ESH)
JDBC persistence service in ESH [message #1776417] Thu, 16 November 2017 05:03 Go to next message
Is there a JDBC persistence service available in ESH ?
If it is available, which is the DB(sqlite, H2) to which we can configure with minimal effort and steps to achieve it.
Thanks.
Re: JDBC persistence service in ESH [message #1776543 is a reply to message #1776417] Fri, 17 November 2017 09:04 Go to previous messageGo to next message
Hi Kiran,
PersistenceService's only exist in openHAB. We do not have them in ESH.
But there are plenty available as you can see here: https://github.com/openhab/openhab1-addons/tree/master/bundles/persistence
However if you want to use them in openHAB2/ESH you need the org.openhab.core.compat1x bundle with the org.openhab.core.persistence.PersistenceService interface.
Some documentation with examples on how to use them can be found here: http://docs.openhab.org/configuration/persistence.html
I do not know what you are planning to do with it but if you like to create nice graphs about item states I can recommend using the org.openhab.persistence.rrd4j service.
Stefan
Re: JDBC persistence service in ESH [message #1776590 is a reply to message #1776543] Sat, 18 November 2017 02:03 Go to previous messageGo to next message
Hi Stefan,
I would like to store item state for graphing purpose and as well as on restart all items should pick the last saved state.
I would like to know the steps to configure it to access DB, if anyone tried on ESH.
Kiran.
Re: JDBC persistence service in ESH [message #1776714 is a reply to message #1776590] Mon, 20 November 2017 12:22 Go to previous messageGo to next message
Hi Kiran,
what you want is exactly what I described. You can store an item's state for graphing purposes or to restore it on a restart of the system via a persistence service.
But since ESH is just the framework it does not provide implementations for persistence services. If you need them, either implement your own or use a solution such as openHAB that bases on ESH and implements persistence services. I have linked the documentation in my post above.
Stefan
Re: JDBC persistence service in ESH [message #1776746 is a reply to message #1776714] Tue, 21 November 2017 00:10 Go to previous message
Hi Stefan,
We would like to add such functionality to ESH.
Thanks for clarifications.
Kiran.
Previous Topic:Nginx configuration to access ESH
Next Topic:Support for Channels in DiscoveryResultBuilder and/or DiscoveryResult
Current Time: Thu Nov 06 14:14:56 EST 2025
Powered by FUDForum. Page generated in 0.05754 seconds
