| Eclipse Neon Crashes on MacOS High Sierra [message #1770190] |
Tue, 08 August 2017 21:17  |
I have MacOS High Sierra, I downloaded eclipse Neon and I moved the file to the application folder. When I start eclipse and select a new workspace it shows the intro window for a second and it suddently closes. When I start eclipse again with the previous workspace I get the following error:
See the log file /Users/...../workspace/.metadata/.log
and the following lines are the content of the log file:
!SESSION 2017-08-08 20:01:14.727 -----------------------------------------------
eclipse.buildId=4.6.3.M20170301-0400
java.version=1.8.0_144
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/saadaoui/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/saadaoui/.eclipse_keyring
!ENTRY org.eclipse.core.net 1 0 2017-08-08 20:01:23.777
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.ui 4 0 2017-08-08 20:01:27.856
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4559)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.graphics.Region.<init>(Region.java:87)
at org.eclipse.swt.graphics.Region.<init>(Region.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.CTabRendering.drawTabBody(CTabRendering.java:377)
at org.eclipse.e4.ui.workbench.renderers.swt.CTabRendering.draw(CTabRendering.java:223)
at org.eclipse.swt.custom.CTabFolder.onPaint(CTabFolder.java:2035)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:339)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1509)
at org.eclipse.swt.widgets.Control.drawWidget(Control.java:1275)
at org.eclipse.swt.widgets.Widget.drawRect(Widget.java:765)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5711)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
at org.eclipse.swt.widgets.Display.applicationNextEventMatchingMask(Display.java:5084)
at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5465)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSApplication.nextEventMatchingMask(NSApplication.java:94)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
!ENTRY org.eclipse.ui.workbench 4 0 2017-08-08 20:01:27.865
!MESSAGE An unexpected exception was thrown.
!STACK 0
at org.eclipse.swt.widgets.Display.getSystemImageForID(Display.java:1948)
at org.eclipse.swt.widgets.Display.getSystemImage(Display.java:1984)
at org.eclipse.ui.internal.statushandlers.LabelProviderWrapper.getSWTImage(LabelProviderWrapper.java:242)
at org.eclipse.ui.internal.statushandlers.LabelProviderWrapper.getImage(LabelProviderWrapper.java:226)
at org.eclipse.ui.internal.statushandlers.InternalDialog.createTitleArea(InternalDialog.java:250)
at org.eclipse.ui.internal.statushandlers.InternalDialog.createDialogArea(InternalDialog.java:217)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:767)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1095)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.doAddStatusAdapter(WorkbenchStatusDialogManagerImpl.java:261)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.addStatusAdapter(WorkbenchStatusDialogManagerImpl.java:197)
at org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager.addStatusAdapter(WorkbenchStatusDialogManager.java:158)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.showStatusAdapter(WorkbenchErrorHandler.java:80)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.handle(WorkbenchErrorHandler.java:49)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.handle(IDEWorkbenchErrorHandler.java:101)
at org.eclipse.ui.internal.WorkbenchErrorHandlerProxy.handle(WorkbenchErrorHandlerProxy.java:31)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:204)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:246)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:257)
at org.eclipse.ui.application.WorkbenchAdvisor.eventLoopException(WorkbenchAdvisor.java:330)
at org.eclipse.ui.internal.Workbench$3.eventLoopException(Workbench.java:531)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.handle(PartRenderingEngine.java:1143)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1133)
!ENTRY org.eclipse.ui 4 0 2017-08-08 20:01:27.868
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-08 20:01:27.929
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-08-08 20:01:27.930
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-08 20:01:27.933
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-08 20:01:28.066
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-08-08 20:01:28.068
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-08 20:01:28.071
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-08 20:01:28.308
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-08-08 20:01:28.309
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-08 20:01:28.312
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-08 20:01:28.692
!MESSAGE Exceptions during shutdown
!STACK 0
at org.eclipse.swt.widgets.Display.getSystemImage(Display.java:1991)
at org.eclipse.jface.dialogs.IconAndMessageDialog.lambda$0(IconAndMessageDialog.java:292)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4814)
at org.eclipse.jface.dialogs.IconAndMessageDialog.getSWTImage(IconAndMessageDialog.java:292)
at org.eclipse.jface.dialogs.IconAndMessageDialog.getInfoImage(IconAndMessageDialog.java:254)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.getImage(ProgressMonitorDialog.java:603)
at org.eclipse.jface.dialogs.IconAndMessageDialog.createMessageArea(IconAndMessageDialog.java:86)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.createDialogArea(ProgressMonitorDialog.java:420)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.createDialogArea(ProgressMonitorJobsDialog.java:75)
at org.eclipse.jface.dialogs.IconAndMessageDialog.createDialogAndButtonArea(IconAndMessageDialog.java:224)
at org.eclipse.jface.dialogs.IconAndMessageDialog.createContents(IconAndMessageDialog.java:203)
at org.eclipse.jface.window.Window.open(Window.java:783)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.open(ProgressMonitorDialog.java:644)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.aboutToRun(ProgressMonitorDialog.java:553)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:478)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:242)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.disconnectFromWorkspace(IDEWorkbenchAdvisor.java:463)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.postShutdown(IDEWorkbenchAdvisor.java:309)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3117)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1206)
at org.eclipse.ui.internal.Workbench.access$22(Workbench.java:1118)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1459)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1456)
