Kura on Raspberry PI - Remote management is not working [message #1770235] |
Wed, 09 August 2017 09:54 |
Praveen Reddy Messages: 14 Registered: June 2017 |
Hi All,
I installed Kura 3.0 in Raspberry PI device and trying remote management using Deploy-V2.
In that process it is observed that, org.eclipse.kura.core.deployment.ClouddeploymentHandlerV2 is in 'Unsatisfied state'
I checked 'ls', 'ss' and comp on OSGi console.
It is giving error on cloud.CloudService and data.transport.mqtt.MqttDataTransport even, those services are installed and active.
Appreciate your thoughts in resolving this.
Logs are:
All Components:
ID State Component Name Located in bundle
1 Active org.eclipse.equinox.event org.eclipse.equinox.event(bid=8)
2 Active org.eclipse.kura.data.DataService org.eclipse.kura.core(bid=53)
3 Active org.eclipse.kura.db.DbService org.eclipse.kura.core(bid=53)
4 Active org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport org.eclipse.kura.core(bid=53)
5 Active org.eclipse.kura.ssl.SslManagerService org.eclipse.kura.core(bid=53)
6 Active org.eclipse.kura.system.SystemService org.eclipse.kura.core(bid=53)
7 Active org.eclipse.kura.system.SystemAdminService org.eclipse.kura.core(bid=53)
8 Active org.eclipse.kura.certificate.CertificatesService org.eclipse.kura.core.certificates(bid=54)
9 Active org.eclipse.kura.cloud.CloudService org.eclipse.kura.core.cloud(bid=55)
10 Registered org.eclipse.kura.cloud.CloudCallService org.eclipse.kura.core.cloud(bid=55)
11 Active org.eclipse.kura.core.cloud.factory.DefaultCloudServiceFactory org.eclipse.kura.core.cloud(bid=55)
12 Unsatisfied org.eclipse.kura.cloud.app.command.CommandCloudApp org.eclipse.kura.core.cloud(bid=55)
13 Active org.eclipse.kura.core.comm.CommConnectionFactory org.eclipse.kura.core.comm(bid=56)
14 Active org.eclipse.kura.core.configuration.CloudConfigurationHandler org.eclipse.kura.core.configuration(bid=57)
15 Active org.eclipse.kura.configuration.ConfigurationService org.eclipse.kura.core.configuration(bid=57)
16 Active org.eclipse.kura.crypto.CryptoService org.eclipse.kura.core.crypto(bid=58)
17 Unsatisfied org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2 org.eclipse.kura.core.deployment(bid=59)
18 Active org.eclipse.kura.log.LoggerService org.eclipse.kura.core.log(bid=60)
19 Active org.eclipse.kura.status.CloudConnectionStatusService org.eclipse.kura.core.status(bid=62)
20 Active org.eclipse.kura.deployment.agent org.eclipse.kura.deployment.agent(bid=63)
Dynamic information :
*The component is NOT satisfied
The following references are not satisfied:
Reference[name = CloudService, interface = org.eclipse.kura.cloud.CloudService, policy = static, cardinality = 1..1, target = (kura.service.pid=org.eclipse.kura.cloud.CloudService), bind = setCloudService, unbind = unsetCloudService]
Reference[name = DataTransportService, interface = org.eclipse.kura.data.DataTransportService, policy = static, cardinality = 1..1, target = (kura.service.pid=org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport), bind = setDataTransportService, unbind = unsetDataTransportService]
Component configurations :
Configuration properties:
CloudService.target = (kura.service.pid=org.eclipse.kura.cloud.CloudService)
component.name = org.eclipse.kura.core.deployment.CloudDeploymentHandlerV2
DataTransportService.target = (kura.service.pid=org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport)
component.id = 34
Instances:
Thank you.
With Best Regards,
Praveen.B
FUDForum. Page generated in 0.03267 seconds
