Home » Modeling » TMF (Xtext) » [LSP] IOutputConfigurationProvider is not working with LSP(But works with Eclipse)
[LSP] IOutputConfigurationProvider is not working with LSP [message #1771044] Mon, 21 August 2017 12:52 Go to next message
Krzysztof Drozd is currently offline Krzysztof DrozdFriend
I'll start with a question: What I'm missing for LSP as IOutputConfigurationProvider works fine with Eclipse and not with LSP?
I would like to generate my files to 'output' directory instead of 'src-out'.
So I implemented IOutputConfigurationProvider like this:
import static org.eclipse.xtext.xbase.lib.CollectionLiterals.newHashSet;
import java.util.Set;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.xtext.generator.IFileSystemAccess;
import org.eclipse.xtext.generator.IOutputConfigurationProvider;
import org.eclipse.xtext.generator.OutputConfiguration;
public class DSDOutputConfigurationProvider implements IOutputConfigurationProvider {
	public static final String GEN_DSD_OUTPUT = "output/";
	public Set<OutputConfiguration> getOutputConfigurations() {
		OutputConfiguration dsdOutput = new OutputConfiguration(IFileSystemAccess.DEFAULT_OUTPUT);
		dsdOutput.setDescription("Output folder");
		dsdOutput.setOutputDirectory(GEN_DSD_OUTPUT);
		dsdOutput.setOverrideExistingResources(true);
		dsdOutput.setCreateOutputDirectory(true);
		dsdOutput.setCleanUpDerivedResources(true);
		dsdOutput.setSetDerivedProperty(true);
		dsdOutput.setInstallDslAsPrimarySource(true);
		return newHashSet(dsdOutput);
	public Set<OutputConfiguration> getOutputConfigurations(Resource context) {
		return this.getOutputConfigurations();
	public Set<OutputConfiguration> getOutputConfigurations(ResourceSet context) {
With this binding in DLSRuntimeModule:
	override configure(Binder binder) {
		super.configure(binder);
		binder.bind(IOutputConfigurationProvider).to(DSDOutputConfigurationProvider).in(Singleton);
And it works fine when I'm using Eclipse. But when I use it with VSCode as LSP files are still generated to 'src-out'
Krzysiek
Re: [LSP] IOutputConfigurationProvider is not working with LSP [message #1771091 is a reply to message #1771044] Mon, 21 August 2017 20:27 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
afaik you need to bind to IContextualOutputConfigurationProvider
Twitter : @chrdietrich
Re: [LSP] IOutputConfigurationProvider is not working with LSP [message #1771201 is a reply to message #1771091] Tue, 22 August 2017 20:34 Go to previous message
It works :)
Thank you very much!
Krzysiek
Previous Topic:Exclude Keyword from ID in specific Context
Next Topic:SecurityException when I use my modified org.eclipse.xtext to run "Generate Xtext Artifacts&
Current Time: Fri Apr 26 10:51:54 GMT 2024
Powered by FUDForum. Page generated in 0.01724 seconds
