Home » Modeling » TMF (Xtext) » Build triggered when opening file in language implemented by Xtext
Re: Build triggered when opening file in language implemented by Xtext [message #1773423 is a reply to message #1773420] |
Wed, 27 September 2017 16:55 |
bautobuildjob is called from this stacktrace
Thread [main] (Suspended (breakpoint at line 523 in BuildManager))
owns: WorkspaceModifyDelegatingOperation (id=18482)
BuildManager.endTopLevel(boolean) line: 523
Workspace.endOperation(ISchedulingRule, boolean) line: 1484
Workspace.run(ICoreRunnable, ISchedulingRule, int, IProgressMonitor) line: 2253
Workspace.run(IWorkspaceRunnable, ISchedulingRule, int, IProgressMonitor) line: 2267
WorkspaceModifyDelegatingOperation(WorkspaceModifyOperation).run(IProgressMonitor) line: 128
WorkspaceOperationRunner.run(IRunnableWithProgress, ISchedulingRule) line: 73
WorkspaceOperationRunner.run(boolean, boolean, IRunnableWithProgress) line: 63
XbaseDocumentProvider(AbstractDocumentProvider).executeOperation(AbstractDocumentProvider$DocumentProviderOperation, IProgressMonitor) line: 536
XbaseDocumentProvider(FileDocumentProvider).refreshFile(IFile, IProgressMonitor) line: 967
XbaseDocumentProvider(FileDocumentProvider).refreshFile(IFile) line: 939
XbaseDocumentProvider(FileDocumentProvider).createElementInfo(Object) line: 689
XbaseDocumentProvider(XtextDocumentProvider).createElementInfo(Object) line: 270
XbaseDocumentProvider.createElementInfo(Object) line: 111
XbaseDocumentProvider(AbstractDocumentProvider).connect(Object) line: 392
XtendEditor(AbstractTextEditor).doSetInput(IEditorInput) line: 4183
XtendEditor(StatusTextEditor).doSetInput(IEditorInput) line: 257
XtendEditor(AbstractDecoratedTextEditor).doSetInput(IEditorInput) line: 1465
XtendEditor(TextEditor).doSetInput(IEditorInput) line: 150
XtendEditor(XtextEditor).doSetInput(IEditorInput) line: 247
XtendEditor(XbaseEditor).doSetInput(IEditorInput) line: 120
AbstractTextEditor$5.run(IProgressMonitor) line: 3159
ModalContext.runInCurrentThread(IRunnableWithProgress, IProgressMonitor) line: 437
ModalContext.run(IRunnableWithProgress, boolean, IProgressMonitor, Display) line: 353
WorkbenchWindow$14.run() line: 2213
BusyIndicator.showWhile(Display, Runnable) line: 70
WorkbenchWindow.run(boolean, boolean, IRunnableWithProgress) line: 2209
XtendEditor(AbstractTextEditor).internalInit(IWorkbenchWindow, IEditorSite, IEditorInput) line: 3177
XtendEditor(AbstractTextEditor).init(IEditorSite, IEditorInput) line: 3202
XtendEditor(XtextEditor).init(IEditorSite, IEditorInput) line: 288
EditorReference.initialize(IWorkbenchPart) line: 362
CompatibilityEditor(CompatibilityPart).create() line: 333
GeneratedMethodAccessor138.invoke(Object, Object[]) line: not available
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 43
Method.invoke(Object, Object...) line: 498
MethodRequestor.execute() line: 55
InjectorImpl.processAnnotated(Class<Annotation>, Object, Class<?>, PrimaryObjectSupplier, PrimaryObjectSupplier, ArrayList<Class<?>>) line: 990
InjectorImpl.processAnnotated(Class<Annotation>, Object, Class<?>, PrimaryObjectSupplier, PrimaryObjectSupplier, ArrayList<Class<?>>) line: 955
InjectorImpl.inject(Object, PrimaryObjectSupplier, PrimaryObjectSupplier) line: 124
InjectorImpl.internalMake(Class<?>, PrimaryObjectSupplier, PrimaryObjectSupplier) line: 399
InjectorImpl.make(Class<T>, PrimaryObjectSupplier) line: 318
ContextInjectionFactory.make(Class<T>, IEclipseContext) line: 162
ReflectionContributionFactory.createFromBundle(Bundle, IEclipseContext, IEclipseContext, URI) line: 105
ReflectionContributionFactory.doCreate(String, IEclipseContext, IEclipseContext) line: 74
ReflectionContributionFactory.create(String, IEclipseContext) line: 56
ContributedPartRenderer.createWidget(MUIElement, Object) line: 129
PartRenderingEngine.createWidget(MUIElement, Object) line: 992
PartRenderingEngine.safeCreateGui(MUIElement, Object, IEclipseContext) line: 661
PartRenderingEngine.safeCreateGui(MUIElement) line: 767
PartRenderingEngine.access$0(PartRenderingEngine, MUIElement) line: 738
PartRenderingEngine$2.run() line: 732
SafeRunner.run(ISafeRunnable) line: 42
PartRenderingEngine.createGui(MUIElement) line: 716
PartServiceImpl$1.handleEvent(Event) line: 104
UIEventHandler$1.run() line: 40
UISynchronizer(Synchronizer).syncExec(Runnable) line: 233
UISynchronizer.syncExec(Runnable) line: 144
Display.syncExec(Runnable) line: 4885
