Home » Archived » Eclipse SmartHome » DiscoveryService registered but startScan not executed
DiscoveryService registered but startScan not executed [message #1773637] Mon, 02 October 2017 02:16 Go to next message
I've a little problem perhaps it's a comprehsension problem on my part.
I've implemented a HandlerFactory extending BaseThingHandlerFactory. My assumption was that when I start scan by pressing the button in the inbox that I get in popup for "Scan for Things" a new entry for my discovery service.
index.php/fa/30883/0/
that's my HandlerFactory extending BaseThingHandlerFactory:
protected @Nullable ThingHandler createHandler(Thing thing) {
   ThingTypeUID thingTypeUID = thing.getThingTypeUID();
   if (thingTypeUID.equals(THING_TYPE_STATION)) {
      MyBridgeHandler handler = new MyBridgeHandler((Bridge) thing);
      registerDeviceDiscoveryService(handler);
      return handler;
   return null;
private void registerDeviceDiscoveryService(MyBridgeHandler bridgHandler) {
   MyDiscoveryService discoveryService = new MyDiscoveryService (bridgHandler);
   this.discoveryServiceRegs.put(bridgHandler.getThing().getUID(), bundleContext.registerService(DiscoveryService.class.getName(), discoveryService,
                new Hashtable<String, Object>()));
and a MyDiscoveryService extending AbstractDiscoveryService:
public MyDiscoveryServiceMyBridgeHandler bridgeHandler) throws IllegalArgumentException {
   super(SEARCH_TIME);
   this.bridgeHandler = bridgeHandler;
protected void startScan() {
   some code....
When I start debugging I see that my code is executed succefully.
But why is my service not listed?
  • Attachment: paperui.jpg
    (Size: 41.35KB, Downloaded 485 times)
Re: DiscoveryService registered but startScan not executed [message #1773881 is a reply to message #1773637] Thu, 05 October 2017 23:48 Go to previous messageGo to next message
Hi Nils,
If your DiscoveryService does not depend on a specific ThingHandler, but it can discovery Things without any preconditions, then all you need to do is to register an OSGi service through declarative services (DS), see e.g. this one: https://github.com/eclipse/smarthome/blob/master/extensions/binding/org.eclipse.smarthome.binding.lifx/src/main/java/org/eclipse/smarthome/binding/lifx/internal/LifxLightDiscovery.java#L67-L68
Re: DiscoveryService registered but startScan not executed [message #1773882 is a reply to message #1773881] Thu, 05 October 2017 23:54 Go to previous messageGo to next message
If you really depend on an existing ThingHandler and thus you need to manually register it in the ThingHandlerFactory as you do, please check that you have implemented getSupportedThingTypes() in your DiscoveryService as this is used to determine, which bindings are offered for triggering a scan.
Re: DiscoveryService registered but startScan not executed [message #1773884 is a reply to message #1773882] Fri, 06 October 2017 02:05 Go to previous messageGo to next message
hi Kai,
thank you for your support! I have implemented getSupportedThingTypes() in my DiscoveryService and now it works!!!
But after your response I'm not sure if I do it right anymore. So let me explain what I'm doing.
I've a bridgeHandler which connect to a http api with username and password to get a sessionid. After connecting to the http api the bridge requests the api with the sessionid to get a json list with devices: These devices are my new discovered things.
After all the http api is a gateway to communicate with the devices. Therefore I have come to the assumption to implement a bridgehandler for the api.
Is the bridgehandler in that case the right aproach for the implementation?
Re: DiscoveryService registered but startScan not executed [message #1773931 is a reply to message #1773884] Fri, 06 October 2017 12:35 Go to previous message
Yes, this is a perfect valid case for modelling the "web account" as a bridge with a handler and then discovering the devices as things on that bridge. So all fine as you have done it!
Previous Topic:Design question: searching for things (getThingByUID)
Next Topic:Error executing maven build and resolving targed-platform
Current Time: Mon Apr 28 16:12:22 EDT 2025
Powered by FUDForum. Page generated in 0.04015 seconds
