Eclipse RCP and Java 9 results in NoClassDefFoundError [message #1775136] |
Wed, 25 October 2017 08:18 |
i got a pure e4 RCP application and when using the latest Java 9 (9.0.1+11) i get the following error:
!ENTRY org.eclipse.osgi 4 0 2017-10-25 09:39:04.204
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/w3c/dom/stylesheets/StyleSheet
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.initializeStyling(PartRenderingEngine.java:1330)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1036)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:164)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: java.lang.ClassNotFoundException: org.w3c.dom.stylesheets.StyleSheet cannot be found by org.eclipse.e4.ui.css.core_0.10.100.v20140424-2042
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:432)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:496)
... 19 more
The application is based on Eclipse 4.4.
I tried using the approach from the Eclipse wiki ( https://wiki.eclipse.org/Configure_Eclipse_for_Java_9 ) but that didn't work.
My ini looks like this:
--launcher.GTK_version
2
--launcher.appendVmargs
-vm
/opt/jdk9/bin/java
-vmargs
-Dosgi.requiredJavaVersion=1.8
--add-modules=ALL-SYSTEM
Any help is much appreciated.
Mihael
FUDForum. Page generated in 0.02500 seconds