E4Application$1.syncExec(Runnable) line: 212
UIEventHandler.handleEvent(Event) line: 36
EventHandlerWrapper.handleEvent(Event, Permission) line: 201
EventHandlerTracker.dispatchEvent(EventHandlerWrapper, Permission, int, Event) line: 196
EventHandlerTracker.dispatchEvent(Object, Object, int, Object) line: 1
EventManager.dispatchEvent(Set<Entry<K,V>>, EventDispatcher<K,V,E>, int, E) line: 230
ListenerQueue<K,V,E>.dispatchEventSynchronous(int, E) line: 148
EventAdminImpl.dispatchEvent(Event, boolean) line: 135
EventAdminImpl.sendEvent(Event) line: 78
EventComponent.sendEvent(Event) line: 39
EventBroker.send(String, Object) line: 52
UIEventPublisher.notifyChanged(Notification) line: 60
PartStackImpl(BasicNotifierImpl).eNotify(Notification) line: 374
PartStackImpl(ElementContainerImpl<T>).setSelectedElement(T) line: 173
ModelServiceImpl.showElementInWindow(MWindow, MUIElement) line: 620
ModelServiceImpl.bringToTop(MUIElement) line: 584
PartServiceImpl.delegateBringToTop(MPart) line: 769
PartServiceImpl.bringToTop(MPart) line: 401
PartServiceImpl.showPart(MPart, EPartService$PartState) line: 1214
WorkbenchPage.busyOpenEditor(IEditorInput, String, boolean, int, IMemento, boolean) line: 3261
WorkbenchPage.access$25(WorkbenchPage, IEditorInput, String, boolean, int, IMemento, boolean) line: 3176
WorkbenchPage$10.run() line: 3158
WorkbenchPage.openEditor(IEditorInput, String, boolean, int, IMemento, boolean) line: 3153
WorkbenchPage.openEditor(IEditorInput, String, boolean, int) line: 3117
WorkbenchPage.openEditor(IEditorInput, String, boolean) line: 3107
IDE.openEditor(IWorkbenchPage, IFile, boolean, boolean) line: 563
IDE.openEditor(IWorkbenchPage, IFile, boolean) line: 518
EditorUtility.openInEditor(IFile, boolean) line: 360
EditorUtility.openInEditor(Object, boolean) line: 167
OpenAction.run(Object[]) line: 256
OpenAction.run(IStructuredSelection) line: 221
OpenAction(SelectionDispatchAction).dispatchRun(ISelection) line: 271
OpenAction(SelectionDispatchAction).run() line: 249
PackageExplorerActionGroup.handleOpen(ISelection, boolean) line: 379
PackageExplorerPart$4.open(ISelection, boolean) line: 540
OpenAndLinkWithEditorHelper$InternalListener.open(OpenEvent) line: 46
StructuredViewer$2.run() line: 851
JFaceUtil.lambda$0(ISafeRunnable) line: 44
508864177.run(ISafeRunnable) line: not available
SafeRunnable.run(ISafeRunnable) line: 173
PackageExplorerPart$PackageExplorerProblemTreeViewer(StructuredViewer).fireOpen(OpenEvent) line: 848
PackageExplorerPart$PackageExplorerProblemTreeViewer(StructuredViewer).handleOpen(SelectionEvent) line: 1163
755583709.handleOpen(SelectionEvent) line: not available
OpenStrategy.fireOpenEvent(SelectionEvent) line: 273
OpenStrategy.access$2(OpenStrategy, SelectionEvent) line: 268
OpenStrategy$1.handleEvent(Event) line: 308
EventTable.sendEvent(Event) line: 86
Display.sendEvent(EventTable, Event) line: 4272
Tree(Widget).sendEvent(Event) line: 1509
Tree(Widget).sendEvent(int, Event, boolean) line: 1532
Tree(Widget).sendEvent(int, Event) line: 1517
Tree(Widget).notifyListeners(int, Event) line: 1321
Display.runDeferredEvents() line: 4096
Display.readAndDispatch() line: 3713
PartRenderingEngine$5.run() line: 1150
Realm.runWithDefault(Realm, Runnable) line: 336
PartRenderingEngine.run(MApplicationElement, IEclipseContext) line: 1039
E4Workbench.createAndRunUI(MApplicationElement) line: 153
Workbench.lambda$3(Display, WorkbenchAdvisor, int[]) line: 680
321795476.run() line: not available
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 594
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 148
IDEApplication.start(IApplicationContext) line: 151
EclipseAppHandle.run(Object) line: 196
EclipseAppLauncher.runApplication(Object) line: 134
EclipseAppLauncher.start(Object) line: 104
EclipseStarter.run(Object) line: 388
EclipseStarter.run(String[], Runnable) line: 243
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 62
Main.invokeFramework(String[], URL[]) line: 653
Main.basicRun(String[]) line: 590
Main.run(String[]) line: 1499
Main.main(String[]) line: 1472
Twitter : @chrdietrich
Re: Build triggered when opening file in language implemented by Xtext [message #1773839 is a reply to message #1773574] |
Thu, 05 October 2017 12:16 |
Minh Quang Tran Messages: 19 Registered: September 2017 |
Being desperate, I tried to override XtextDocumentProvider and remove the refresh part manually. It seems to work in our N4JS IDE. Admittedly, it is really ugly.
