Cannot update Eclipse: missing repository for 2 google inject items [message #1774621] |
Wed, 18 October 2017 00:35 |
Marc Sherman Messages: 5 Registered: October 2017 |
I have been getting the error msgs below for the past several weeks when I click on the update notification. The bundle must contain 20 line items/folders, but the missing repository error msg blocks all the updates, not just those relying on the com.google osgi's repository.
I was hoping that many people would be getting the same error msg, and that it would be fixed after a few days. So far that is not the case, so I have posted it here in the newby forum.
Thanks/Cheerss,
Marc
Eclipse version:
Version: Oxygen Release (4.7.0)
Build id: 20170620-1800
Error message:
An error occurred while collecting items to be installed
session context was:(profile=C__Users_marcs_java-oxygen2_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.google.inject,3.0.0.v201605172100
No repository found containing: osgi.bundle,com.google.inject.multibindings,3.0.0.v201605172100
Re: Cannot update Eclipse: missing repository for 2 google inject items [message #1779072 is a reply to message #1777686] |
Tue, 02 January 2018 03:21 |
John Salvo Messages: 3 Registered: December 2017 |
I had this problem as well. I have updated all other features / plugins / etc .. are are now only left with the following that cannot be updated:
Code Recommenders for Java Developers 2.5.0.v20171201-1623
Code Recommenders Mylyn Integration 2.5.0.v20171201-1623
session context was:(profile=C__eclipse-jee-oxygen_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
The "Code Recommenders" is using the the following URL in the "Available Software Sites":
http://download.eclipse.org/recommenders/updates/stable/
.. and if you look at the plugins dir:
http://download.eclipse.org/recommenders/updates/stable/?dir=plugins
.. my understanding is that, It shows that the JARs are there ( at least on the meta-data ):
com.google.inject.source_3.0.0.v201605172100.jar
com.google.inject.multibindings_3.0.0.v201605172100.jar
... so should have NOT errored out. Just not sure what the "osgi.bundle," means in front of "com.google.inject,3.0.0.v201605172100"
What I did as a workaround it was to do what Stephen did above. Specifically, that is to deselect the "Contact all update sites during install to find required software" when installing the update for "Code Recommenders".
FUDForum. Page generated in 0.07915 seconds
