EPSILON Editor Performance Problem: disable online validation? [message #1773153] |
Fri, 22 September 2017 06:49  |
Hi all,
I am currently editing very large .eol files (>2000 loc) and I experience some performance problem in Eclipse (Java memory exceptions, very slow editing).
Is it possible to enable/disable the online validation of EPSILON files?
Or can you suggest the best eclipse.ini configuration to edit very large EPSILON files?
Finally, due to some project constraints I installed EPSILON on Eclipse Mars2. Therefore, I do not know if similar issues have been solved in latest releases.
Thanks in advance for any help.
cheers,
Luca
[Updated on: Fri, 22 September 2017 06:50] by Moderator
FUDForum. Page generated in 0.04512 seconds
