.metadata/.log [message #1773547] |
Fri, 29 September 2017 06:46 |
Sahil Khan Messages: 1 Registered: September 2017 |
Hello people,
I have just installed eclipse oxygen on my windows 10, i am trying to launch the application but i encountered with an error which says:
An error has occurred. See the log file C:Users\.....\eclipse-workspace\.metadata\.log.
When i open the .log while here it what says
!SESSION 2017-09-29 18:36:37.593 -----------------------------------------------
eclipse.buildId=4.7.1.M20170906-1700
java.version=9
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_IN
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.osgi 4 0 2017-09-29 18:36:46.391
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:410)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:491)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:505)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:204)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:614)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
... 22 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:496)
... 24 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-09-29 18:36:46.454
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:450)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:156)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:99)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:141)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.base/java.lang.Thread.run(Thread.java:844)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
... 21 more
!SESSION 2017-09-29 18:36:59.236 -----------------------------------------------
java.version=9
!ENTRY org.eclipse.osgi 4 0 2017-09-29 18:37:00.298
!MESSAGE The -clean (osgi.clean) option was not successful. Unable to clean the storage area: C:\Users\Prathista\Downloads\eclipse\configuration\org.eclipse.osgi
!ENTRY org.eclipse.osgi 4 0 2017-09-29 18:37:15.875
!STACK 1
... 22 more
... 24 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-09-29 18:37:15.985
!STACK 0
... 21 more
!SESSION 2017-09-29 19:08:08.106 -----------------------------------------------
java.version=9
!ENTRY org.eclipse.osgi 4 0 2017-09-29 19:08:41.761
!STACK 1
... 22 more
... 24 more
I have surfed the net but found nothing that could help me.
I tried cleaning the cache in plugins, tried to run the program a admin, tried to find the .snap file but i couldn't find it.
Please help very tired fixing this.
Thanks in advance.
FUDForum. Page generated in 0.02950 seconds