at org.eclipse.ui.internal.WorkbenchConfigurer.emergencyClose(WorkbenchConfigurer.java:147)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.closeWorkbench(IDEWorkbenchErrorHandler.java:244)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.handleException(IDEWorkbenchErrorHandler.java:146)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.access$0(IDEWorkbenchErrorHandler.java:137)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler$1.runInUIThread(IDEWorkbenchErrorHandler.java:112)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:97)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4032)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3708)
!SESSION 2017-08-08 20:02:47.798 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2017-08-08 20:02:55.236
!ENTRY org.eclipse.osgi 4 0 2017-08-08 20:02:59.089
!MESSAGE Application error
!STACK 1
at org.eclipse.swt.internal.cocoa.NSWindow.makeKeyAndOrderFront(NSWindow.java:202)
at org.eclipse.swt.widgets.Shell.makeKeyAndOrderFront(Shell.java:1312)
at org.eclipse.swt.widgets.Shell.setWindowVisible(Shell.java:2019)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1372)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:805)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:669)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1059)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-08-08 20:02:59.133
!MESSAGE
!STACK 0
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:209)
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:227)
at org.eclipse.ui.part.WorkbenchPart.dispose(WorkbenchPart.java:100)
at org.eclipse.ui.part.PageBookView.dispose(PageBookView.java:513)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:237)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:403)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:161)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.lang.Thread.run(Thread.java:748)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-08-08 20:02:59.151
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.eclipse.swt.SWTException: Device is disposed
at org.eclipse.swt.SWT.error(SWT.java:4533)
at org.eclipse.swt.widgets.Display.error(Display.java:1089)
at org.eclipse.swt.widgets.Display.asyncExec(Display.java:594)
at org.eclipse.ui.internal.WorkbenchWindow$9.changed(WorkbenchWindow.java:726)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:344)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
Any help would be really appreciated.
Thank you!
| Re: Eclipse Neon Crashes on MacOS High Sierra [message #1770200 is a reply to message #1770195] |
Wed, 09 August 2017 01:13   |
I got the following error message:
See the log file
/Users/saadaoui/Documents/workspace10/.metadata/.log
and the file content is the following:
eclipse.buildId=4.7.0.I20160915-0230
!ENTRY org.eclipse.core.net 1 0 2017-08-09 00:10:34.356
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:41.589
!STACK 0
at org.eclipse.e4.ui.workbench.renderers.swt.CTabRendering.drawTabBody(CTabRendering.java:372)
at org.eclipse.e4.ui.workbench.renderers.swt.CTabRendering.draw(CTabRendering.java:227)
at org.eclipse.swt.custom.CTabFolder.onPaint(CTabFolder.java:2026)
at org.eclipse.swt.custom.CTabFolder.lambda$0(CTabFolder.java:337)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4245)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5697)
at org.eclipse.swt.widgets.Display.applicationNextEventMatchingMask(Display.java:5070)
at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5451)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3689)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:692)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
!ENTRY org.eclipse.ui.workbench 4 0 2017-08-09 00:10:41.610
!STACK 0
at org.eclipse.swt.widgets.Display.getSystemImageForID(Display.java:1945)
at org.eclipse.swt.widgets.Display.getSystemImage(Display.java:1981)
at org.eclipse.ui.internal.statushandlers.InternalDialog.createTitleArea(InternalDialog.java:252)
at org.eclipse.ui.internal.statushandlers.InternalDialog.createDialogArea(InternalDialog.java:219)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:775)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1103)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.showStatusAdapter(WorkbenchErrorHandler.java:95)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:213)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:260)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:271)
at org.eclipse.ui.internal.Workbench$3.eventLoopException(Workbench.java:525)
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:41.612
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:41.712
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-08-09 00:10:41.713
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:41.716
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:42.280
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-08-09 00:10:42.282
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:42.284
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:42.511
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-08-09 00:10:42.512
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:42.514
!STACK 0
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:42.911
!STACK 0
at org.eclipse.swt.widgets.Display.getSystemImage(Display.java:1988)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4800)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3112)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1201)
at org.eclipse.ui.internal.Workbench.access$22(Workbench.java:1113)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1454)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1451)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4021)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3697)
!ENTRY org.eclipse.ui.workbench 4 2 2017-08-09 00:10:43.998
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.widgets.Display.error(Display.java:1086)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:837)
at org.eclipse.swt.widgets.Display.create(Display.java:820)
at org.eclipse.swt.graphics.Device.<init>(Device.java:129)
at org.eclipse.swt.widgets.Display.<init>(Display.java:719)
at org.eclipse.swt.widgets.Display.<init>(Display.java:710)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:1416)
at org.eclipse.oomph.setup.ui.SetupUIPlugin.performStartup(SetupUIPlugin.java:196)
at org.eclipse.oomph.setup.ui.EarlyStartup.earlyStartup(EarlyStartup.java:22)
at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:77)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:53)
at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2830)
!ENTRY org.eclipse.ui 4 0 2017-08-09 00:10:43.999
!MESSAGE Unable to execute early startup code for the org.eclipse.ui.IStartup extension contributed by the 'org.eclipse.oomph.setup.ui' plug-in.
