Why MyDslParsingTest re-create each time? [message #1773803] |
Wed, 04 October 2017 19:52 |
Hello All,
I observe the strange behavior of build system. The Unit Test MyDslParsing.xtend was generated while project was initiated. I prefer to use clear java instead of xtend, so I set
in my mwe2 configuration file. Then I deleted xtend file and write java code instead. I was surprised that MyDslParsing.xtend generates again and again. How can switch off this strange behavior
Thanks in advance
Alex.
Re: Why MyDslParsingTest re-create each time? [message #1773867 is a reply to message #1773866] |
Thu, 05 October 2017 15:42 |
you should have content assist in mwe files
you should be able to do crtl+click and find references
language = StandardLanguage {
name = "org.xtext.example.mydsl.MyDsl"
fileExtensions = "mydsl"
serializer = {
generateStub = false
validator = {
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
junitSupport = {
Twitter : @chrdietrich
FUDForum. Page generated in 0.03554 seconds
