IllegalStateException when formatting [message #1776316] |
Wed, 15 November 2017 09:37 |
Nikita Dümmel Messages: 19 Registered: September 2017 |
Im getting following issue:
1927597 [main] ERROR org.eclipse.xtext.ui.editor.formatting2.ContentFormatter$FormattingUnitOfWork - Error formatting platform:/resource/de.ubt.ai1.athena.testPluginProject/src/test.athena: null
java.lang.IllegalStateException
at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccessBuilder.process(NodeModelBasedRegionAccessBuilder.java:229)
at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccessBuilder.process(NodeModelBasedRegionAccessBuilder.java:220)
at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccessBuilder.getEObjectToTokensMap(NodeModelBasedRegionAccessBuilder.java:87)
at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccess.<init>(NodeModelBasedRegionAccess.java:29)
at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccessBuilder.create(NodeModelBasedRegionAccessBuilder.java:58)
at org.eclipse.xtext.formatting2.regionaccess.TextRegionAccessBuilder.create(TextRegionAccessBuilder.java:37)
at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter.initRequest(ContentFormatter.java:126)
at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter.exec(ContentFormatter.java:88)
at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter$FormattingUnitOfWork.exec(ContentFormatter.java:57)
at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter$FormattingUnitOfWork.exec(ContentFormatter.java:1)
at org.eclipse.xtext.resource.OutdatedStateManager.exec(OutdatedStateManager.java:91)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.internalReadOnly(XtextDocument.java:520)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.priorityReadOnly(XtextDocument.java:485)
at org.eclipse.xtext.ui.editor.model.XtextDocument.priorityReadOnly(XtextDocument.java:142)
at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter.format(ContentFormatter.java:103)
at org.eclipse.jface.text.source.SourceViewer.doOperation(SourceViewer.java:992)
at org.eclipse.jface.text.source.projection.ProjectionViewer.doOperation(ProjectionViewer.java:1461)
at org.eclipse.ui.texteditor.TextOperationAction$1.run(TextOperationAction.java:130)
at org.eclipse.ui.texteditor.TextOperationAction.run(TextOperationAction.java:127)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.commands.ActionHandler.execute(ActionHandler.java:118)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:92)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:305)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:239)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:287)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:527)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:577)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:385)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:331)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:88)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1271)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1078)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1088)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1130)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1126)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1547)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4962)
at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:364)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4843)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:359)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5178)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2560)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3815)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
when calling the formatter on this code:
type Point : structure {
attribute x : integer;
attribute y : integer;
main {
variable a : integer;
a <-- 3;
variable b : integer;
b <-- a; // works fine
variable p : Point;
p.x <-- 2; // works fine
p.y <-- a; // IllegalStateException
_output(p);
The formatter works fine except for similar cases like in the code above.
In such cases the execution stops with the error before I even get into the formatter.
Xtend IDE and Xtext Complete SDK are updated to version 2.13.0.v20171020-0920.
The code generation works fine (with traced codegen).
The formatter is the generated stub with some extensions to see if it works:
class AthenaFormatter extends AbstractFormatter2 {
@Inject extension AthenaGrammarAccess
def dispatch void format(Program program, extension IFormattableDocument document) {
// TODO: format HiddenRegions around keywords, attributes, cross references, etc.
for (TypeDeclaration typeDeclaration : program.getTypeDeclarations()) {
typeDeclaration.format;
typeDeclaration.append[setNewLines(2)];
for (Operation operation : program.getOperations()) {
operation.format;
operation.append[setNewLines(2)];
program.getMainBlock.format;
def dispatch void format(Enumeration enumeration, extension IFormattableDocument document) {
for (EnumTypeValue enumTypeValue : enumeration.getValues()) {
enumTypeValue.format;
// TODO: implement for Composition, Operation, Block, Return, Conditional, WhileLoop, ForEachLoop, OperationCall, Attribute, Parameter, VariableDeclaration, Assignment, QualifiedAccess, Xor, Or, And, Equality, Comparison, AddSub, MulDiv, Exponent, Cast, ParenthesizedExpression, Not, Reference, ListDeclaration, ListInitRepetition, ListInitRange, ListInitElements
Nikita.
FUDForum. Page generated in 0.03944 seconds
