Home » Eclipse Projects » Model Driven Health Tools » Error while creating a new CDA model(when i try to create a new cda model using eclipse(mars 2),it gives a null pointer exception )
Error while creating a new CDA model [message #1771866] Thu, 31 August 2017 09:36 Go to next message
Hello Sean,
I wanted to work on new CDA model.Followed relevant threads and added .psf file to the workspace and also used eclipse 'update site' for my mars version.While trying to create new CDA model named "testmodel",i get the following error
 5ERROR:   Package "<<codegenSupport>> <Package> testmodel" must import the CDA and HL7 datatypes packages.
    [cdatools] Validation found one or more errors in the UML model.
    [cdatools] 	at org.eclipse.mdht.uml.cda.ant.taskdefs.ValidateModel.validateUML(ValidateModel.java:87)
    [cdatools] 	at org.eclipse.mdht.uml.cda.ant.taskdefs.ValidateModel.doExecute(ValidateModel.java:48)
    [cdatools] 	at org.eclipse.mdht.uml.cda.ant.taskdefs.CDAModelingSubTask.execute(CDAModelingSubTask.java:62)
    [cdatools] 	at org.eclipse.mdht.uml.cda.ant.taskdefs.CDAModelingTask.execute(CDAModelingTask.java:201)
    [cdatools] 	at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:293)
    [cdatools] 	at sun.reflect.GeneratedMethodAccessor98.invoke(Unknown Source)
    [cdatools] 	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    [cdatools] 	at java.lang.reflect.Method.invoke(Method.java:498)
    [cdatools] 	at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
    [cdatools] 	at org.apache.tools.ant.Task.perform(Task.java:348)
    [cdatools] 	at org.apache.tools.ant.Target.execute(Target.java:435)
    [cdatools] 	at org.apache.tools.ant.Target.performTasks(Target.java:456)
    [cdatools] 	at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1405)
    [cdatools] 	at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
    [cdatools] 	at org.eclipse.ant.internal.core.ant.EclipseSingleCheckExecutor.executeTargets(EclipseSingleCheckExecutor.java:34)
    [cdatools] 	at org.apache.tools.ant.Project.executeTargets(Project.java:1260)
    [cdatools] 	at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:441)
    [cdatools] 	at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:105)
    [cdatools] 	at org.apache.tools.ant.Project.executeTarget(Project.java:1376)
    [cdatools] 	at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
    [cdatools] 	at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:36)
    [cdatools] 	at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:705)
    [cdatools] 	at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:527)
    [cdatools] 	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    [cdatools] 	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    [cdatools] 	at org.eclipse.ant.core.AntRunner.run(AntRunner.java:371)
    [cdatools] 	at org.eclipse.ant.internal.launching.launchConfigurations.AntLaunchDelegate.runInSameVM(AntLaunchDelegate.java:290)
    [cdatools] 	at org.eclipse.ant.internal.launching.launchConfigurations.AntLaunchDelegate.launch(AntLaunchDelegate.java:249)
    [cdatools] 	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:885)
    [cdatools] 	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
    [cdatools] 	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:731)
    [cdatools] 	at org.eclipse.mdht.uml.cda.ui.builder.CDABuilder.runTransformation(CDABuilder.java:502)
    [cdatools] 	at org.eclipse.mdht.uml.cda.ui.builder.CDABuilder.runTransformation(CDABuilder.java:434)
    [cdatools] 	at org.eclipse.mdht.uml.cda.ui.wizards.NewCDAModelProjectWizard$1.run(NewCDAModelProjectWizard.java:261)
    [cdatools] 	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:463)
    [cdatools] 	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:371)
    [cdatools] 	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:500)
    [cdatools] 	at org.eclipse.mdht.uml.cda.ui.wizards.NewCDAModelProjectWizard.performFinish(NewCDAModelProjectWizard.java:147)
    [cdatools] 	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:799)
    [cdatools] 	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:429)
    [cdatools] 	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:619)
    [cdatools] 	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
    [cdatools] 	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    [cdatools] 	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4230)
    [cdatools] 	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1491)
    [cdatools] 	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1514)
    [cdatools] 	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1499)
    [cdatools] 	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1299)
    [cdatools] 	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4072)
    [cdatools] 	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3698)
    [cdatools] 	at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
    [cdatools] 	at org.eclipse.jface.window.Window.open(Window.java:803)
    [cdatools] 	at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:269)
    [cdatools] 	at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:290)
    [cdatools] 	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
    [cdatools] 	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
    [cdatools] 	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
    [cdatools] 	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
    [cdatools] 	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
    [cdatools] 	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
    [cdatools] 	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
    [cdatools] 	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
    [cdatools] 	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
    [cdatools] 	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
    [cdatools] 	at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:343)
    [cdatools] 	at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:160)
    [cdatools] 	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
    [cdatools] 	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
    [cdatools] 	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)
    [cdatools] 	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
    [cdatools] 	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
    [cdatools] 	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
    [cdatools] 	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
    [cdatools] 	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
    [cdatools] 	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
    [cdatools] 	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
    [cdatools] 	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
    [cdatools] 	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    [cdatools] 	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
    [cdatools] 	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
    [cdatools] 	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
    [cdatools] 	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
    [cdatools] 	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
    [cdatools] 	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
    [cdatools] 	at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
Re: Error while creating a new CDA model [message #1771872 is a reply to message #1771866] Thu, 31 August 2017 10:25 Go to previous message
We have moved onto using OOMPH for install but are behind in some of the documentation - so i do apologize
Here is the modeler setup
first
Download appropriate eclipse installer from here
https://wiki.eclipse.org/Eclipse_Installer
then download MDHTModeler.setup
from
https://github.com/mdht/mdht-models/tree/develop/releng/setups
or see attachment
Then Use the Eclipse Installer to install MDHTModeler.setup file using the advanced mode
This will install a new version of NEON with the correct plugins
It is a work in progress so it is beta more then a release
we will be going to oxygen asap
thanks
sean
Previous Topic:Error while creating a new CDA model
Next Topic:cda dependency
Current Time: Thu Nov 06 06:57:54 EST 2025
Powered by FUDForum. Page generated in 0.14750 seconds
