Home » Newcomers » Newcomers » Unhandled event loop exception and outOfMemory when sharing project(Eclipse Oxygen outOfMomery when sharing project)
Unhandled event loop exception and outOfMemory when sharing project [message #1772391] Fri, 08 September 2017 09:44 Go to next message
index.php/fa/30671/0/The Eclipse always hangs and then throws a "Unhandled event loop exception" when I share a project (Team->Share project). There is outOfMemory in the .log, I tried to given larger memory but that did not work.
$ tail -n 100 metadata.log
!MESSAGE An error occurred
!STACK 0
	at com.ibm.team.repository.rcp.ui.internal.menus.ActionExtContributionItem$1.run(ActionExtContributionItem.java:42)
	at com.ibm.team.repository.rcp.ui.internal.utils.WorkQueue.doUpdate(WorkQueue.java:83)
	at com.ibm.team.repository.rcp.ui.internal.utils.WorkQueue.access$3(WorkQueue.java:55)
	at com.ibm.team.repository.rcp.ui.internal.utils.WorkQueue$2.run(WorkQueue.java:46)
	at com.ibm.team.repository.rcp.ui.internal.utils.WorkQueue$1.run(WorkQueue.java:36)
	at org.eclipse.core.databinding.observable.Realm$1.run(Realm.java:149)
	at org.eclipse.core.databinding.observable.Realm.safeRun(Realm.java:153)
	at org.eclipse.jface.databinding.swt.DisplayRealm.access$0(DisplayRealm.java:1)
	at org.eclipse.jface.databinding.swt.DisplayRealm$1.run(DisplayRealm.java:67)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:37)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4033)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3700)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1044)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
!ENTRY org.eclipse.core.jobs 4 2 2017-09-08 20:20:12.148
!MESSAGE An internal error occurred during: "Deferred storing of feeds".
!STACK 0
java.lang.OutOfMemoryError: Java heap space
	at sun.util.locale.provider.DateFormatSymbolsProviderImpl.getInstance(DateFormatSymbolsProviderImpl.java:85)
	at java.text.DateFormatSymbols.getProviderInstance(DateFormatSymbols.java:364)
	at java.text.DateFormatSymbols.getInstance(DateFormatSymbols.java:340)
	at java.util.Calendar.getDisplayName(Calendar.java:2110)
	at java.text.SimpleDateFormat.subFormat(SimpleDateFormat.java:1125)
	at java.text.SimpleDateFormat.format(SimpleDateFormat.java:966)
	at java.text.SimpleDateFormat.format(SimpleDateFormat.java:936)
	at org.eclipse.emf.ecore.impl.EFactoryImpl$SafeSimpleDateFormat.format(EFactoryImpl.java:787)
	at java.text.DateFormat.format(DateFormat.java:345)
	at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.convertEDateToString(EcoreFactoryImpl.java:462)
	at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.convertToString(EcoreFactoryImpl.java:193)
	at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.convertToString(XMLHelperImpl.java:1610)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.getDatatypeValue(XMLSaveImpl.java:3108)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveDataTypeSingle(XMLSaveImpl.java:1698)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1280)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1224)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XMLSaveImpl.java:2716)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSaveImpl.java:1181)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSaveImpl.java:1042)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany(XMLSaveImpl.java:2417)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1553)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedSingle(XMLSaveImpl.java:2403)
!ENTRY org.eclipse.core.jobs 4 2 2017-09-08 20:20:48.203
!MESSAGE Unhandled error
!STACK 0
!STACK 0
	at java.util.HashMap.newNode(HashMap.java:1742)
	at java.util.HashMap.putVal(HashMap.java:641)
	at java.util.HashMap.put(HashMap.java:611)
	at java.util.HashSet.add(HashSet.java:219)
	at org.eclipse.core.internal.jobs.JobManager.changeState(JobManager.java:455)
	at org.eclipse.core.internal.jobs.JobManager.nextJob(JobManager.java:1129)
	at org.eclipse.core.internal.jobs.JobManager.startJob(JobManager.java:1603)
	at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPool.java:221)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:52)
!ENTRY org.eclipse.core.jobs 4 2 2017-09-08 20:20:48.211
!MESSAGE An internal error occurred during: "Sharing Projects".
!STACK 0
Please help me. Thanks!
Re: Unhandled event loop exception and outOfMemory when sharing project [message #1772413 is a reply to message #1772391] Fri, 08 September 2017 16:57 Go to previous message
As I said on your other post on the JDT forum, it's best to ask on an IBM forum specific to the technology you're using.
Previous Topic:Highlighting code block in Oxygen ?
Next Topic:Team menu not showing after installing eGit in Eclipse Oxygen
Current Time: Fri Sep 26 17:04:12 EDT 2025
Powered by FUDForum. Page generated in 0.08500 seconds
