Re: Deleting Model Elements of an Dynamic Xcore Instance with Sample Reflective Ecore Model Editor [message #1775736 is a reply to message #1775728] |
Sat, 04 November 2017 11:24 |
i wonder why it is 2 minutes. are you using java 9?. xtext(xbase) and thus xcore performance is terribly bad with java 9.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=526209
dont use xtext or xcore with j9.
=> it should be better if
BREE in Manifest is: Bundle-RequiredExecutionEnvironment: JavaSE-1.8
JRE in .classpath is: <classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.8"/>
java compiler setting in .settings/org.eclipse.jdt.core.prefs is
eclipse.preferences.version=1
org.eclipse.jdt.core.compiler.codegen.inlineJsrBytecode=enabled
org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.8
org.eclipse.jdt.core.compiler.compliance=1.8
org.eclipse.jdt.core.compiler.problem.assertIdentifier=error
org.eclipse.jdt.core.compiler.problem.enumIdentifier=error
org.eclipse.jdt.core.compiler.source=1.8
Twitter : @chrdietrich
[Updated on: Sat, 04 November 2017 11:48] Report message to a moderator
FUDForum. Page generated in 0.03724 seconds
