Home » Eclipse Projects » Virgo » SLF4J distribution changed in 3.7.x(JCL and LOG4J binder instead of extender)
SLF4J distribution changed in 3.7.x [message #1772292] Thu, 07 September 2017 12:20 Go to next message
Hi, I'm updating our Virgo Tomcat Server 3.6.4 to 3.7.2. We noticed a change in the distribution of the SFL4J libraries.
In 3.6.4 is distributed SLF4J with api, JUL, JCL and LOG4J extender. So that bundles that import java and apache loggers are redirected on SLF4J that logs delegating to an installed binder (logback).
The name of jar are in P2 form <bundle symbolic name>.<version with timestamp>.jar
  • org.slf4j.api_1.7.2.v20121108-1250
  • org.slf4j.jcl_1.7.2.v20121108-1250 (extender)
  • org.slf4j.jul_1.7.2.v20121108-1250 (extender)
  • org.slf4j.log4j_1.7.2.v20130115-1340 (extender)
  • org.slf4j.nop_1.7.2.v201212060727 (binder)
  • ch.qos.logback.slf4j_1.0.7.v20121108-1250 (binder)
The virgo 3.7.2 distribuites SLF4J with api and JUL extenders. So only bundles that import java loggers is redirect on SLF4J that delegates to one of the installed binder (JUL, LOG4J and LOGBACK).
The name of jar are in groovy form (maybe, are not maven)
  • slf4j_api-1.7.25
  • slf4j_jcl-1.7.25 (binder)
  • slf4j_log4j12-1.7.25 (binder)
  • jul_to-slf4j-1.7.25 (extender)
  • ch.qos.logback.classic_1.2.3 (binder)
Now the question is: Why the centralisation to SLF4J (that redirect logs on a single implementation) was removed?
What happen if a third party library logs to log4j ? Where is redirect it's log since log4j is not configured.
Maybe some changes in the compilation system led to the mistake of the JCL and LOG4J binders instead of the extender.
[Updated on: Fri, 08 September 2017 09:29] by Moderator
Re: SLF4J distribution changed in 3.7.x [message #1772380 is a reply to message #1772292] Fri, 08 September 2017 09:20 Go to previous messageGo to next message
Hi Nikolas,
If I understand correctly you are saying that Virgo 3.7 is different from Virgo 3.6 because:
  • Virgo 3.6 shipped with Logback as the logging framework, used SLF4J for its own logging (delegating to logback), and also included some SLF4J bridges [1] for other popular logging frameworks (Jakarta Commons Logging, Log4j etc.) to ensure that any deployed bundle would be logging via SLF4J and therefore via Logback
  • Virgo 3.7 still includes Logback and SLF4J but you found out that it no more includes the bridges but instead it includes adapters to use JCL or Log4J instead of logback, which seems incorrect because you should only have one backend (logback) and bundles depending on e.g. log4j will now no more resolve unless the log4j bridge is added to the repository
and you are wondering whether this was done on purpose or was a mistake due to the confusing Jar names. Well, I don't know the answer, but maybe Daniel will comment on this.
[1] https://www.slf4j.org/legacy.html
Re: SLF4J distribution changed in 3.7.x [message #1772383 is a reply to message #1772380] Fri, 08 September 2017 09:30 Go to previous messageGo to next message
you understand it well
Re: SLF4J distribution changed in 3.7.x [message #1772387 is a reply to message #1772383] Fri, 08 September 2017 09:35 Go to previous messageGo to next message
Hi Nikolas,
It really looks as if the move away from ANT into Gradle caused this change. Can you please open a Bug for this, then will address this for 3.8.0.
Dani
Re: SLF4J distribution changed in 3.7.x [message #1775201 is a reply to message #1772383] Thu, 26 October 2017 04:33 Go to previous message
Hi Nikolas
Could you have a look at the latest build [1] from master to verify what has been changed regarding the slf4j distribution in Virgo?
Please let know if it now looks ok for you as well.
[1] https://hudson.eclipse.org/virgo/view/Virgo/job/virgo-master/1043/artifact/packaging/tomcat-server/build/distributions/virgo-tomcat-server-latest.zip
Previous Topic:Virgo tooling and Oxygen
Next Topic:How to include a managed service factory configuration artifact in a plan?
Current Time: Sat Jun 21 01:57:50 EDT 2025
Powered by FUDForum. Page generated in 0.16122 seconds
