Home » Eclipse Projects » Model Driven Health Tools » Using CDAUtil's Load(Accessing individual sections using CDAUtil's load)
Using CDAUtil's Load [message #1771018] Mon, 21 August 2017 04:22 Go to next message
Hello Community,
I have downloaded MDHT Runtimes from the following location.
LINK:
github.com/mdht/mdht-models
/releases/download/v3.0.0.20170725_Consol2/MDHT_CCDA_R2.1_R1.1_MU2_20170725_build.zip
I believe they are the latest Runtimes (as it shows version 3.0.0.xxx).
After that, I followed the examples provided in the following page:
www.cdatools.com/docs/
developeruserguide/org.openhealthtools.mdht.cda.doc.developerguide/tasks/t_Consume_CDA.html
The following code throws a ClassCastException as already discussed in a different post in the MDHT community forum. (Google for 'eclipse ClinicalDocumentImpl cannot be cast ContinuityOfCareDocument' and the first result is the topic I am talking about).
ContinuityOfCareDocument ccdDocument1 =
 (ContinuityOfCareDocument) CDAUtil.load(new FileInputStream("/tmp/SampleCCDDocument.xml"), result);
java.lang.ClassCastException: org.eclipse.mdht.uml.cda.impl.ClinicalDocumentImpl cannot be cast to org.openhealthtools.mdht.uml.cda.consol.ContinuityOfCareDocument
So, I tried to do this instead:
ClinicalDocument ccdDocument = (ClinicalDocument) CDAUtil
This compiled/ran fine without any exceptions and I am able to get the list of document sections, their codes etc... as shown in the following code.
EList<Section> sections = ccdDocument.getAllSections();
            System.out.println("# of sections (==> " + sections.size());
            for (Section sec : sections) {
                System.out.println("Section code ==> " + sec.getCode().getCode() + ", # of entries  ==> "
                        + sec.getEntries().size() + ", class code ==> " + sec.getClassCode().getName()
                        + ", template ID ==> " + sec.getTemplateIds().get(0) + ", type ID ==>" + sec.getTypeId()
                        + ", title ==> " + sec.getTitle());
But, on the other hand, querying for a specific section does not return anything.
Query query = new Query(ccdDocument);
            AdvanceDirectivesSection section = query.getSection(AdvanceDirectivesSection.class);
FYI, I am following the examples provided in the link below to query for a specific document section:
LINK:
www.cdatools.com
/docs/developeruserguide/org.openhealthtools.mdht.cda.doc.developerguide/tasks/t_Query_CDA.html
Please see the sample CCD document I am using for this Query exercise.
Please let me know if I am missing anything. I would like to use the MDHT API to parse the CDA documents.
regards,
Karthik
Re: Using CDAUtil's Load [message #1771077 is a reply to message #1771018] Mon, 21 August 2017 14:19 Go to previous messageGo to next message
Most of the results depend on the contents of the document and which libraries you have loaded; The samples on CDATools are a bit dated
There are some updated ones here
https://github.com/mdht/mdht-models/tree/develop/examples
in particular you can use the maven one
Re: Using CDAUtil's Load [message #1771078 is a reply to message #1771018] Mon, 21 August 2017 14:19 Go to previous messageGo to next message
Re: Using CDAUtil's Load [message #1771149 is a reply to message #1771078] Tue, 22 August 2017 09:37 Go to previous messageGo to next message
Hi Sean,
Thank you for your reply.
I tried out my code with different samples available in the link you provided, but with no luck. Let me elaborate what I have now:
1) I am able to successfully load a ClinicalDocument from the sample CCDA example.
2) I am able to print out all the meta information for the clinical documents (i.e., author, title, mood code, record targets size etc...)
3) I am able to print the list of section codes available in the document.
4) I am NOT able to access a section (eg., MedicationSection) from the loaded clinical document. For example:
MedicationsSection medSect = ccdDocument.getMedicationsSection();
 System.out.println("medSect id = " + medSect.getSectionId());
I am wondering whether I am including all the relevant libraries (JARs) so that access by specific section is also possible.
Could you please point me to a project/article that outlines all the required mdht and non-mdht libraries that will be required to achieve what I am trying to do.
Thanks for your help!
Karthik
Re: Using CDAUtil's Load [message #1771367 is a reply to message #1771149] Thu, 24 August 2017 07:45 Go to previous messageGo to next message
Hi Sean,
I was able to make some progress with a Discharge Summary example and a different CCD example.
regards,
Karthik
Re: Using CDAUtil's Load [message #1773451 is a reply to message #1771367] Wed, 27 September 2017 23:46 Go to previous message
HI Karthik,
The consolidated (you can look it up) CDA is the way to go; plus use loadAs method of CDAUtil
So something like
ContinuityOfCareDocument ccd = (ContinuityOfCareDocument) CDAUtil.loadAs(dataHandler.getInputStream() /*or whatever inputstream you have*/
, ConsolPackage.eINSTANCE.getContinuityOfCareDocument());
Previous Topic:cda dependency
Next Topic:How to set sdtc:deceasedInd on a patient
Current Time: Thu Nov 06 06:57:56 EST 2025
Powered by FUDForum. Page generated in 0.47000 seconds
