Home » Archived » BIRT » Memory Issues with Spudsoft Emitter when extracted with Styles & charts (Memory Issues with Spudsoft Emitter when extracted with Styles & charts )
Memory Issues with Spudsoft Emitter when extracted with Styles & charts [message #1775731] Sat, 04 November 2017 05:01
Hi Team -
I am using "uk.co.spudsoft.birt.emitters.excel" emitter to generate the report output in XLSX format.
When I extract large dataset through Spudsoft emitter the reports were occupying the entire heap memory and fails generation.
Based on my investigation, I have enabled ExtractMode if the template is not using any styles or charts which has improved the memory usage and performance.
But I want to know, whether any solution is available when the styles or charts are used? or it is there any alternative emitter to extract the report output in Excel 2010 format without these limitation.
Any help here would greatly help us.
Please let me know if you need any additional information.
Thanks In Advance,
Naveen.
Previous Topic:convert date from miladi to jalali
Next Topic:Memory Issues with Spudsoft Emitter when extracted with Styles & charts
Current Time: Wed Nov 05 14:37:28 EST 2025
Powered by FUDForum. Page generated in 0.03402 seconds