!STACK 0
!ENTRY org.eclipse.core.jobs 4 2 2017-08-09 00:10:44.000
!MESSAGE An internal error occurred during: "Workbench early startup".
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@4b7af5e0 rejected from java.util.concurrent.ScheduledThreadPoolExecutor@152f946d[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 58]
at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2063)
at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:830)
at java.util.concurrent.ScheduledThreadPoolExecutor.delayedExecute(ScheduledThreadPoolExecutor.java:326)
at java.util.concurrent.ScheduledThreadPoolExecutor.schedule(ScheduledThreadPoolExecutor.java:533)
at org.eclipse.ui.internal.progress.ProgressManager$1.apply(ProgressManager.java:183)
at org.eclipse.ui.internal.progress.ProgressManager$1.apply(ProgressManager.java:1)
at java.util.concurrent.ConcurrentHashMap.computeIfAbsent(ConcurrentHashMap.java:1660)
at org.eclipse.ui.internal.progress.ProgressManager.refreshJobInfo(ProgressManager.java:683)
at org.eclipse.ui.internal.progress.ProgressManager$JobMonitor.internalWorked(ProgressManager.java:263)
at org.eclipse.ui.internal.progress.ProgressManager$JobMonitor.worked(ProgressManager.java:326)
at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2832)
!SESSION 2017-08-09 00:10:49.033 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2017-08-09 00:10:59.176
!ENTRY org.eclipse.osgi 4 0 2017-08-09 00:11:03.185
!STACK 1
!ENTRY org.eclipse.osgi 4 0 2017-08-09 00:11:03.212
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-08-09 00:11:03.214
!MESSAGE Device is disposed
!STACK 0
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:630)
at org.eclipse.swt.widgets.Display.getShells(Display.java:1740)
at org.eclipse.ui.internal.progress.ProgressManagerUtil.getModalShellExcluding(ProgressManagerUtil.java:321)
at org.eclipse.ui.internal.progress.ProgressManagerUtil.getDefaultParent(ProgressManagerUtil.java:376)
at org.eclipse.ui.internal.statushandlers.InternalDialog.<init>(InternalDialog.java:157)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.doAddStatusAdapter(WorkbenchStatusDialogManagerImpl.java:260)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.access$0(WorkbenchErrorHandler.java:88)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler$1.run(WorkbenchErrorHandler.java:55)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.handle(WorkbenchErrorHandler.java:52)
at org.eclipse.ui.statushandlers.StatusManager$StatusManagerLogListener.logging(StatusManager.java:331)
at org.eclipse.core.internal.runtime.RuntimeLog.logToListeners(RuntimeLog.java:161)
at org.eclipse.core.internal.runtime.PlatformLogWriter.logged(PlatformLogWriter.java:103)
at org.eclipse.osgi.internal.log.ExtendedLogReaderServiceFactory.safeLogged(ExtendedLogReaderServiceFactory.java:88)
at org.eclipse.osgi.internal.log.ExtendedLogReaderServiceFactory.logPrivileged(ExtendedLogReaderServiceFactory.java:217)
at org.eclipse.osgi.internal.log.ExtendedLogReaderServiceFactory.log(ExtendedLogReaderServiceFactory.java:189)
at org.eclipse.osgi.internal.log.ExtendedLogServiceFactory.log(ExtendedLogServiceFactory.java:65)
at org.eclipse.osgi.internal.log.ExtendedLogServiceImpl.log(ExtendedLogServiceImpl.java:87)
at org.eclipse.osgi.internal.log.LoggerImpl.log(LoggerImpl.java:54)
at org.eclipse.osgi.internal.log.EquinoxLogFactory$1.log(EquinoxLogFa
FUDForum. Page generated in 0.09289 seconds