* This class customizes XtextDocumentProvider to prevent builds from being triggered when opening files. See:
* https://www.eclipse.org/forums/index.php/t/1089089/
public class N4JSDocumentProvider extends XtextDocumentProvider {
protected ElementInfo createElementInfo(Object element) throws CoreException {
ElementInfo info;
if (isWorkspaceExternalEditorInput(element)) {
IDocument document = null;
IStatus status = null;
try {
document = createDocument(element);
} catch (CoreException x) {
status = x.getStatus();
document = createEmptyDocument();
info = new URIInfo(document, createAnnotationModel(element));
info.fStatus = status;
} else {
info = _createElementInfo(element);
registerAnnotationInfoProcessor(info);
return info;
/** Copied from {@link FileDocumentProvider#createElementInfo} */
private ElementInfo _createElementInfo(Object element) throws CoreException {
if (element instanceof IFileEditorInput) {
IFileEditorInput input = (IFileEditorInput) element;
// Custom behavior: Do NOT refresh file
// try {
// refreshFile(input.getFile());
// } catch (CoreException x) {
// handleCoreException(x, TextEditorMessages.FileDocumentProvider_createElementInfo);
IDocument d = null;
IStatus s = null;
try {
d = createDocument(element);
handleCoreException(x, "N4JSDocumentProvider.createElementInfo");
s = x.getStatus();
d = createEmptyDocument();
// Set the initial line delimiter
if (d instanceof IDocumentExtension4) {
String initalLineDelimiter = getLineDelimiterPreference(input.getFile());
if (initalLineDelimiter != null)
((IDocumentExtension4) d).setInitialLineDelimiter(initalLineDelimiter);
IAnnotationModel m = createAnnotationModel(element);
FileSynchronizer f = new FileSynchronizer(input);
f.install();
FileInfo info = new FileInfo(d, m, f);
info.fModificationStamp = computeModificationStamp(input.getFile());
info.fStatus = s;
info.fEncoding = getPersistedEncoding(element);
// info.fBOM = getBOM(element);
// Use reflection to set the private field info.fBOM
Field field;
try {
field = FileInfo.class.getDeclaredField("fBOM");
field.setAccessible(true);
field.set(info, getBOM(element));
} catch (NoSuchFieldException | SecurityException e) {
// Do nothing
} catch (IllegalArgumentException x) {
// Do nothing
} catch (IllegalAccessException x) {
// Do nothing
* The code below is a no-op in the implementation in this class because the info is not yet stored in the
* element map. Calling to not break clients who have overridden the method. see
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=109255
cacheEncodingState(element);
return info;
return super.createElementInfo(element);
* Returns the default line delimiter preference for the given file.
* @param file
* the file
* @return the default line delimiter
* @since 3.1
private String getLineDelimiterPreference(IFile file) {
IScopeContext[] scopeContext;
if (file != null && file.getProject() != null) {
// project preference
scopeContext = new IScopeContext[] { new ProjectScope(file.getProject()) };
String lineDelimiter = Platform.getPreferencesService().getString(Platform.PI_RUNTIME,
Platform.PREF_LINE_SEPARATOR, null, scopeContext);
if (lineDelimiter != null)
return lineDelimiter;
// workspace preference
scopeContext = new IScopeContext[] { InstanceScope.INSTANCE };
return Platform.getPreferencesService().getString(Platform.PI_RUNTIME, Platform.PREF_LINE_SEPARATOR, null,
scopeContext);
* Returns whether the underlying file has a BOM.
* @param element
* the element, or <code>null</code>
* @return <code>true</code> if the underlying file has BOM
private byte[] getBOM(Object element) {
IFile file = ((IFileEditorInput) element).getFile();
if (file != null) {
try {
IContentDescription description = file.getContentDescription();
if (description != null)
return (byte[]) description.getProperty(IContentDescription.BYTE_ORDER_MARK);
} catch (CoreException ex) {
return null;
return null;
Current Time: Fri Apr 26 14:50:28 GMT 2024
Powered by FUDForum. Page generated in 0.06260 seconds
